Question about Electrical Supplies
I need a wiring diagram for a homelite generator lr5000t
2 Suggested Answers
  • 42 Answers
SOURCE: wiring diagram for Generac engine on standby generator
here is a wiring diagram for that engine:
Posted on Mar 13, 2009
Battery charging and control, electric start. Need schematic and parts list.
The UT number for this generator is UT-03559. The problem is like yours can't find anything online in the line parts or owners manuals for this unit. You may try http://www.ktoutdoor.com/
They were listing this number. doesn't mean they have anything on it but might be worth a try.
Here is alternate idea on recharging the battery use a 12 dc ac adapter for recharging while the unit is in use.
Feb 26, 2015 | Electrical Supplies
I have homelite textorn 7500watt generator not strating ,no carunt to spark plug
You'll need to look up to see what the ohms are on the coil of that chainsaw use of a multimeter required it should have a reading between to set readings if ok then check for loose or broken wires
Feb 07, 2015 | Homelite Garden
Generator output plugs don`t work
If you don't see a reset then you may have to replace a diode or voltage rectifier inside your unit.
Nov 29, 2013 | Homelite Lr5000t Generators
I have a hg 6000 homelite generator, runs great but does not give me any power. i used it a year or so ago an everything worked fine. got a lil smoke from where windings are. the generator was made in...
Hi and welcime to FixYa. I am Kelly
This is going to sound odd but.... this is how it it is recommended to field flash and inverter type generator. (Brushless) The steps are to (not kidding...) use a male mail interconnecting wire from your house wiring and plug in your generator and turn ON the main CB for 1 minute.
If this does not work.... See steps below amnual links.
Owners manual link: (Click on get manual)
http://lawnandgarden.manualsonline.com/manuals/mfg/homelite/hg6000_1.html
Or try this direct link:
http://lawnandgarden.manualsonline.com/support/homelite/portable-generator/request-manual-299128
This is a brushless generator... Not sure what the smoke was but... the yellow wires are for the capacitor winding. If you probe the capacitor terminals with one of the wires disconnected with a meter on R x 10,000 you should see a brief jump in resistance and then the meter drifts to infinity.
reverse the test leads and test again looking for the same result.
Next read resistance Yellow wire to Yellow Wire (Stator capacitor loop check) It should read low resistance
Also read Brown wire to Brown wire. This is the DC stator loop check. Is should read resistance.
Main winding checks Red to Blue and White to Brown that goes to the main breaker. OR Turn the Main breaker on.. White to lower left pin of 30A 4 pin output recepticle. Bot red to blue and White to Brown MUST read low resistance
These are all the checks except the rectifier and the rotor. You will probably find something during the above tests. If not... respond here and I will pass on the rotor and diode tests.
Kelly
Aug 27, 2011 | Electrical Supplies
I need a wiring diagram for a homelite HRI4400HD generator please.
Go to Homelite's web page http://www.homelite.com/ and you enter your Model Number and download the Owner's Manual, that should have wiring diagram in it. If you don't find it. contact Homelite Customer Service.
Hope this helps you find what you need.
Apr 18, 2011 | Heating & Cooling
Have inherited a homelite generator- LR5000T what grade of oil does it take. Also, does it support 220 volt equipment? Equipment draws less than 15 Amps.
Yes, this generator supports 220 volt. The grade of oil advertised for this generator is 10W30, 4-cycle.
I hope this helps. If it does, I'd appreciate your vote. Thanks,
Handie Andie
Apr 12, 2011 | Homelite Garden
I need the ignition wiring diagram for a Homelite HB180V UT08010B
There is no ignition wiring diagram for the HB180V; it is a 2-cycle engine that uses an ignition module, part number HM-06504A which can be found just about anywhere for $40-$50
Oct 07, 2009 | Homelite Garden
Homelite ut13122 replace battery,need a wiering diagram
I have seen the wiring diagram and it does not make sense to me. I normally write a diagram of the wiring when i take the cover off to keep things straight.
Sep 30, 2009 | Homelite Garden
Electrical Supplies Logo
94 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
