Question about Panasonic NN-H965 Microwave Oven
Panasonic microwave NN-S615WFX will not start -
Microwave oven will not start - plug-in has been checked as well as main power supply. It had been working fine, but had to be unplugged for a short period of time. When plugged in again, it would not work.
SOURCE: Panasonic Model No. NN-S933BF Microwave Oven
could it be that i didn't follow the manuel because i got it second hand or is it because something is wrong with it,and i have to get it fixed.
Posted on Oct 21, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Panasonic Microwave Oven Stops After 15 seconds - Never Heats
If it stops at 16 seconds and is a sensor model, it probably has a defective humidity sensor.
You can order Panasonic parts from Tritronics.
If you reconsider, you can find an authorized Panasonic servicer here.
Posted on Oct 22, 2008
  • 4 Answers
SOURCE: my microwave says "child" and won't play anymore
Not sure of the TT series models but for the NN series models the procedure is as follows:-
If "Child" is displayed in the display window, then the child safety lock is on.
To remove the child safey lock, press the "Stop/Reset" button 3 times in fairly short succession (less than 3 seconds). The time of day or just the Colon sign (:) is then displayed
If you later want to apply the Child safety lock, then, when the time of day (or colon sign) is displayed, press "Start" 3 times (again in short succession).
Hope this helps
Doug
Posted on Nov 08, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: broken door catch, possible spring,
If you gently push up on the door latches (hook-like devices on the door) there should be spring tension. If they just flop right up, the spring is off.
Normally the problem is not the spring, but a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
If it's the door panel, it's usually easier and cheaper to use epoxy and some kind of hardware to fashion a new spring mount.
The door latch head (hook) is easy to replace or repair if that's the issue.
We have critical safety & disassembly info at our site, linked here.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
The best place to order parts is Tritronics. You can also call them at 866-779-5835.
Posted on Nov 27, 2008
  • 178 Answers
SOURCE: Need a users manual for a Panasonic Dimension 4
http://www.retrevo.com/samples/Microwave-manuals.html
Hope this helps!!
Posted on Sep 14, 2009
Microwave oven whirpool model mt1100shq,it was workinh fine suddenly stopped and no power coming to it
Check the mains power to the microwave before you check for power to the unit. If the program controller is not working , check power - step down supply, the pads are responding- if not faulty pads- or the door switches, if the switch contact are not good then it will not trigger the processor to switch on the waveguides. If the lights or fan work without any display or action of program being triggered to start then it can be a possible fault on the main board or the processor. Sometimes insect secretion can short the board and display panel and so the processor can work in such an erratic manner. If so clean, solder and reset the board. Now identify the parts by clicking this link: http://www.espares.co.uk/advice/microwave/a/5/141/identifying-microwave-parts.html
If there is no heating please do not switch on unless you have confirmed the fault. It is possible that the Magnetron is faulty, the temperature cut off is faulty or the main capacitor is short. It is also quite possible that insect can get into the oven and create soft spots. When you switch on these will create a short and make the voltage jump and in the long run damage the magnetron. Check this link to know how a microwave works:
http://www.espares.co.uk/advice/microwave/a/5/1443/how-a-microwave-oven-works.html
So Remove cover after disconnecting , check for dirt/moisture in the cabin, if so wipe clean and dry, check the magnetron and area clean and use an jet air to clean off. Check the wave guide covers, if food had deposited
then it must be checked or replaced. See link:
http://www.espares.co.uk/advice/microwave/a/5/1146/how-to-replace-a-microwave-guide-cover.html
Feb 11, 2013 | Microwave Ovens
Nn-t664sf no power
Check the power plug and also the mains supply to the main board. Please disconnect the power to check the continuity. Check the main fuse and if blown the main capacitor and surge capacitor.
Make sure that the program controller is working if not check power - step down supply, the pads are responding- if not faulty pads- or the door switches, if the switch contact are not good then it will not trigger the processor to switch on the waveguides. If the lights or fan work without any display or action of program being triggered to start then it can be a possible fault on the main board or the processor. Sometimes insect secretion can short the board and display panel and so the processor can work in such an erratic manner. If so clean, solder and reset the board. Now identify the parts by clicking this link: http://www.espares.co.uk/advice/microwave/a/5/141/identifying-microwave-parts.html
Jan 30, 2013 | Panasonic Microwave Ovens
The power just went off. tried unplug for 20 secs and plug again. tried the braker and plug. still nothing
Plug a lamp into the wall receptical, if it works! the main fuse in the microwave has blown. Unplug, and remove the top "several screws" check under the keypad and follow wires to the circuit board, look for a silver rectangular capacitor, take a screw driver and short the two points to remove any residual voltage. Now look for a small fuse "clipped" pop with screwdriver and replace with the same current rating, assemble unit because lethal voltages are present when powered on.
Mar 04, 2012 | Panasonic NN-T990SA Microwave Oven
There is no indication that power is getting to the Microwave. There is power at the socket so I know that it is getting to the plug. It has been working fine up until yesterday during the Thanksgiving...
The power from the plug to the main unit- the board must be checked. So you will need to remove the top panel to check, disconnect power and use a multimeter to check the fuse, power to the main board.If there is no heating please do not switch on unless you have confirmed the fault. It is possible that the Magnetron is faulty, the temperature cut off is faulty or the main capacitor is short. It is also quite possible that insect can get into the oven and create soft spots. When you switch on these will create a short and make the voltage jump and in the long run damage the magnetron.
Check for dirt/moisture in the cabin, if so wipe clean and dry, check the magnetron and area clean and use an jet air to clean off.
Make sure that the program controller is working if not check power - step down supply, the pads are responding- if not faulty pads- or the door switches, if contact is not through the microwave will not work.
Now keeping clear of the microwave, switch on, use a cup of water inside to test.
If you notice any sparks shut off as the magnetron or the main HT capacitor can be faulty. replace with same type.
If there is heating without any issues, you can use the microwave safely
Nov 26, 2010 | Samsung SMH9187ST Microwave Oven
My microwave isn't turning of wether I select mints or not
It isn't turning off? (typo check)
If it starts running as soon as you plug it in and close the door, the main relay is stuck on. On most microwave ovens, it's an electromagnetic relay on the controller board, and a new one probably costs about $5-$6 from an electronic supply firm. Before buying, test the relay and its driver transistor with an ohmmeter to see which part is shorted. (Do these tests with the oven unplugged!) If neither is shorted, you may have a controller chip failure.
A few models use a triac to run the magnetron. Check this for a short between the MT1 and MT2 terminals as well. Generally, though, the triac is only used for setting the magnetron's power level and a relay turns the magnetron, lamp and fan on and off.
Oct 29, 2010 | Emerson MW8102SS 1100 Watts Microwave Oven
Whirlpool Microwave error F3H
F3H Humidity sensor failure 1. Unplug microwave oven or disconnect power.
2. Connect a new sensor to the board (at P5).
3. Plug in microwave oven or reconnect power.
4. If no failure code appears when starting sensor function:
 Replace old sensor.
5. If failure code appears when starting sensor function:
 Replace power supply board.
6. Plug in microwave oven or reconnect power.
Aug 04, 2010 | Whirlpool GH5184XPQ Microwave Oven
No Power
Remove cover. Check that the fuse is good, if it is good, check power from power supply to main board.
Oct 29, 2009 | Sharp R-316FS Microwave Oven
Amana Microwave bulb I cant seems to access, model # AMV5164ACS??
The owner's manual shows you to to access and change them.
Your exact model is not there, but the similar models (like the BCS suffix) should work just fine.
COOKTOP/NIGHT LIGHT REPLACEMENT
CAUTION
To avoid personal injury or property damage, wear gloves when replacing light bulb.
1. Unplug the oven or turn off power at the main power supply.
2. Remove the bulb cover mounting screws.
3. Replace bulb with 40 watt appliance bulb.
4. Replace bulb cover, and mounting screws.
5. Turn the power back on at the main power supply.
OVEN LIGHT REPLACEMENT
1. Unplug oven or turn off power at the main power supply.
2. Open the door.
3. Remove the vent cover mounting screws. (3 middle screws)
4. Slide the grille to the left, then pull straight out.
5. Remove the charcoal filter, if present.
6. Press and hold the center snap while lifting the tab on the left corner. Remove the cover. Remove
the bulb by turning gently.
7. Replace bulb with a 40 watt appliance bulb.
8. Replace the bulb holder.
9. Replace the grille and 3 screws. Turn the power back on at the main
power supply.
Jun 26, 2009 | GE JVM1650 1000 Watts Microwave Oven
Panasonic NN-H965 Microwave Oven Logo
368 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
