Question about Kenwood Audio Players & Recorders
Overloaded cd player. it will not respond at all now
    Problem Solver:
  • 19 Answers
Do you have any pictures or even a video on it so i can see what the problem is?
Posted on Oct 31, 2012
  • clc_05
    clc_05 Oct 31, 2012
    no sorry
Rockola 481 max 2, mechanical overload light comes on, reset button resores play for a short time, what causes it?
Sometimes a motor is too slow because it's dirty and more current is needed to turn it, so everything ramps up and overloads.
Nov 11, 2014 | Audio Players & Recorders
32MD251D/37 will not power on
Zack Corpier
Workup for repair
02/22/2013
Diagnosis for Magnavox 32MD251D/37
Symptoms:
Will not power on
Once on, if turned off power might not return
Does not respond to power cycling
Possible Culprits:
Overloaded fuse
Damaged/fried power board
Damaged/fried inverter board
Damage to wiring or related
Overloaded capacitors on power board - I identified this based on a visual inspection and a multi meter test
https://lh6.googleusercontent.com/-Mcf67G5l3l8/USgitModWZI/AAAAAAAACRo/PwjueC45Hjo/w333-h319-o-k/caps.png
Problems Identified:
Capacitor 2079 appears overloaded - 1200uf 35v
Capacitor 2080 appears overloaded - 1200uf 35v
Explanation:
The capacitors referenced regulate the voltage controlling the power. These caps have a limited lifetime in hours which is usually around 3000. The device was left on for an extended period of time overloading these essential components.
Resolution:
1. I will order a set of replacement capacitors
2. Discharge board prior to work
3. Remove and replace damaged capacitors
Required Parts (total cost $30):
(2) Vented axial 1200uF 35v Capacitors - $8
Variable wattage soldering iron (minimum 35w) - $22
Feb 10, 2013 | Magnavox 32MD251D/37 Tabletop Pedestal...
CD rom not responding does not spin, play or eject
the cd player has gone bad. make sure you have it set to cd for sometime's things get alil stuck
Jan 12, 2010 | Nakamichi SoundSpace 5 Shelf System
03 vibe cd player will not respond
I blew a fuse controlling the radio, charging system, turn signals, heater fan, ,etc..this ran down my battery.
When I replaced the fuse, the CD player would not respond, but the radio worked.
I disconnected the battery for over 30 seconds, hooked it back up, and the time reset on the radio to 12:00 and the CD player works again.
Jan 23, 2009 | 2003 Pontiac Vibe
2GB Player not responding
That player is not compatible with iTunes - sorry. Loading them onto there has corrupted your DB - go to Sansa'a website and download the Sansa Recovery Tool
Jan 09, 2009 | SanDisk Sansa Fuze MP3 Player
My Numark Cdx and Numark Cdn90 are frozen
Hi Mitchdias,
Have you tried downloading the most recent rom update for the CDN-90? All you need to do is download it from here http://www.numark.com/contentmgr/showdetails.php/id/1493/tt/5 , then burn the download to disc. Once that's done, put the disc into the player, switch the player off and wait 10 seconds, then switch it back on again. the player will read the disc and flash the ROM. this should reset the player for you. Before you ask, you can out the disc into either side of the player. Full instructions are given with the download.
Jan 05, 2009 | Nu Mark Numark Cdx Table Top CD Player CD...
Numark cd mix 1
The buttons usually wear out, open unit and replace the buttons.
May 14, 2008 | Nu Mark Numark Cd-Mix-2 Dual CD...
CD player won't eject CD and does not recognize the CD
You will have to remove the player from your Sierra and disassemble it sufficiently to remove the stuck CD.
May 30, 2017 | Car Audio & Video
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
da surgen
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
