Question about Maytag PYE2300AY Electric Dryer
Maytag electric dryer won't start
Dryer worked, went to restart and it would not do anything. I can hear the timer still ticking, checked the fuse, the drum will turn manually. How do you check the door switch or what else can I try?
  • loripowers Jan 04, 2009
    ok, I took off the top and i have the back of the timer, the chime box, and three little 1x1 black boxes, and another black box that looks like the chime. Am I in the wrong place, I don't see anything round except the timer?
  • 163 Answers
Hi!!! You have a bad thermal fuse.easy to replace just lift up open the top cover of the dryer and the thermal fuze is in the back next to the heating element.Its round and black with 2 wire going into it its around half and inch thick next to the heating element ..Good luck..
Posted on Jan 03, 2009
Dryer will not run or heat
Could be the thermostat or element....Element should read around 32 ohms on multimeter..stat closed circuit.....Try to look for any overheat cut off at the back anywhere...
Apr 12, 2010 | Maytag PYE2300AY Electric Dryer
Maytag Performa Electric dryer. Went to put in load and start-would not turn on. Checked breaker first. Then listed and I could hear the timer clickin on the front panel.Front door panel was full of lint....
In-laws machine did exactly the same thing. Check the thermal fuse.
Turn off the breaker.
Pop the top open with a flat screwdriver (there are two clips at the front)
There are two white wires on the right-side of the burner element, this is the thermal fuse (wires are kinda awkward to remove)
I jumpered these to wires and it started right up.
Jan 25, 2010 | Maytag PYE2300AY Electric Dryer
My dryer was working just fine this morning and tonight we went to dry some clothes and it is doing nothing, I can hear the timer ticking so it is getting power, but it is not doing anything else.
I would ck the plastic door switch than ck the small white thermal fuse in back of dryer behind the large panel. You'll have to remove about 9 1/4 hex head screws to access.
Nov 10, 2009 | Whirlpool LER5636P Electric Dryer
Maytag dryer
you need to check the door switch and the main fuse inside the dryer on the blower box,let me know what you find-mike
Oct 29, 2008 | Dryers
Will not start; makes no noise
check the humidity sensor this will prevent the motor from starting
Sep 22, 2007 | Maytag PYE2300AY Electric Dryer
Maytag PYE2300AY Electric Dryer Logo
172 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
