Question about Rinnai RHFE-431FAIII 16,700 BTU Direct Vent Furnace Energy Saver Heater - LP Gas
Gibson LP furnace flashes 2 flashes - Rinnai RHFE-431FAIII 16,700 BTU Direct Vent Furnace Energy Saver Heater - LP Gas
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 4 Answers
Should be a chart on unit that will tell you what this is then you can test the part to see if that is the problem, but most of the trouble codes are roll out switch or main lemited switch on two blinks.
Posted on Oct 31, 2012
3 Suggested Answers
Therinnaiguy
  • 1420 Answers
SOURCE: g6rc lp furnace short cycles.
Tap on the pressure switch to possibly reset the switch to normal off position, not too hard. Check the small hose going to switch for any moisture or a blockage. Inspect your air filter and make sure it is clean. Check for a blockage in any of the condensate hoses or pump. And most importantly, check both air intake and exhaust pipes for any blockage or water that may be restricting the pipes. You can test the pressure switch by attaching a jumper wire to both leads when the inducer blower starts up. If unit fires, replace switch only after you have inspected all other items i mentioned.
Posted on Mar 01, 2010
  • 2976 Answers
SOURCE: Running out of LP??
Yes. The ignitor is trying to find fire and it can't. That's an ignition error. It should go away once you get fire to the sensors. You might have to hit a reset button, it all depends on the heater.
Posted on Feb 05, 2009
Have Gibson furnace runs cycle but seems don't get hot enough out of vents check all 115 degrees at vents use to lot hotter old furnace you couldn't stand on vents now you can easily
Is this a gas furnace ? Newer high eff. gas furnaces do have cooler outlet temperatures. The installer should have checked the temperature rise and gas pressure. By adjusting the gas pressure and blower speed you can obtain a higher outlet temp, but you don't want the gas pressure to be higher than the manufacture specs and you don't want the furnace to run outside of the manufactures temp rise specs.
Mar 02, 2017 | Gibson Heating & Cooling
Gas conversion lp kit 8927 has 2 pilot orifices...I only need 1, correct?
The smallest pilot orifice is used for LP. Make sure you read the instructions thoroughly. Usually the gas valve pressure regulator is disabled and the burner orifices are also changed. Good luck and hope this helps.
Aug 11, 2014 | Williams Wall Heaters: 30,000 Btu/hr...
Amp fuse keeps blowing
The component being protected by the fuse is drawing excessive current - has to be a board or something because the motor always draws more than three amps. Check the units schematic for locating the possible offending board. Must be relatively new since you indicate it is multispeed. Still under warranty?
Feb 23, 2014 | Gibson KG7SA045C23A 45,000 BTU 80% Gas...
Gibson LP gas furnace red light flashes 2 blinks
You need to lok up the code for that unit, propane requires a 100% safety pilot and also may have induced draft and proving devices as pressure switches, sail switches or centrifigual switches.
I would suspect a safety or proving device.
Oct 31, 2012 | Heating & Cooling
Nordyne LP Furnace wont fire
might be the flame sensor need replacing.
Apr 15, 2009 | Kitchen Appliances - Others
Running out of LP??
Feb 05, 2009 | Coleman Propane Forced Air Heater...
BLINKING LIGHTS ON fURNACE
had same problem, first you need to find the location of ignitor double black wires from plug on board and flame sensor.single red wire. 4 red flashes means ground fault, I removed ignitor, cleaned with some scothchbrite, cleaned around screw holes(2) to reestablish ground, I even ran a wire from one of the mounting screws to a ground elsewhere. then I went on to the flame sensor witch will give you flashing yellow light. single red wire to sensor that has one screw holding in. Remove sensor carefully and do the same as the ignitor, clean with scothbrite. I did this a year ago and is still going!
Jan 21, 2008 | Dishwashers
Heating & Cooling Logo
250 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
