I have a Kenwood kr-v8010 and all a suddenly one channel is only working just woundering if its a easy fix?
  • Ian Bradley
    Ian Bradley Mar 08, 2013
    I have a Kenwood kr-v8010 and how do i get both a and b channel to work and my surround speakers i have no manual
    Novelist:
    Champion:
  • 225 Answers
Could be a speaker wiring issue, defective speaker or possibly a speaker protection fuse inside the unit has blown.
1. Check speaker wires for proper connection.
2. Swap left and right speakers to see if the problem follows the speaker.
3. Check for internal speaker fuse that may have blown. PLEASE proceed with caution inside the unit. With the AC cord unplugged there are still high voltages resident inside...BE CAREFUL!!
Posted on Nov 02, 2012
  • 17 Answers
SOURCE: Kenwood Receiver KR-V127R - left channel not working
Select an input that is not connected, for example select CD with no cables going to the CD input on the backside. Will you then hear equal humming on both channels? If so, the amp stage is ok,
and the problem lies in the signal level circuitry.
Open the cover and use a plastic (insulated) stick to touch suspectible cables and components. When the sound returns, you've found the cause. Resolder or reseat the component/cable/card.
Use the insulated stick, NOT your fingers!
Posted on Jan 01, 2008
  • 319 Answers
SOURCE: problem with playing my Kenwood KR-X1000
Unit apparently has problems. Check/replace batteries in remocom
Posted on Aug 14, 2008
SOURCE: I want to find out
I have the same receiver. When I asked the same question at a stereo store about 12 years ago, I was told it was listed at 55 watts/channel.
Posted on Mar 14, 2010
  • 222 Answers
SOURCE: kenwood kr 3600 volume potentiometer is faulty
try google and it will give you some local electonic stores
Posted on Jun 08, 2010
dunnbiker
  • 8546 Answers
SOURCE: kenwood kr-v888d after "ON", through 3sec.
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
Posted on May 18, 2011
One channel has no bass. what should I check first under the cover
No bass like speaker isnt working? If so first thing a would try is switching speakers...If it fixes that channel then its your speaker.
Mar 23, 2016 | Kenwood KR-V7080 Receiver
Whats is wrong when reciever kenwood kr v8010 doesn't torn on?
Power supply section circuit should be checked. Start with AC cord, Fuse, Diodes, Output components etc:
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Aug 11, 2014 | Audio Players & Recorders
Avr kenwood kr v5090
Have you tried the "Simulated" surround setting?
If you don't get sound in "Simulated" mode then you have probably lost the surround channels.
If you do get sound then your "Media"
is not recorded with a surround "Track". or the surround "Processor" may have issues that need to go to the repair shop.
Mar 25, 2014 | Audio Players & Recorders
Did I fry my Kenwood receiver with excessive input?
It is very possible that you lost a channel and the uit is in protect.
Apr 10, 2012 | Kenwood Audio Players & Recorders
Can the Kenwood KR-4600 connect to an ipod?
Hi,yes you can connect Kenwood KR-4600 to an ipod.
Instruction..
You will need an coolken_9.jpgRCA cable .
Connect the RCA (red and black to the input of the Kenwood KR-4600...You have options of inputs to use..
Either input at the back of the Kenwood KR-4600,or tape A and tape B..which ever you wan to use..
After connecting the red and black RCA to Kenwood KR-4600, then connect the other jack end to the ipod, and go the front of the Kenwood KR-4600 to activate the input selection knob to the desired input being selected at the back of the Kenwood KR-4600..
And don't forget to turn on the volume of the Kenwood KR-4600 and also the iPod volume..
And after that your done..
Good luck to you..
Aug 10, 2011 | Kenwood Audio Players & Recorders
Kenwood kr-v6030 master volume wont go down
To zyclon3, I've got a KR-V6030 that the volume knob some how got broke and had to take the receiver apart and get the knob out and play with it with the remote untill I got control. but I have to becareful cause it will go full blast if I'm not carefull going down in volume have to be especialy carefull since theres no stop.
Mar 08, 2010 | Kenwood Audio Players & Recorders
My kenwood amplifier suddenly off when i turn the volume high?
You need to make sure you ohms are correct if there too low this will happen to protect the amp.
Dec 03, 2008 | Kenwood KR-V7080 Receiver
Dec 31, 2007 | Audio Players & Recorders
Problem with playing my Kenwood KR-X1000
Nov 19, 2007 | Kenwood KR-X1000
Standby mode, shuts off
After 10 years of use probably best to replace with a new unit. Most will be hard to find exactly wich little bit is broke.
May 23, 2017 | Kenwood KR-A5080 Receiver
119 people viewed this question
 Grubhead
Grubhead
