Question about Brother Office Equipment & Supplies
Printing double exposure
I just replaced the toner and now everything I print has a shadow print down below the original print.
  • 5 Answers
SOURCE: "shadow" print on letterhead and envelopes
CLEAN YOUR DRUM WITH COTTON SWAB. (AND BLOW OUT PRINTER1.gif IF YOUR DARING.)
Posted on Feb 14, 2008
Mix-it-up
  • 832 Answers
SOURCE: Double prints or Text shadow printing by MFC 420CN
yes. you have to run the alignment feature. press ink - set - arrow-down til alignment. After alignment test print read the paper and choose the right setting by nr.
Posted on Apr 09, 2008
SOURCE: Hp color laserjet cp1215 is laying a shadow double
Press Menu button. Then press the <Left> scroll button and <Cancel> button simultaneously. This will take you to the secondory service menu. Press the menu button and select secondary service. Scroll through the menu item and you will see <Clean belt> option. Select it and press select again. This will clean the belt for you. Do it may be two or three times. This will solve your problem.
Posted on Aug 18, 2009
  • 159 Answers
SOURCE: Brother MFC-7420 just started printing a shadow image
Sounds like a bad drum cartridge. Pull the toner/drum cartridge out of the machine and set it down. Press down on a (blue?) tab to release the toner cartridge, and you can lift the toner cartridge out of the drum cartridge. There is a cleaning blade in there - a soft plastic blade that rides against the drum and scrapes off toner that didn't get transferred to the paper. If it gets stuck off the drum surface, images repeat a few inches (one drum circumference) down the page.
A new DR-350 drum unit should fix it. have the machine's power on when replacing it. While the door is open, touch the CLEAR key. The display will read "REPLACE DRUM?" or something like that. Press 1 for Yes.
Posted on Jan 07, 2010
SOURCE: My Dell 5110CN printer is printing a double image
I am having the same problem, and I am using the original toner cartridges that were supplied with the printer, so yes, they are genuine Dell toner cartridges.
Posted on Jan 31, 2010
Quilt y of print !, it gives double printing on page one is print of original doc.& second as its image what should i do to improve its print quilt y. i will be thank full to you
Dots, Lines, shadows and smudges on the printouts are due to dirty/ deteriorating cartridge and cleaning the green drum of the cartridge may help temporarily. Take out the cartridge and gently clean the roller/ green drum with a dry, soft, lint-free cloth wiping off the toner dots marks/ lines.
Also, make sure that the visible inside of the printer is clean and ther is no spilled toner inside, which sometimes results in dots. Double printing is also due to the deteriorating cartridge. The drum is not getting clean after its each rotation and hence the remaining toner/ image is transferred to the paper resulting in double printing. So, it is recommended that clean the drum etc (this would help temporarily). Also, make sure that the toner cartridge is in good working condition. If not you may replace the cartridge.
Let me know if any further clarification/ assistance is required.
GoodLuck!
Dont forget to appreciate the solution if I could have been of any help!
CreativeTECH
Jan 14, 2011 | Canon Image Runner 1630 Copier Copier
Jan 05, 2010 | Brother MFC 7420 All-In-One Laser Printer
Brother 4070CDW Shadowing Problem
Check your toner if they are properly installed.
Check your drum if they are properly installed.
Clearn your toner and drum.
Print a test page.
If nothing happens please replace your printer drum
Sep 19, 2009 | Brother HL-4070CDW Printer
Lexmark T630
If you are using the Postscript driver, switch to one of the PCL drivers. Either PCL or PCLXL.
If you are using PCL, switch to a different driver.
If all of the above fail, send me a Print to File so I can debug it.
(janddgasrepair@verizon.net)
Don
Apr 07, 2009 | Lexmark T630 Laser Printer
I get shadowing while printing.
The corona wire is incorparated in the toner cartridge. With this problem i would replace the cartridge.
May 22, 2008 | HP LaserJet 1020 Printer
HP 2420dn printing gray and shadows
maybe the scan unit need to clean first you most sure that the toner cartridge is original and new then start clean th scan unit reflector d9b88f3.jpg
Mar 12, 2008 | HP LaserJet 2420dn Printer
Brother all in one printer
Do you run a laser printer (you ve mentioned toner). If yes. plz post under your printer (e.g. HL-2040 etc.).
This is the ink jet forum!
Jan 10, 2008 | Brother Multi-Function Center MFC-240C...
Shadow/duplicate printing
in computer goto printer setting mode and uncheck option
toner saving mode and check out for dark or light effect
Jan 08, 2008 | Epson ACULASER CX11NF All-In-One Printer
Light Copy
first you press the exposure key and select the manual exposure mode then press and hold exposure key for 5 seconds when it blinks select the position to dark and press exposure key again,try to make the copy if no defrence ,select the photo mode and press and hold the exposure key again select the dark position by dark exposure key and press exposure key again.check the copy if again no difference change the DEVELOPER
Sep 14, 2007 | Kyocera RI-3530 Black and White Copier
Double print or a shadow print
Unfortunately your drum unit is shot. The mechanism that cleans excess toner from the drum surface is worn out or has developed a problem. The materials needed to repair are generally not available. If this is happening then the surface of the drum is probably near the end of its usable life anyway. Save yourself a lot of grief and aggravation. Bite the bullet and buy a new drum unit. Office Depot, Staples, etc. usually offer them at about $105.
May 02, 2007 | Brother IntelliFax-2820 Laser Fax
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
