Question about Denon AVR-4308CI Receiver
Hdmi not working
Hdmi pass through or upscaling does not work. When any component is used with the hdmi I get ant screen. All the equipment works with one another in any combination. I have a bit stream digital air tuner, mitsubishi xd450, sony 350 blu ray, ps3 , denon 755 dvd player,as stated before all work great with one another. Denon only blames other components. I have tried sequencing the equip (the hand shake etc.) They are all hdcp 1.3 compliant. I get very little help from donon Any help please.
    Problem Solver:
  • 6 Answers
Please rephrase you get an "ant screen"?
Does the sound work? What is your hdmi video output device?
At any rate, you can also try this quick fix. In the setup menu go to Source Select. Make sure these settngs are right:
Assign>HDMI = HDMI 1 - 4 (depending on device)
Input Mode>Input Mode = Auto
Decod Mode>Decode Moe = Auto
Other>Video Convert = On
Set this for sources (devices) you have connected to the hdmi.
Posted on Sep 04, 2009
Only HDMI Video works. All other inputs/components have sound but no video
Some receivers have settings to switch the video circuits off when other parts are used. You will have to look around the manual to see if the video settings can be switched off.
Jan 24, 2016 | Audio Players & Recorders
Problem? * The signal from componenant input,RGB,@ 1080i + 720p,doesn't work at all when outputting at component output or HDMI. 100% failure.
you cant record an hd picture and sound through component input rgb,for 1 you arent inputting hd,you are inputting analog,you cant up convert,
Apr 16, 2015 | Televison & Video
Connecting a sony dvp-sr500h dvd player to sanyo tv. using the red, yellow, white cables that came with the sony player get me no picture, no sound. do I need additional cables? the menu on the tv screen...
Here is the quick start guide
https://docs.sony.com/release//DVPSR500H_qs_EN_FR_ES.pdf
You seem to be using the Video & Audio connection. Start at the Player. Connect cables to YELLOW Video, RED Right Audio WHITE Left Audio Then go to TV and find the YELLOW input RED input and WHITE input. On some TV's they are separate, some combine them with the COMPONENT inputs (Component is 5 cables you will use 3 of them if you only have COMPONENT inputs)
Some TV's have an input button on the remote but no on screen selection. Try pressing the input repeatedly to access the other inputs. Lastly you will not get upscaling if you are using the 3 cable hook-up. To get upscaling use an HDMI cable to connect. Be sure to not have both types of cables plugged in at the same time HDMI by itself is best. If you reply with the modelof the sanyo TV I'll try to get you more info.
Jan 05, 2018 | Cyberhome CH-DVD 300 DVD Player
My HDMI ports went out. Everything else works. Can I repair the HDMI ports myself?
Yes you can replace the HDMI ports yourself following the replacement guidelines of the manufacturer, remember to use the same part that was in the first piece of equipment
Nov 30, 2009 | Samsung 61" 1080p Slim-Depth DLP HDTV
I have a JVC LT-37X776, I have bought a blu ray player and it does not seem to recognise it on HDMI channel works through component but kind of defeats the point of buying a hd players if you are not...
go back to the shop wher u got ur HDMI cable and find out if this is the right one for ur player and tv......
not all cables are the same......even they look like it and work on different components
Nov 20, 2009 | Televison & Video
My player seems not able to upscale the signal from my antennea and DVDs
Upscaling will only occur when playing DVDs. You have to use an HDMI connection from the DVD player to the tv. For upscaling of DVD's you will also have to setup the upscaling resolution in the DVD player's setup menu. Be sure to set the resolution to one that your tv will support.
If your tv does not have a HDMI input, then you will not be able to use the upscaling feature.
Upscaling will not occur on antenna signals. This is not possible because the hardware (inside DVD player) is only meant to upscale DVD video.
Again, to upscale DVDs ONLY, you will have to have an HDMI cable going from DVD player to TV, set up your upscaling options on your DVD setup menu and have a TV that has a HDMI input and is capable of recieving the upscaled resolution you have set your DVD player to.
If you have any further question regarding this, let me know!
Oct 07, 2009 | Samsung DVD-VR375 DVD Recorder/VCR
I am having trouble hooking up my xbox through my denon avr 688. I can get audio but no video. Help me, please.
Are you using an hdmi or a component vid from the xbox to the avr? and a hdmi from the avr to the tv? Some receivers only pass through not upscale the video. My xbox uses the component vid out to my avr so I have to also use component to my tv from my avr.
Aug 19, 2009 | Audio Players & Recorders
Upscale from 480p Signal via HDMI
ok the problem might not be with your receiver it is with your direct tv settings. Double check to make sure you go to the format and set it up to be fixed or 1080i whichever will give you the highest resolution. Check your manual for the direct tv receiver. If this is all correct for the DTV then you must go into the setup on the receiver and at hardware icon toward bottom check on that box, now goto the hdmi settings and make sure it is set to through. this will allow the best picture with no upscaling which will degregade picture for blu ray. so your direct tv will be only 1080i but very impressive. if you still want to upscale you can then you have to change the hdmi settings from before to upscale 1080p . I just hope that your dtv can output 1080i it will give a better picture than 480p even if both are upscaled to 1080p
Oh i forgot to ask if you are connected through hdmi to the tv. Hdmi is the only option for upscaling
Feb 21, 2009 | Onkyo TX-SR606 Receiver
No component output on AVR-4306
This does not work... You can only upscale the video signal with 4306; meaning you can covert s-video, component video to HDMI but can not down-convert HDMI input (coming from your HD DVD player) to Component video output. Sorry that I could not give you a solution as this is the 4306's limitation (written on the 4306 manual.).
Nov 21, 2008 | Denon AVR-4306 Receiver
No video
I am not sure if you have gone into the Receivers Menu or not? If you have NOT! Then please try this: Go into the Receivers Menu (If you do not see the MENU on the TV you can hook up a Composite (Yellow) Cable from the Receivers Monitor Out (Yellow) and select the Input on the TV that you plug into) Look in the Menu for Inputs or In/Out Config. or Video Setup. Look for the Input that you are using for that Device. Change the Video setting to HDMI. I also recommend doing this for you Audio as well. Find the Audio Inputs and MATCH each Input to there DEVICE and CABLE (Connection) Being used. Also check in the Receiver Menu for UPSCALE or UPSCALER. Turn this on or off to see if your TV is Compatible! Hope This Helps! P.S. Check the Manual for Upscaling Capabilities NOT all Receivers upscale and route the SAME!
Jan 12, 2008 | Yamaha RX-V861 Receiver
Denon AVR-4308CI Receiver Logo
578 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
