Question about Epson TM-T88III Thermal Printer
Tm-t88iii feeds too much paper
Prints receipt but feeds too much paper at the end and does not cut automatically
  • 10 Answers
SOURCE: partial printing of epson TM-T88III
hi,
what you can do is to make sure that from you application you should choose the right size of paper and on the printer driver go to its printing preferences and select layout, from there you must select the roll paper.
you should be well from there..
Posted on Feb 24, 2008
SOURCE: how to auto tear paper after printing receipt is completed.
I had the same problem, and after going through so many articles, I was getting the message but didn't know how to pass the escape codes. All you need to do is pass the ASCII code of the characters needed preceded by the ASCII code for Escape. In Delphi, we use Char(27) or #27. In my case I used ESC 105 Null and it worked. Here is my sample code, with Str being a TStrings class (A string array object) and the WriteTextFile being a procedure to write the Strings to LPT1 as plain text. Str.Add('*********END**********'); Str.Add(''); Str.Add(#10); Str.Add(#10); Str.Add(#27#105); WriteTextFile(dmMain.LPTFile, Str); any questions, holla me at gachugu@yahoo.com or igachugu@gmail.com
Posted on Jun 10, 2009
SOURCE: Auto cutter does not cut automatically
TM 220a and TM 220b should come with auto cutters
You have to unscrew the metal tab under the printer, you will find two sets of DIP switches. upper one is DWS 1 and the lower one is DWS 2. On DWS 2 you need to have jumper #2 ON. this enables or activates the auto cutter on printers. Good luck...
Posted on Jul 04, 2009
57 varieties
  • 1653 Answers
SOURCE: TM-T88III print speeds and other issues
Try setting both switch 1-7 and 1-8 to ON for 38400 baud, set switch 1-2 to OFF to give a 4k buffer, set switch 2-5 to OFF to release the busy buffer at 256 bytes, set switches 2-3 and 2-4 to ON & OFF for medium print density and OFF & ON for dark print density or OFF & OFF for normal print density.
Also remember that the thermal TM-T88III also prints faster when the print head is cooler and slower when it heats up. The print speed is adjusted automatically depending on the voltage applied and head temperature. So make sure your power supply is providing a steady 24VDC at full load and has enough capacity to provide a peak of 7.7A in full speed mode. If you are using the printer in high temp and humidity you might want to swap the unit out for a Star Printer which performs faster and uses the same protocol or use a cooling fan.
Also make sure you use a good quality paper and that the humidity is within range at 10 – 90% RH although the paper performance will be greatly diminished at higher humidity levels.
Specifications:
High-speed = Approx. 150 mm/s {5.9"/s} max.; 47.2 lps, max. (3.18 mm {1/8"} feed);
35.5 lps, max. (4.23 mm {1/6"} feed, at 24 V, 28°C {82°F}, density level 1).
Low-power: Approx. 16.5 lps (4.23 mm feed {1/6"}); 70 mm/s {2.76"/s}
Ladder bar code: Approx. 42 mm/s {approx. 1.7"/s}
High-speed mode: Mean: Approx. 1.8A Peak: Approximately 7.7A @24VDC
Low-power mode: Mean: Approx. 1.2A Peak: Approximately 6.6A @ 24VDC
Operating temp = 5 to 45°C {41 to 113°F}
Operating Humidity = 10% - 90% RH
Posted on Aug 29, 2009
  • 1570 Answers
SOURCE: In installing an old Epson T88III receipt printer
Hi
Ignore the message to install the Epson TM-2.01 and proceed to install the correct driver for your Epson T88III.
Just set up or add the correct printer driver and make you choose USB port connection not parallel port. Then try to print the test paper and if prints, then you are properly configure your printer.
If not, you have to configure the correct driver and the correct PORT connection to your printer.
Please rate and make a comment if you find this solution very helpful and might help others as well. Post more comments if you need more help.
Regards and thank you for using Fixya !
Posted on Apr 15, 2011
Not printing, paper came out blank
1. disconnect printer from computer, turn off
2. re-seat thermal paper, make sure it's loaded correctly
3. press and hold paper feed button while turning the printer on
4. if print test is successful, reconnect to computer
5. print test page from printer driver
Aug 29, 2010 | Epson TM-T88III Thermal Printer
Does epson tm-t88iiip have a ribbon
No. thermal printers do not use ribbons or ink cartridges. They have thermal heads that heat up and use that heat to print on the specially treated, heat sensitive paper rolls. If the printer has stopped printing, check to see if the paper is thermal and loaded correctly (shiny side facing the front when it feeds).
Jul 13, 2010 | Epson TM-T88III Thermal Printer
Epson tm-t88II prints the second copy after i restart the pc
This sounds like its a problem with your EPOS software rather than the printer - contact your EPOS provider.
Dec 29, 2009 | Epson TM-T88III Thermal Printer
Printer not printing receipt and till programme freezes as a result. The "error" light is flashing 3 times...does this mean anything? thanks
tell me details when your problem arrive.........
If you set your paper in wrong position error light will flashing...........
Oct 27, 2009 | Epson TM-T88III (C420863)
Specifications:
Aug 28, 2009 | Epson TM-T88III Thermal Printer
Espon TM-T88III Not Feeding or Printing
Does it have a manual insert for the paper?
If it does, try putting the paper in that.
If not, or if that doesn't work, I recommend trying to reinstall the printer and drivers.
If that also doesn't solve your problem, please post back.
Apr 15, 2009 | Epson TM-T88III (C420863)
How to auto tear paper after printing receipt is completed.
moz-screenshot-2.jpgIf you are using the generic driver you can get the code from epsonexpert.com site or try this
SELECT CUT MODE AND CUT PAPER ASCII GS V m
executes full or partial cut. HEX 1D 56 m
DEC 29 86 m
m = 0, 1, 48 or 49 cuts paper
SELECT CUT MODE AND CUT PAPER ASCII GS V m n
feeds paper and executes full or partial cut. HEX 1D 56 m n
DEC 29 86 m n
m = 65 or 66 feeds paper to (cut position + [n x (vertical motion unit)]) and cuts the paper
n = 0 to 255
8f9f602.tif
Apr 08, 2008 | Epson TM-T88III Thermal Printer
Problems with regular printouts
you have to change the printer sittings before you print.
Oct 23, 2007 | Epson TM-T88III Thermal Printer
Epson TM-T88III Thermal Printer Logo
222 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
