Question about Brother Sewing Machines
I changed the needle on my new Brother HE 240 sewing machine and now the automatic threader won't work. Any ideas?
I don't know why the auto threader won't work anymore.
  • Brother Master
  • 7,365 Answers
Make sure the needle is inserted all the way into the needle holder
also make sure the needle is turned the right way in the needle
holder
Posted on Nov 02, 2012
  • Kelly Smith
    Kelly Smith Nov 02, 2012
    Thank you Debbi. That's what I thought too, and so it finally came together, and I think that was the problem..
Brother HE 240. Red light with Raise the Button hole lever. During NON button hole sewing the light would come on and stop the machine.
Solution: I took off the cover and found two wires (red and black) with intermittent solders touching. Place a small flat head screw driver between and carefully separate the solders.
If you need pics email me, c6138498984@gmail.com
Tim
I changed the needle on my new Brother HE 240 sewi - 1_12_2013_5_39_33_am.jpg
Posted on Jan 12, 2013
bargainbox
  • 1388 Answers
SOURCE: Needle Threader is not lined up
This is called the Needle Threader Plate.
If this is too small for you to read, or you want any more help with this, just post back here, or, drop a line through the "Contact Us" page at www.bargainbox.com.au
Posted on Feb 24, 2008
  • 323 Answers
SOURCE: singer 2932 automatic threader
A new part is faster and easier but sometimes the problem is a bent hook( the tiny part which goes through the eye of the needle). Remove the needle to see the part better and pull the threader down. Look in the very center of the threader for the hook. It is probably pushed to the right.Using a small screwdriver or other thin piece of metal, force the hook back to the center. Try it and continue until it enters the eye again. By the way, a Singer dealer can get this part for you for under $10.
sewman7
Posted on Aug 11, 2008
freetek
  • 5568 Answers
SOURCE: auto threader
The parts for any autothreader are necessarily delcate considering the nature of its task. Check (without thread) to make sure the tongue that passes through the eye of the needle isn't bent a tiny bit causing it to strike next to the ****. Have seen this more than once.
Posted on Sep 07, 2008
talk2ginny
  • 34 Answers
SOURCE: automatic needle threader on brother se-350
Hi - first, make sure that you raise the needle to as far up as it will go. When you thread the machine, make sure you pass the thread through each number along the path - there is a hook on the threader mechanism that is really easy to miss. It is always a good idea to refer to the book when you are having a problem.
You might also try changing the needle. The threader has a teeny hook that goes in to the eye of the needle from behind, grabs the thread, and pulls it back thru the eye of the needle.
The threader can go out of alignment. If you got the machine last fall, it should still be under warranty. You can call Brother and ask where you can take the machine for repair. Or, you can go to Brother's website and look for information that might be helpful.
Good luck,
Ginny
Posted on Jan 31, 2009
SOURCE: Janome MC 10001 auto. needle threader stuck in up position.
I have a Janome 10001 and the needle threader is stuck in the down position and I cannot get it up. Help, please !!!!
Posted on Jan 11, 2010
I need an automatic needle threader for a Brother NS30 Le
Fixya does not sell replacement needle threaders.
Aug 05, 2016 | Brother Sewing Machines
Automatic needle threader won't work on brother pe-770
Always make sure the hand wheel is at the exact top. Have you replaced the need recently? If it's bent, then the threader will not work. If the needle is loose or not all the way to the top in the holder, it will also cause the threader to not work.
Jan 06, 2013 | Brother PE770 Computerized Sewing Machine
The self threader won't catch the thread
make sure the needle is inserted correctly into the needle holder
if the needle threader has worked before then there could be something
wrong with the needle threader
here is a link for a manual
http://www.singerco.com/uploads/download/545_7470-instruction-book-engfrespa.pdf
Dec 13, 2012 | SINGER 7470 Sewing Machine
After replacing needle, needle threader won't work. What am I doing wrong?
You probably haven't inserted the needle fully into the needle bar. Try that first.
Also check that there isn't a bit of needle shank in the holder.
Good luck.
Oct 04, 2012 | Brother Sewing Machines
Is there a automatic threader for this machine model 1599
go to the website of sewingpartsonline.com
look for the name of your sewing machine & then the modle number & see if they have a threader, if you don't find one,, email them & ask them & they can tell you for sure.
May 22, 2012 | White Sewing Sewing Machines
I can't get the needle to thread automatically on my new Janome 3160.
if the needle threader is not working, try rethreading the machine & if that
doesn't help then take the machine back to the place you bought it & see what they will do about it
May 02, 2012 | Sewing Machines
Automatic threader doesn't work
The automatic needle threader is very tiny and easily bent or damaged; however, it is designed not to turn if needle is not at its most upper position to protect the threader. Turn the hand wheel until the needle is at the highest position. If the needle is not aligning with the threader hook, you will need to replace it. And you can replace the needle threader hook if it is bent. I hope this helps!Jimmy
Mar 27, 2012 | Brother Sewing Machines
After automatic thread cut the needle comes unthreaded
you need long thread tails, of 3 to 6 inches for the top & bobbin thread so the needle doesn't come unthreaded,
also pull the thread behind the needle before you start to sew
Mar 27, 2012 | Brother PQ1500S Computerized Sewing...
Sewing Machines Logo
244 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
