Question about Goodman Heating & Cooling
How do you light the furnace of a goodman ez 1625
Trying to light the furnace for the heater
  • 499 Answers
We have not lit pilot lights ourselves since 1978 when they outlawed standing pilots in Ca for furnaces. We have electronic ignitions of spark oror hot surface ignition, neither of which can be manually lit.
Do you get any fan action if you flip the fan on from auto?if so, you have power and 24v control power too, I would start there.
Posted on Oct 31, 2012
johnsonr1
  • 91 Answers
SOURCE: I have a goodman heater/ac unit and the heater
NO, the furnace has an electronic ignition system, if it is new than 15 years. Your ignitor may have failed. Depending on your location, this is approximately a 180.00 repair for a service techician to come and install the part. This is parts and labour, not just the part. The part is approximately 50-90 dollars, depending on location.
Posted on Nov 04, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: I HAVE A 45000 BTU GOODMAN FURNACE RED LIGHT
There may not be a call for heat being registered by the control board. Take the R and W terminals on the control board and put a jumper between the two. If the heater starts, you have either a broken thermostat wire or a bad thermostat or connection.
Posted on Jan 25, 2010
Therinnaiguy
  • 1420 Answers
SOURCE: goodman furnace model#GCH90904CXAB the red light
This model is equiped with a diagnostic error control. Take off the front panels and look for a wiring diagram pasted on the reverse side of the panels. On this diagram there will be a chart telling you what 4 blinks represent and where to start looking for the issue. I suspect the air filter may be dirty or the pressure switch may be bad, however make sure the condensate hoses are free of any debris. Good luck to you!
Posted on Apr 25, 2010
  • 53 Answers
SOURCE: goodman furnace model # GMNT100-4B
from my experience with goodman units ,it could have been a gas supply problem there are so many protective sensors that i dont think it is the unit by the way is it electronic ignitor or pilot
Posted on May 16, 2010
  • 1033 Answers
SOURCE: What's your problem? goodman furnace lights, burns 10 secs goes out
Hello,sounds like you have a dirty flame sensor. This is a metal rod on the oppositenside of the hot surface ignitor. turn off power to the furnace and remove the flame sensor, then use steel wool and clean the flame sensor and reinstall. Next turn back power to Furnace.
Posted on Nov 18, 2011
Blower motor makes noise, but does not work goodman
its either a bad motor or bad capacitor if you try to spin the wheel by hand and it starts then its the capacitor
Dec 26, 2012 | Goodman Heating & Cooling
Furnace will not light,on Goodman Furnace model#GME80704BX
Is the gas turned on or does it come on but goes off quickly?
Oct 06, 2012 | Cozy Enclosed Front Console Heater 70,000...
Nov 18, 2011 | Goodman Heating & Cooling
My goodman furnace will not light,complete new hook-up
not much to go on.dianogstic light will tell you whear to start.these are sensitive to polairty.check to confirm hot 110 is black wire.I put one in that had on off switch on gas valve.turn on.did you bleed air out of supply? did furnace try to light?
Dec 22, 2010 | Goodman GMS81405DNA Open Flame Mid-Size...
Goodman furnace model # GMNT100-4B On vacation neighbor checked house house filled with gas. He shut off main and furnace. Came home turned on gas to everything except furnace. All good. Furnace will not...
May 14, 2010 | Goodman GMS90703BXA Heater
Goodman furnace model # GMNT100-4B On vacation, neighbor checked house, house filled with gas. He shut off main and furnace. came home turned on gas to everything except furnace. All good. Furnace will...
Solid red typically means bad controller. Try unplugging the furnace, wait about 30 secs, then plug it back in. The possibility that the controller was sending voltage to the valve even when there was no flame is a bad sign. If the controller starts the furnace, watch it very closely and see what it does. If the solid light comes back on, it's time for a new board.
Mar 24, 2010 | Goodman GMS90703BXA Heater
Is a patriot heater comparable to a goodman heater
The Patriot 80 is an oil furnace made by heat controller, To my knowledge Goodman (aka AMANA) does not make an oil furnace.
Feb 23, 2009 | Goodman GMS90703BXA Heater
How to manually relight a Goodman® GMS9/GCS9 Single-Stage, Multi-Speed Gas Furnaces
You should NEVER attempt to relight manually this furnace. Serious burns could be the result. This furnace has an electronic ignition and should light by itself. If it does not light you may have a bad ignitor. These are usually around 30-50 US dollars.
Jan 28, 2009 | Goodman GMS90703BXA Heater
Heating & Cooling Logo
270 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
