Question about Bell SH50102 Remote Control
Remote codes I have a bell espressvu 6100 remote and trying to program it to turn my tv off HP PL4200N but cannot find a code nor can the remote's own auto code finder can you help?
  • 24 Answers
1 - Hold the clear tv buttom until all 4 light flash red
2- Press the red tv buttom
3- Press the amount of time needed on the up cursor ( around select buttom) until your tv shut down
4-When the tv goes off press the search buttom ( at the end on the right side )
5-Press record
Then u can use the red tv buttom to control ur tv and u can control the volume on satelitte mode without going back to tv mode , if u press too much time while searching the code and the tv wont light back , do the same thing but instead pressing the up cursor press the down one to go back on the code it will be faster .
Posted on Feb 25, 2009
Use 652 as a code.
Posted on Jan 08, 2010
2 Suggested Answers
  • 29 Answers
SOURCE: program bell remote to emerson tv
Hi try this
Emerson 526, 534, 536, 541, 573, 590,
627, 636, 642, 648, 652, 654,
655, 657, 658, 659, 660, 661,
662, 665, 666, 667, 669, 670,
677, 679, 682, 692, 696, 699,
720
http://www.bell.ca/web/tv/en/all_regions/pdfs/deviceCodes.pdf
good luck please rate
Posted on Dec 18, 2009
I have RCA RLDED5099 Tv, but can't program it to work with my Bell satellite remote so I can then work My JVC THA35 home theatre..
Bell Satellite remote codes for RCA TVs: : 001,005,006,008,012,014,015,018,023,
025,035,066,077,085,121,124,131,133,135,
144,148,150,151,152,155,160,167,190,194,
222,223,225,227,232,236,245,248,268,269,
282,288,289,317,431,486, 492
Instructions for when the code for your device is not listed. Use this procedure to scan the remote control’s memory for the device code
1. Turn the device on (TV).
2. Press and hold the mode button until all the other mode buttons light up, and then let go of the button. The mode button flashes.
3. Press POWER.
4. Press the UP or DOWN ARROW repeatedly until the device turns off.
5. Press POUND (#).
6 .Turn the device back on and try some other buttons to make sure they work
7. If necessary, repeat this procedure
How to program my Bell Satellite TV remote control
Apr 09, 2015 | RCA Televison & Video
Need the tv code for samsung ph t4254 to program my bell remote to my tv
The codes for Samsung TVs on a Bell remote are:
505, 506, 516, 523, 526, 566,
573, 612, 627, 647, 652, 653,
654, 655, 656, 658, 659, 664,
665, 667, 669, 670, 679, 680,
704, 717, 730, 738
Try each of the above codes in turn until you find the one which works best, i.e. controls most functions. This may be limited to contolling the power, volume and channel functions. I have also pasted the programming instructions for your remote below, in case you need them.
Regards,
BElectric.
Program your remote control to operate your TV
NOTE: Before you start, locate the remote codes for the TV and write them down.
Follow these steps to program your remote control to work with your TV:
  1. Press and hold the TV button on the remote until the SAT, VCR and AUX buttons light up.
  2. Let go of the TV button. It should start to flash.
  3. While the TV button is flashing, enter one of the 3-digit codes for the TV that you wrote down earlier.
  4. After entering the 3-digit code, press the # button on the remote. If the code was entered successfully, the TV light will flash 3 times.
  5. Try to control the TV's volume and power.
  6. If the remote did not control the TV, simply repeat steps 1 to 5 with another code from the list.
If you tried all the codes provided for the manufacturer, try the following steps to find another code.
  1. Make sure the TV is on.
  2. Press and hold the TV button on the remote until the SAT, TV and VCR buttons light up.
  3. Let go of the TV button. The TV button should start to flash.
  4. Press the Power button on the remote control. The TV button will stay lit.
  5. Press the up arrow on the remote every second until the TV turns off.
  6. When the TV turns off, press the # button on the remote to lock the code. If the scan was successful, the TV light will flash 3 times.
Your remote should now be programmed to work with your TV.
Nov 23, 2010 | Televison & Video
Program bell remote to emerson tv What codes do I use to program my bell satellite remote to be able to tun off/on tv and to use the volume from one remote
Hi try this
720
Dec 18, 2009 | Bell Televison & Video
Cannot program tv using bell satellite remote
Turn your TV on.
Press and hold the TV mode button until all the other mode buttons light up.
Press the blank POWER button. (If your remote only has one POWER button, press that one)
Press the UP ARROW button repeatedly until your TV turns off.
Press the POUND (#) button to confirm.
Cheers
Feb 01, 2009 | Hitachi 50FX30B 50" Rear Projection...
Need remote code for programming a bell expressvu receiver
Here for the Jensen remote just click below;
Here is link to the manual:
http://www.remotecodelist.com/remotes/jensen/JR300C.pdf
Here is some helpful information I found:
Without the code on JER-323:
1.Manually turn on the component you want the remote to control.
2. Press the device button, example:( TV) and the (power button) for 3 seconds until the (on/off button stays lit).
3. Once the (on/off) button is lit, press the (on/off) button until the unit (the TV or unit you are trying to control.) turns off.
4. When the code is located, press the (stop) button at the bottom to save the code.
Here are some codes I found for the Jensen 323:
GE VCR: 2000, 2013, 2021, 2022, 2053, 2087, 2089, 2091, 2115, 2120
Motorola Cable Box: 5000, 5003, 5046, 5047, 5052
Mitsubishi TV 0093, 0150, 0178, 0019
JVC VCR 0067, 0041, 0008
JVC DVD 0558, 0623
Hope it may help you;
Regards,
VOTIT
Jan 27, 2009 | Jensen 143307 Remote Control
Codes to program Innovage Products Jumbo Universtal Remote
I need the code for my rca tv so I can program the inovage jumbo universal remote Pleaseeeeeeeeeeeeeeee
Dec 31, 2007 | Televison & Video
Program bell expressvu remote for new tv
The easiest way is to do device code scan. Since you want to program the TV, hold the TV button on your bell expressvu remote. When all the top buttons light up, press the power button, the TV button light should remain lit. Keep pressing up/down until your TV turns off. When your TV turns off, press the # button. Thats all. Your done.
If you want to set up the AUX button, hold the AUX button until all the buttons light up. Then press * and either
0 - second TV
1 - second VCR/DVD player
2 - audio amplifier or cable box
Then press the power button and press up/down until the device turns off. The last step is to press # and your done.
Oct 22, 2007 | Televison & Video
Televison & Video Logo
1,980 people viewed this question
Top Bell Televison & Video Experts
bigdawg7299
Are you a Bell Televison and Video Expert? Answer questions, earn points and help others
