Question about Alba Televison & Video
No disc fault.
Alba video cassette recorder/DVD player Model No.DVCR3X1 DCA2311P-NK. When a disc is inserted the screen said:- loading, The disc makes two very short spins. then comes up:-no disc. and sits there.
Not many discs have been put through the unit. Can you help?
  • 2 more comments
  • john_corri Jan 04, 2009
    I have used a lens cleaning disc to no avail.
    The disc only rotates about a quarter turn twice and then stops. I spun it by hand and still nothing.
    No help on this sitehttp://www.gadgetspeak.com/gadget/articl...
    The disc is pre recorded. No disc will work.
  • john_corri Jan 05, 2009
    Thanks for the help.
    President:
  • 1,952 Answers
. Open cd door and push the front that says "dvdr recorder"upwards to get it off.
2. Remove the top cover 9 torx screws and lift the top off.
3. remove 4 torx screws on the cdplayer gently loosen the wide cable and a power connector, it should now be possible to remove the player and turn it upside down.
4 Locate the white plastic cablebracket that locted just under the lasertrollys travel
and gently remove the bracket and turn it so that the side that was facing downwards now points up. notice that the thin side was facing up and made the lasertrollys movement to be hooked on the cablebracket.
5. If you want to feel the problem you can remove the fan and cd holder on the other side off cdplayer this to gain access to the lasertrollys full travel an you should be able to feel when the trolley hooks on the cablebracket.
Posted on Jan 04, 2009
  • mohammed marika thambi
    mohammed marika thambi Jan 04, 2009
    Take a swiffer duster, and shove it in the unit. Then pull it back out.
    Thats exactly what I did to mine, and it started to work again. Not
    even kidding.
    Genius:
  • 3,422 Answers
see if the player tries to read the disc. Load a disc and listen.
Does the player make squealing noises or is it totally quiet? Squealing noises may indicate that the player is trying to synchronize with the disc but can't due to an obstruction on the lens or in the laser path inside the pickup or a defect in the pickup. This can also be caused by an intermittent signal problem due to a faulty ribbon cable.
Totally silent means that the photo sensor is not getting any usable input from the laser at all, meaning that the pickup is blind for lack of a better word.
This can be caused by an obstruction of the beam by foreign matter on the lens or inside the pickup all the way to a marginal or failed laser diode and/or photosensor array. This can also be caused by a bad ribbon cable with one or more severed traces.
You could try to clean the optics. This is the most common malfunction as far as i know in all disc players. It would involve taking the cover off and finding a way to expose the lense, and then cleaning it with a very gentle brush. some players have a cover for the lense that swings to the side during playing, this greatly reduces the chance of dust accumulating but it is still better to give it a try.
If you see dust on the lense, then its just that simple. clean, close, play.
check on the small shafting that guides the carriage of the laser pickup. Dirt, grome, dust and solidified lubricant can cause stoppage of the carriage and the laser eye then fails to read the next track.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Offhand as the others have posted, a probable weak/faulty laser/optics if cleaning does not correct the issue. Alternately, it could be tried that the bias be adjusted to "squeeze in some more usable time" overdriving the laser or a general cleaning of the inside be conducted with re-application of appropriate lubricant in the mechanism.
While technically the DVD assembly is replaceable/repairable and parts are still available, the cost of repairs and downtime would have to be factored in, then you may have to re-evaluate your options and consider a replacement. Not unless it is still under warranty. Sorry to be the one bringing you the bad news.
Good luck and Thank you for using FixYa.
  • Alba Master
  • 19,396 Answers
If the disk makes two very short spins, and you hear it clicking, but it does not read, then it is a lens problem.
First try using a dvd cleaner disk.
When a cleaner DVD is not enough, the lens must be accessed direcly and cleaned.
Some choice of cleaning products here.
  • 1,879 Answers
Lens dead.
replacement needed. ask local electronics repair shop to identify the part then decide if you want to DIY the replacement.
or
might want to consider getting a new one (compare repair cost vs. new player)
    Brigadier General:
  • 5,158 Answers
Is it a blank disc or pre recorded ? you need to check that the format of the disc is one that is supported by your player
    Brigadier General:
  • 8,619 Answers
Hi
try this link first
http://www.gadgetspeak.com/gadget/article.rhtm/751/238039/article.html
If it does not work then you can use a lens cleaner dvd .
Thankyou
Posted on Jan 03, 2009
    President:
  • 2,110 Answers
Okay,Your DVD player lens have to be cleaned by lens cleaner CD...
    Sergeant:
    Novelist:
  • 326 Answers
This could be due to weak ,faulty or dirty lens.
  • technodeal Jan 03, 2009
    use a lens cleaning disc which will clean off the lens if its dirty and will solve the problem if it is due to dirty lens.otherwise u will hve to get the lens replaced to fix the problem.
When inserting vhs tape, the player pulls the tape from inserted vhs
That is exactly what a typical M-Load mechanism is supposed to do. Once the VHS tape cassette is inserted, cassette housing cover will be flipped up and two arms will pull tape out of cassette housing to wrap tape around cylindrical spinning head housing that contains video heads and, if VHS HI-FI, audio heads as well. When stop or eject button is pressed, arms will retract and tape will wind back into cassette housing. What type of problem are you experiencing with unit? It may have nothing to do with M-load engaging tape around head cylinder.
Mar 22, 2014 | Samsung DVD-VR325 DVD Recorder/VCR
OLD AUDIO TAPE TRANSFER TO DVD FORMAT
May i please know the model and the make of the product in details so that it can help me resolving the issue is a more prompt manner
Apr 24, 2008 | Audio Players & Recorders
How can I record a music cassette to a music disc on my Magnavox DVD recorder/ VHS --Model # ZV427MG9
You can't burn a CD-A with the ZV427MG9. The unit will not burn to a CD to play in a CD player.
You may be able to record the audio to a DVD with no video source. Connect your cassette player to the Line In audio ports (L/R) at either the back or front of the unit. Depending on your cassette player, you may need a 3.5 mm M to RCA F/F adapter to connect the RCA audio cable to the cassette player's headphone jack. Do not connect a cable to the video input of the composite input unless you have a video on a camera or something to play back. This means that the recorded video may say "No Signal" or will be black or static. (Note: this may not work with this signal issue.)
Set the unit to record to DVD on L1 or L2, as needed, by pressing Source on your remote. Advance the cassette to where you want to record. Press Rec on the DVD unit and then press Play on your cassette player. If you want to identify tracks, Stop the recording and play back and then press Rec and Play again. You are at risk of having issues with the volume during the recording. Clipping of overly-loud sounds and distortion is possible.
When done, finalize the disc, if desired, to play the disc on other DVD players.
If you want to make an audio CD, you would be better off using a computer and connecting the cassette player to the Line In jack of the computer. You do have to make some adjustments to avoid recording the default Microphone input. Use a program like Audacity or any other audio editing program. Record the signal and divide it into tracks, if needed. Now you can filter out any distortion as well. Then save as a WAV file. Use a different program to burn the WAV files to a CD-A. (This must be burned as a mastered disc; my attempts that worked on an older CD player failed if there were gaps between the tracks. Lots of programs will do this; Roxio Creator is one option.)
The manual for the ZV427MG9 is available here: http://download.p4c.philips.com/files/z/zv427mg9_f7/zv427mg9_f7_dfu_aen.pdf .
I hope this helps.
Dec 31, 2012 | Magnavox Televison & Video
I have a JVC DVD Player (XV-N670B), (XV-N672S). I recently purchased a BluRay DVD and after inserting the DVD into the player, "Disc Error" appears. Would you tell me if my player can...
Sorry to say, no; this is a model limitation not a fault as such. XV-N670B is a DVD player, and the playable formats are:
DVD-Video, DVD-RW/-R, +RW/+R, CD, CD-R/RW, SVCD/VCD, WMA/MP3/JPEG, DivX. No Blu-ray support.
The JVC XV-BP11 and XV-BP1 do play Blu-Ray discs, as they are specifically Blu-Ray players (according to the JVC website).
I have heard of quite a few Blu-Ray players allowing DVD playback. The XV-BP1 supports the following playable media: BD-R/RE (Blu-Ray), DVD-Video/-R/-RW, R/ RW, CD, USB (again, this is from the same JVC website). You would need to purchase this or a similar Blu-Ray player to enjoy the benefits it has to offer (but it's up to you if you want one of those later on).
DVDs are still good, the 'disc error' message on your DVD player is normal due to the wrong media format inserted. The bonus here is it didn't cost you anything to ask, and you don't need a workshop quote on repairs.
This is the best free advice I can offer.
Mar 07, 2011 | JVC Televison & Video
I have a Toshiba DVD Video Player Model SD 260. I
Hello, The problem could be dirt on the surface of the lens, you can clean this by removing the cover of the dvd player . Gently use a dry cotton bud to clean the lens because the lens is fragile. Insert the disc plate into the dvd player and press play, if it does not play try the second method. Ensure the cover of the player is open, connect the power plug to the mains socket and observe the lens if it beam a red light, Also check the ribbon cable use to connect the lens to the printed circuit board, then gently clean the lens with a dry cotton bud , insert the disc plate and press play to see if it play. If it does not play the disc, then this require a change of the lens
May 20, 2010 | Televison & Video
Alba DVD recorder won't recognise any discs
The Alba DVD recorder may not recognise any disc due to one or two of the following reason.
1, the optical pick up (lence) may be dirty or may have gone bad.
2, the cable which connects the optical pick up to the circult panel board may have go borken.
Jan 04, 2009 | Televison & Video
Dvd player/video cassette recorder
Assuming your dvd player supports your dvd+r format. You might need to make your dvd player multi-region or remove the region setting all together.
this website have unlock codes for dvd players
http://www.dvdexploder.com/
Those cheap made in china $35 dvd players have no region setting and will play virtually anything.
Feb 23, 2008 | Televison & Video
JVC DVD Player/Video Cassette Recorder Model HR-XV2EK
try to clean your machine by playing a lens cleaner disc coz the lens might be dirt enough not to pick on data from the discs you play. if it does not work then isuggest you change the lens coz it might be weak
Aug 01, 2007 | JVC DR-MV1S DVD Recorder/VCR
Televison & Video Logo
44 people viewed this question
Top Alba Televison & Video Experts
Rod
Rod
Robert Crombie
Robert Crombie
Level 1 Expert
Are you an Alba Televison and Video Expert? Answer questions, earn points and help others
