Question about 2wire HomePortal 100 Network Adapter
Need password for 2wire network
Trying to setup Tivo and need the password to my 2wire network but I don't know what it is. It's not the default because I tried that. How can I find out what it is?
  • Anonymous Mar 29, 2009
    can i connect to a proctected network?
    Problem Solver:
  • 13 Answers
The best solution is to reset the router. The easiest way to do this is to find the reset button, usually on the back of the router there is a pin hole button. Use a pin or pencil to push the button.
Be warned, any special settings will be lost, but most installations of home network routers such as the 2Wire Router/Gateway is the default settings. If you have other than the default settings, then contact the person/organization that set up the 2Wire for you, such as your ISP/Internet provider.
Posted on Jan 04, 2009
How do I reset a 2Wire HomePortal to factory default on a used device?
Hold the reset in the back till it cycles. Don't see the default listed for this model, but should be easy to figure out.
http://portforward.com/default_username_password/2wire.htm
Dec 12, 2012 | 2wire HomePortal 1000HG DSL Modem and...
Just bought a new kindle to access the a network i need a password for 2WIRE 726 how do i gain access to a password
First off is the wireless network "2WIRE 726" owned by you or someone you know? If yes ask the owner for the password, if no, then short of doing something illegal then you can't get on that network unless you get permission and the password from the owner.
Your best course of action at this point would be to setup your own network and connect to that.
An alternative would be to go to a public location (Starbucks, McDonalds a library and connect to their free wireless and download some books considering you only need a connection to download the books and not to read them)
Comment if you need additional assistance.
Aug 04, 2011 | 2wire 2700HG-B Router (2700HGB)
What is the default wifi password for my 2wire 2700HGV-B2 modem?
2wire wireless network key
The network key is located at the side of the router you will see a barcode on it. It indicated the wireless network key.
If you have questions please let me know. Thanks
Jul 05, 2011 | 2wire 2700HG-B Router (2700HGB)
Where is the wifi password for my 2wire wireless router. trying to connect my iphone 3g for faster internet
the default wireless passowrd or network key is located at the bottom left of the 2wire router. You will find a sticker that indicates the Serial Number, System Password and Wireless Network Key. The Wireless Network Password is is the 10 Digit Code located under the S/N.
If in any case you want to personalize the Wireless Network Key. You can access the gateway by opening a browser the type 192.168.1.254 it will ask you for a password use the System Password on the sticker. Click on Home Network then Click on Wireless Settings. You can also change the Network Name or SSID, The Authentication and the Wireless Network Key
Thanks for using Fixya
Jul 29, 2010 | 2wire 2700HG-B Router (2700HGB)
Roomate controlling wireless router...gateway.2wire.net no one can get any work done he controlls all speeds and so forth please help
You can adjust settings by going into 2Wire Router using your internet browser..
Default IP Address on 2Wire Routers: http://home/ This will take you to manager tools
Default Username / UserID on 2Wire Routers: None
Default Password on 2Wire Routers: Wireless
Default Netmask on 2Wire Routers: 255.255.255.0
If you can’t access management tools because of logon or password, you can reset to above
By following these directions
Apr 29, 2010 | Computers & Internet
I have reached the point in setting up ROKU where I am advised on screen to "enter your security info". Where can I find that on the AT&T 2wire modem?
I believe that you have setup WEP/WPA encryption key to network, please contact your service provider to know the security key.
Regards
Rizwan
Jan 27, 2010 | Computers & Internet
Where to find password to join wireless network?
Hope this helps
Chris (ziraffa)
Jan 11, 2009 | 2wire HomePortal 100W (1000-400026-000)...
Switch from WEP to WPA wireless protocol
First have a computer directly plugged into the 2wire
Using windows xp: click on start> then run> then type "cmd" and hit enter.
Type "ipconfig" and hit enter.
You are looking for a default gateway address, usually "192.168.1.254" on 2wire gateways.
Skip the vista section if you are using xp
Using Windows Vista: click start> then click on the search bar and type "cmd" and hit enter.
Once you find the gateway address, you now have the website address you need to get to your 2wire. Open internet explorer and type that default gateway address in the address bar.
This should take you to a 2wire homepage. At the top click on the "home network" or "local network" tab at the top.
Once there, click on the wireless network link at the top. It will prompt for a password, if you do not know the password, click I forgot for a hint. Click I still cannot remember if the hint doesn't help, it will ask for a system key, which is a 10-digit number on the bottom of the 2wire.
After entering the password you will be in the wireless settings window where you can change the security type to any available that the 2wire has, if it doesn't have it available call the provider and see if they have a firmware upgrade available.
Nov 13, 2008 | Gateway Wireless-B Router (wbr-100)
DWA 552 and 2WIRE HP1000
you dont have router protected (is not yours anymore).to gain control again, you can rest config. but you need your router manual nerby, to help you config. a previous internet provider config. and so on. to reset router config, you press a reset button on the back, until the lights is off/red. then config the router on the router website( writen on botton with default user and passw.(user: admin passw: admin or password) the wan config, Wlan,...
(Use a wpa2/wep encrption level on Wlan config.)
Note: change all router passw every 30 days, or less if necessary.
Jul 24, 2008 | 2wire HomePortal 100W (1000-400026-000)...
The password key
usually by using its IP address.
you will need to use a computer that is already connected to the router (internet)
open up internet explorer (or other browser) and in the address bar try the following:
http://192.168.1.1
http://192.168.0.1
http://192.168.2.1
http://172.16.1.1
http://172.16.0.1
http://172.16.2.1
also, i see someone recommends trying
http://192.168.1.254
it will ask your for a username and password which, unless changed during setup will be the router's default such as
admin/admin
admin/1234
etc
both the router's default IP address and default username and password will be in the instruction manual
Jan 27, 2008 | 2wire (1000-400108-001) Router
Computers & Internet Logo
1,099 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
