Question about Hughes SD-DVR80 DirecTV / TiVo DTV Receiver / 70-Hours Video Recorder
No local channels
I reset my receiver because of power failure. And I do not get my local channels. They come from 72.5
Is the receiver fried? or can the problem be fixed?
I have gone throught all the setup function. The local do not even show up on the guide. Help.
  • 68 Answers
Make sure u are gettin a signal on the 72.5 if you are call dtv and have them reauthorize the locals to your receiver. they can send a signal for a force download
Posted on Jan 06, 2009
How to reset denon avr 1913
Is thereany sign of power? relay click or anything?
Jun 07, 2014 | Denon AVR 1913 71 Channel 3D Home Theater...
Dish tv support
Hi Vicki,
You may call them at
  • CALL US 1-888-615-3725 for DISH
  • You can also try this steps:
  • MISSING OVER THE AIR CHANNELS The quality of reception and number of channels available depends on the antenna's placement and the customers location. Weather conditions may interfere with channel reception. The Channel Display receiver menu option may not be set correctly.
    1. Check Over-the-Air Antenna ConfigurationCheck that the wiring between your DISH receiver and your over-the-air antenna is configured properly using Setup OTA
    2. Reset ReceiverIf the issue is only on ONE receiver, unplug the DISH receiver for 10 seconds and plug back in.
      Please note: It may take up to 5 minutes for the reset process to be completed.
    3. Rescan Over-the-Air Channels to ReceiverAccess "Local Channels" select "Scan Locals" then "Save".
May 08, 2014 | Televison & Video
MY BOGEN BR 360 RECEIVER WORKS ON ONLY ONE CHANNEL
Are you shure the speaker is good? Switch them around, If it still doesn,t work the problem is with the reciever,The output transister is probally fried,
Dec 06, 2012 | Audio Players & Recorders
Receiver goes on then off
Receiver goes on and off
There could be electronic components failure
• need to open the unit
• get a multimeter and measure the DC voltages present on
each of the amplifier output stage.
• it should be no more than 0.7 V, if it s, remove those pair of power
transistors and test again for output voltages.
the negative probe
of the multimeter to the chassis of the unit.
• if the problem goes out,
assume one of the extracted pair is bad.
you can test it individually since it is already outside the circuit.
• There could be other causes like regulators on the power supply
Let me know how you make out with the inspection.
It is a good chance you will find something.
hope this helps, thanks for using Fixya!
Aug 07, 2012 | Yamaha HTR6280 72 Channels Receiver
Did I fry my Kenwood receiver with excessive input?
It is very possible that you lost a channel and the uit is in protect.
Apr 10, 2012 | Kenwood Audio Players & Recorders
Denon AVR 2105 power shuts off, tried resetting the micro processor and no luck. Please help...
The receiver has an internal problem like bad power supply or burnt channel. You need to bring it to a local repair shop or mail it here.
Feb 06, 2011 | Denon AVR-2105 Receiver
Hughes sd-dvr80 direct tv receiver tivo
go to your settings page and run the initial setup. make sure each section is done correctly. the tivo might take a second to start downloading the locals.
Jan 03, 2009 | Hughes SD-DVR80 DirecTV / TiVo DTV...
Onkyo rx-ds989 no sound from speakers
With the initial price of this being as high as it is, it is probably worth saving.
If you haven't checked all outputs, I would advise doing so since that would help localize a potential point of failure.
If NO outputs are still alive, it may be a failure of the main power supply of the unit; if this is the case, the repair may not be that costly.
If some outputs are still active, it could still be a power supply failure since it is probably not servicing all channels from a single supply. Alternatively, it may be a failed output module with two channels in a shared housing.
Nov 15, 2008 | Onkyo TX-DS989 Receiver
Garmin gps 72 not aquiring satelites
Press POWER ON and PAGE buttons at startup and leave for 20 minutes to initiate
Nov 09, 2008 | Garmin GPS 72 GPS Receiver
Hughes SD-DVR80 DirecTV / TiVo DTV Receiver / 70-Hours Video Recorder Logo
174 people viewed this question
Top Hughes Televison & Video Experts
Jim London
Jim London
Edward Talavera
Edward Talavera
Are you a Hughes Televison and Video Expert? Answer questions, earn points and help others
