Question about Maytag MSD2756G Side by Side Refrigerator
None of the buttons on the door will not work
I took the advice for this site and fixed one problem and have developed another. I have a Maytag Plus MSD2756G fridge and I changed the filter and reset the buttons on the door for the filter by holding the lock button and the filter button for so many seconds and release. But now I can't get the ice maker or the water buttons to work, when I press them nothing happens.
  • 163 Answers
Hi!! You should be able to unlock it from the dispenser control panel if not disconnect the frig for 5 minutes from the back of the wall and try again..Good luck..
Posted on Jan 03, 2009
Tough scrub plus button blinking
I have the dishwasher working again. Now I have a problem because while checking things out I took out the pump sump support bracket part w10300599 and I don't know where to put it back in. Does anyone have a picture of this installed?
Sep 12, 2012 | Maytag Jetclean Plus MDB6769AW Built In...
Maytag MFI2568aes:none of the keypad controls work. Is it the control board that is no good?
Check the harness up at the top of the door. Remove the cover and be sure everything is plugged in correctly. Sometimes the harness will work loose do to door movement.
Aug 18, 2012 | Maytag MFI2568AES Stainless Steel Bottom...
I have sharp AR-5316e and it has CH error non function are working.
CH
ON
None Content Side door open
Detail The side door is open.
Cause Side door sensor abnormality
MCU PWB abnormality
Check
and
remedy
Check that all the side doors are closed.
Replace the MCU PWB.
CH
Blink
None Content Developing cartridge not installed
Detail The developing cartridge is not installed.
Communication with the CRUM cannot be
made in initial check of the CRUM.
Cause Developing unit disconnection
MCU PWB abnormality
CRUM chip abnormality
Check
and
remedy
Check installation of the developing unit.
Replace the MCU
Jul 20, 2011 | Sharp AR-5316 Advanced Digital Imager...
I have a Maytag plus, side by side fridge (MSD2758DRB) that is leaking from the freezer side, bottem of the door where the plastic tube comes out, what can i do to find out how to fix it!
Same problem here, took apart the entire door. Most likely it's a problem with ice defrosting inside the door. It was not the tube that runs through the door, there are no joints or washers inside. Perhaps seal on door edge is letting warm air through.
Oct 30, 2010 | Refrigerators
Flashing lights on Maytag dishwasher
Check whether the door is getting closed fully. Try pushing little hard. If the door close switch problem it may work.
Contact service for help if u can not proceed further with electrical circuits. Micro-controller board to be checked!
May 18, 2010 | Dishwashers
MVP microwave panel doesn't work. Can't push any buttons
Okay, that's a Maytag MVP series model CMV1000ADW. Thanks.
Your membrane keypad has failed, and in this case, it's a pretty simple thing for the average do-it-yourselfer to fix.
You can order the control panel frame with keypad (part # AP4060316) for $65.76 plus shipping here.
You can also find helpful exploded views at that link.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you disconnect the keypad strip from the circuit board, as shown in the photo below.
Next, move your circuit board to the new control panel frame, reconnect everything, and you're done.
If you would like to have us do this repair for you, we do that for $39.95 plus part costs.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Jun 28, 2009 | Maytag MMV5186A Microwave Oven
Blinking lights, unresponsive
I went to the Maytag site looking for a manual. None existed for my model, but I looked up won't start under the FAQs. The advice said to push the cancel button twice. My model doesn't have one, so I just started at the left side of the control panel and pushed each button twice. pushing the dry button twice made the lights stop blinking. i pushed the wash button and the unit started.
May 08, 2009 | Dishwashers
Maytag dependably quiet plus not starting
check connections to the door switch.
Nov 04, 2008 | Dishwashers
Maytag Microwave MMV1153
First of all, it's under warranty. So I would contact Maytag for a free fix.
See http://maytag.com/support/service_parts.jsp
For an out of warranty reply:
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Nov 27, 2007 | Maytag MMV1153A Microwave Oven
Maytag MSD2756G Side by Side Refrigerator Logo
365 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
