Battery My battery on my lap top seems to drain very fast, even after a complete charge.. What can i do to cure this?? Thanks.
    Scholar:
  • 107 Answers
Get a new battery. The life span of a laptop battery is typically only 1-2 years. Check to see if it's still under warranty.
Posted on Jan 03, 2009
Only screen is the garmin logo with the battery charge icon. When power button is pressed another icon appears for 20s: a picture of the garmin unit linked to a charger then back to the first screen.
Don't know if this will help but it might be worth trying, especially if you just did a software update. I have a 520 and it gets frequent software updates. After an update it ends up just showing the Garmin screen and seems to be bricked because nothing else works - even the off button doesn't work. The solution is to just let it sit showing the Garmin screen for five or ten minutes so it can process and load the new software which seems to take a long time. It eventually opens onto the main screen.
Oct 07, 2016 | Garmin EDGE 705
E-machine laptop start up trouble
the battery will need to be optimized, make sure you have the power cord in and start the machine, once the battery is fully charged drain the battery completely. repeat this process 3-4 times
May 10, 2014 | E-Machines Computers & Internet
Battery will not charge connection seems loose
your battery charger is bad theres bad cell in it what happens is when pluged to long it makes the cells weaker the longer it sets on your lap top wile your lap top charged.
Feb 15, 2011 | Computers & Internet
My lap top wont turn on i have a blankj screen the
Please try these. After on your pwoer botton wait 2 minites and the press FN+F6.
Let me know what happening.
Thanks.
Jan 30, 2010 | Acer Aspire 6920 Notebook PC
¿ tiempo de carga de la bateria en lap top por primera vez?
Sorry, espanol no hablo
You must let the battery cargar completemente maybe 4 o 5 horas if you are not using the computer (OFF) , and 12 a 13 horas if computer is ON. Don't leave it charged in the computer while computer is connected to the power socket, unless you also charging the battery.
Before charging it a second time, make sure it is completely drained. Some manufacturers (Toshiba) recommend to cycle the battery (charge, discharge) 2 or 3 times before using it.
Every month you should allow it to be drained.
Tu dois laisser la batterie se charger complètement. Cela prendra 4 à 5 heures si l'ordinateur est éteint, et 12 à 13 heures si l'ordinateur est en marche. Ne laisse pas la batterie dans l'ordinateur s'il est connecté à la prise, sauf si la batterie est en train d'être chargée. Certains constructeurs (Toshiba) recommandent de faire subir à la batterie 2 ou 3 cycles charge-décharge avant de pouvoir l'utiliser de façon autonome.
Chaque mois tu dois la laisser se décharger complètement.
Hope it helps.
Aug 31, 2009 | HP Compaq Presario V2000 Notebook
What is the implication when swopping the motherboard of a acer l
Hello. Although this should cure the problem, there may be an issue with the battery connector within the laptop, causiong the battery not to charge. You have to perform more diagnostics on your unit before replacing the expensive motherboard. With a charged battery does the unit work? If no, then the problem could be a bad battery connector on the motherboard, or the foil-pattern connections around the battery connector terminals. Sometimes the damage is just around the battery connector terminals that connect it to the rest of the circuitry on the motherboard. I this case the cure could be a simple rewiring of these terminals to bypass the broken circuit board areas, costing you a few mere dollars, a little spare wire and time, or you may need to have this professionally performed if you're unable to do so. Most battery packs can have between 2-8 connections. If any of them get broken or stop working, different things can surface. I'd have someone look into this unit more indepth to correctly identify the problem, unless of course, you can find yourself another working motherboard really cheap. Good luck.
Apr 03, 2009 | Computers & Internet
Lap works but the battery does not charge
oh
maybe your power IC is broken
or something about your power connection
you said The lap top is less than 12 months old,
it's mean it still has it's warranty
if you lost your warranty card
don't afraid
if seal(s) above your laptop is not broken
you still have your warranty
Jan 22, 2009 | Toshiba Satellite A100-S8111TD Notebook
Digital camcorder problem
there a short line to the carbon wire of the function switch.....unfold the wire to loose the fold....and clean the contact of the wire using a pencil eraser slowly
Oct 14, 2006 | Sony Handycam DCR-HC40 Mini DV Digital...
Computers & Internet Logo
54 people viewed this question
David Payne
David Payne
