Question about Miele Washing Machines
Miele novotronic w502 check drain check inlet lights flashing
  • 183 Answers
SOURCE: The washing machine wont start
This indicates either a faulty inlet valve, afaulty pump or a blocked filter Regards Engineer
Posted on Jul 30, 2007
SOURCE: miele novotronic w/m fault light flashing
We had the same problem on a Premier 500 and solved it by tilting the machine forward. Some more water ran out and the lights went off.
Posted on Jan 05, 2008
Mark Harmer
  • 8 Answers
SOURCE: Inlet blockage red light flashing
Try turning the machine on its side, undo the bottom and check that the polystyrene float (attached to a switch) is not somehow jammed. This float cuts off the water if the machine leaks internally, and produces the symptoms you describe. It's a really good machine so don't throw it away!!
If that still doesn't help then it might also be the motor brushes, which produce similar symptoms - if your machine starts to fill but then flashes and just drains again, it's almost certainly the brushes. This might be the case after you check the float problem.
Posted on Sep 21, 2009
odiebugs
  • 949 Answers
SOURCE: the check inlet light flashes. I have cleaned the
If your sure the water way is clear, unplug the unit, plug it back in,
and see if the error is gone, if not, place the water lines into the tub and turn on the water to make sure water is coming into unit, if so the problem lies somewhere else.
Re-post if this didn't help, and say you did this but still have the error.
Good luck, hope it helps.
Posted on Feb 05, 2010
  • 70 Answers
SOURCE: What do you do if the Miele washing machine's
The flood protection device has activated. This is caused by a leak in the machine. It can also be caused if you are not careful when checking the drain pump,water may have gone back into appliance and activated flood protection device. If this is the case Tip machine forward,water in base of appliance will run out, and appliance will work.
Posted on Mar 29, 2010
I have a Miele Novotronic W 828 the check inlet red light is flashing - what do I do?
Hi dear. Seems to me your machine needs new inlet valve replacement.Due to it's age, it's quite normal. Thanks.
Jan 26, 2016 | Miele Washing Machines
Miele Novotronic 500, 10 years old, noisy filling, no error light, inlet filters clean. Any suggestions please?
Hi dear,
As I know it's a indication on inlet valves going to fail. I hope that helps. Thanks.
Jan 21, 2016 | Miele Washing Machines
Miele novotronic w145 s spullen light flashes
Possible that this error can be due to the INLET or the DRAIN being clogged or is not functioning. Remove and clean the filter to both the inlet and drain.
Jan 19, 2013 | Miele Washing Machines
Have miele dishwasher g641 inlet/outlet light flashing the water is going in and is draining starts flashing about 5/10 mins after starting do you know what else to try many thanks janet
Just encountered exact same problem - happened after attempting to clean very greasy pans so grease/oil created foam/more or less solid material in filter area, but as well in pressure switch (pn 4859640)
This seems to be the cause (not sure yet)
Mar 07, 2011 | Miele 24 in. Novotronic G641 Plus Built-In...
Inlet/outlet light keeps flashing on G641 dishwasher - have checked filter and cleared debris. Just completed a wash but dishes not washed or rinsed adequately. Anything else I can check before requesting...
hi,
this is a general fault light which could mean anything without a Miele Technician coming out and connecting a
laptop to the unit. However most common faults with dishwashers is a drain fault. Check for any kinked hoses and check the drain spigot under the sink where the drain hose connects into the u bend. Usually this is where food gets trapped due to the spigot not being drilled out large enough. This then causes a blockage. Also check the non return valve under the filter and make sure the drain pump can turn freely. See what part of the cycle the unit lights up the fault. If it happens at the very start it is the drain. If it drains ok then fails it is the inlet. If it fails after that it could be any number of things.
Hope this helps.
Jan 26, 2010 | Miele 24 in. Novotronic G641 Plus Built-In...
Sep 05, 2009 | Miele Novotronic Premier 500 Front Load...
Miele Novotronic.
all miele are supplied with schematics. on washers take the top off and its on top of dispenser tray. if not there remove front panel it will be there
Feb 11, 2008 | Miele Novotronic Premier 500 Front Load...
Washing Machines Logo
349 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
