Question about Kicker Car Audio & Video
Why is it when i sit in idle the sub will play when i hit the gas it stops?
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 62 Answers
Check your amp. is it turning off and on as you move?was the system professionally installed?check for loose wiring.check where the power wire came in through the fire wall
Posted on Nov 05, 2012
Why does it Start and idle great but when i aply gas injectors close
You very likely have clogged injectors from dried up fuel.
Apr 26, 2016 | Cars & Trucks
Why does my car die when you hit the brakes?
Hi is maybe a liitle hard to asmwer with out having car to check sensor readings.
But i will help the best i can .Do you have a scanner that you can live data on?
Youll need to check you iac reading that is your idle air control .The growing
you heard was it like a hissing from under dash near brake pedal? That maybe your brake booser.If not where is noise coming from? Also when coming to stop and car trys to die if you hold brake and give gas does it stay running or die
if so check your fuel press at idle should be 38-45 psi maybe fuel pump
Jan 03, 2012 | 2005 Chevrolet Cobalt
Have 2007 suzuki vinson quadrunner 500 4x4,only runs at idle with choke on ,has been sitting for year,new gas in it now.
Mine did the same thing. I took the air filter off and there was about a half inch of gas sitting in the bottom, so I just soked that up started the wheeler and covered the air hole w my hand and hit the gas. After that it started working. It died when I did that and then it started right up.
Oct 11, 2010 | Suzuki GT 500 Motorcycles
Fuel pump or filter possibly
the idle control sensor could be bad give these websites a try www.alldatadiy.com and www.autozone.com if all fails stop by your local GM dealership and ask for the manager and he can tell you what is going on if that fails stop by your local library and get your hands on a Haynes auto repair manual for you car wish you the best Michigan Man.
Nov 06, 2009 | 2001 Chevrolet Camaro
My car idles high like at 6 rpm n i dont even gotta hit the gas to get it to go n to get it to stop COMPLETELY i have to shovee it in neutral while its in motion, it wont stop idling high and i ride the...
Well all cars idle at 550 rpm to 700 rpm depends on engine but it sounds like you throttle body is not shutting down .
yes could be idle sensor or you could have a hose come off the intake manifold so bypassing the body valve, ,check throttle cable for free play when not going..check for hoses off /crackedand leaking air/or hose off the engine block either big or small ..
Sep 24, 2009 | 1991 Acura Legend
Sub woofer
are your subs bridged? if they are try unbridging them... if that doesnt work try finding a better ground, and if neither of those work turn the amp down while music is playing until the palsating stops and the speakers are just hitting...
Dec 18, 2008 | Car Audio & Video
Sub not hitting constantly
The big speakers have wires from the frame to the voice coil. After longer use at higher volumes (or longer travel), the wire can fracture, and make contact only some of the time..line on a bounce or knock.
Apr 20, 2008 | Car Audio & Video
System not playing
Sounds like the output transistors on the amp are blown. Were you slammin when it stopped or how did you find out it stopped working. It could be the sub failed then caused the ap to go which is why you get a little something from the JL.
Feb 11, 2008 | Car Audio & Video
Car Audio & Video Logo
22 people viewed this question
Top Kicker Car Audio & Video Experts
Professor_V
Professor_V
Tygh Duval
Tygh Duval
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
