Question about LG LRBN20510WW Bottom Freezer Refrigerator
Temperature Control The temperature control on the top will not work. The refrigerator is not cold. The freezer control is working, yet unable to turn it down. Ice is forming (not the ice maker) in the freezer. There are no lights showing on the temp control in the refrigerator. I pressed the "adjust" button still nothing. Thanks for your time.
  • Anonymous Nov 17, 2007
    The L.G. refrigerator does not form ice.Otherwise cooling does take place
    P.N.R.Rao
  • Anonymous Mar 12, 2008
    refrigerator will not get cold, only 2 years old. the freezer bottom is fine but the top buttons will not push in. vac. good in the back and bottom, still no help. I cannot figure out how to take off the cover on the control buttons, help
I called the service number in my manual twice. Both times I waited and waited and then was told that I was not in their service area. I have a 5 year warranty and went to the store where I bought my LG refrigerator and they helped me get a service person. I was advised to turn the temp control to 7 which is maximum. However, recently, I have again begun having a temperture problem and I will be calling service again.
Posted on Mar 06, 2008
    Problem Solver:
  • 3 Answers
Call the number in your service manual. they'll ask you to sent the receipr, the silver sticker on the back of the fridge, and a piece of the outlet cord so they know it's not in use. they'll ship you a new fridge. WOW!
Posted on May 17, 2007
Why is the refrigerator side is freezing food
First some fridge 101, the refrigerator/freezer models cool by directly refrigerating the freezer section and the refrigerator section is cooled when "some" of the cold air from the freezer is directed over to the refrigerator side (typically by a fan) to keep food fresh and not frozen a temperature controlling damper opens and closes to regulate the temperature of the fridge by introducing more or below freezing air into the cabinet. In older models where the freezer was on top the air simply "gravity" drained into the refrigerator cabinet, if the food was too cold you turned the fridge knob up and less air sank from the freezer to the fridge, simple but effective.
When you adjust the temperature level it controls the freezer temperature and this turns the compressor on and off to keep the food frozen. There is typically a knob or lever and some even have electric dampers that open and close to direct more or less air from the freezer and direct it to the refrigerator cabinet based on your temperature requirements.
Now that you know how it works there are a couple things to check. If the condenser coil is plugged with dust the internal system pressure will rise and in some cases make the fridge an over achiever and can chill too much so check/clean the condenser coil. Check the freezer temperature control and turn in up, also make sure the fridge temperature control setting is not set too cold.
Finally as the temperature changes around the refrigerator it will have an effect on the inside of the fridge too so expect to turn it up and down as the environment changes, down in the summer and up in the winter.
Hope the novel helps to resolve your issues.
Nov 01, 2017 | Refrigerators
I have a 2yr. old Maytag Frig.,freezer on top.I cannot get a stable freezing temp. I can set, with the setting control, readings of 4 or 7 with no effect on the actual temp. I bought a freezer thermometer...
If the refrigerator is not cold enough then please check the following and also click on the blue coloured links for more info.
How To Check the Temperature1x1.gif In most refrigerator freezers, the refrigerator gets its cold from the freezer. The evaporator fan circulates air over the coils in the freezer and cold air circulates into the refrigerator through vents. If the vents are blocked or closed, then the fridge will not get cold enough but the freezer will. If neither is cold enough, then the number of possibilities increases.
Lowering the freezer temperature will increase the cooling cycle activity. Setting the refrigerator temperature may have little affect on the cooling cycles because it simply changes the vent opening size. Decreasing the fridge temperature opens the vents more and increases air circulation from the freezer.
The temperature can be adjusted using the controls found inside the refrigerator or freezer. The ideal freezer temperature is about 0 to 5 degrees (F) and about 38 degrees (F) for the fridge.
Measure the temperature by placing a cup of water with a cooking thermometer into the refrigerator for about 2 hours or more. To test the freezer, substitute alcohol or cooking oil.
Goodluck,
Please don't forget to rate the solution.
Mar 27, 2008 | Refrigerators
How do you work temp control on GE Profile top freezer
The ACTUAL TEMP light will come on and the display will show the actual temperature. To change the temperature, tap either the REFRIGERATOR or FREEZER pad until the desired temperature is displayed. To turn OFF cooling system, access SETTINGS from the HOME screen. Page over and tap COOLING SYSTEM ON.
Sep 22, 2017 | GE Refrigerators
How do I keep my refrig/freezer from defrosting in the winter when store in the garage.
There is only one source of cold in many refrigerators. If yours is a top freezer, then most likely it is in the freezer.
But the thermostat that you set temperature with is in the refrigerator, not the freezer.
In the cold garages, what can happen is that the refrigerator stays cold enough that it does not call for cold. So the freezer does not get enough cold.
The freezer control works by diverting cold air into the freezer WHEN THE RERIGERATOR HAS TURNED ON THE COOLING. If it is not turned on, oh well.
The best you can do for this is to put both on max cold. Then the refrigerator will call for more cold at a lower temperature, and the freezer will get it more often and will divert more when it is cooling.
This can result in the refrigerator freezing things too. You can try raising the refrigerator setting JUST A LITTLE and see if both work, but keep freezer on max cool.
This works for my situation, but ambient temperature fluctuations in the garage make this dicey. We don't put things like lettuce in the refrigerator in the garage in the winter because freezing damages them.
Good Luck
Feb 05, 2015 | Refrigerators
Temperature
Hello R, thank you for your question! Generally speaking it is recommended that the temperature knob is set in the middle for both the refrigerator and freezer compartment for top mount refrigerators. The temperature can be adjusted by moving the knob in small increments, allowing the temperature to stabilize. If you desire a colder temperature, then turn the knob towards COLDER, or for warmer temperature, turn the knob towards COLD. Turning the refrigerator control will change temperatures in both compartments. For example, if the refrigerator control is turned to a colder setting, the freezer control may have to be adjusted to a warmer setting. Turning the freezer control will only change the freezer temperature. Hope this proves to be helpful!
Jul 22, 2013 | Refrigerators
Fridge too cold
check the damper control and damper door between the freezer and refrigerator compartment to see if its iced up in a fully open position,if so thaw it out and then see if it moves as in opens and closes when the cold control in the refrige is adjusted,if not replace the cold control
Jan 17, 2010 | Refrigerators
I have a HTR16ABSARWW Top Freezer Refrigerator in
You need to warm up the garage for it to work right. The cold control reads the refrigerator temperature and if it's already cold, will not turn on the compressor. Hence the freezer warms up to the ambient temperature.
Jan 06, 2010 | Hotpoint Refrigerators
Freezer does not freeze fast enough, icecream gets soft
Faulty Cold control (Temperature Control)
The cold control is a temperature actuated switch and should open when the set temperature has been achieved. If the control does not open and turn the compressor off, it will continue to run and all items in the fresh food section will begin to freeze.
If the control is not closing, the compressor and all fans will cease to operate. Check the control for continuity.
This is usually not a do it your selfer.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Apr 25, 2009 | GE GTS22KBP Top Freezer Refrigerator
Freezer cold but not freezing
Check the settings for the freezer control. Refrigerator temperature control normally controls the run time of the compressor. if the freezer control is set to low the refrigerator temperature will be fine and the freezer will be warmer. Setting the freezer control to a colder setting will hold back more cold air in the freezer and reduce the air volume supplied to the refrigerator. Check and make sure the condenser coil is clean.
Jun 08, 2008 | Liebherr Premium CTP 3153 Top Freezer...
LG LRBN20510WW Bottom Freezer Refrigerator Logo
179 people viewed this question
Top LG Refrigerators Experts
Steve Allison
Steve Allison
Colin Stickland
Colin Stickland
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
