Question about Health & Beauty
Go-Go Elite Traveller With the seven beep code. Replaced the speed and throttle controller. Still the seven beeps when turned on , shut it off and turn it back on and it will move untill you let off on the throttle controller and the beeps come back.
3 Suggested Answers
wcdoc1953
  • 280 Answers
SOURCE: I turn the key on get 10 fast beeps on my GO GO
The Pride Go Go Elite Traveller Plus HD 4 Wheel scooter problem you are describing with 10 fast beeps is that the scooter has "exceeded the push or roll away speed limit" (the scooter service manual is written by an engineer). The second symptom you describe is that you could get the scooter to drive by turning it off and on. By resetting the controller you were able to get the scooter to work for awhile.
This scooter has either an S drive controller or R series controller which has gone bad. By running the serial number you can call the manufacturer and identify which type. The part runs about $500 retail. It may be covered under warranty so it is advisable to call the manufacturer and run the SN first. Pride Mobility Products is at 1 800 800 8586. They can direct you to a local dealer for warranty repair.
While under the rear electronics shroud cover inspecting the controller check for burnt or melted wiring harnesses and connectors and replace those also. The rear cover has velcro attached inserts and well hidden screws that need to be removed first. An experienced tech can do the work in under an hour or you can save some money by doing the repair yourself. If I remember correctly all you need is 2 different size screwdrivers and an open end wrench for the nuts (all metric hardware).
Hope this helps.
Posted on Nov 26, 2010
wcdoc1953
  • 280 Answers
SOURCE: My pride go go elite traveler 4 wheel stops randomly often with no beeps. I have replaced the throttle, the speed pot, the brake, and the batteries check out fine.
You may have a loose connection at one of the harnesses or connectors. If there are no codes you may have a bad controller or loose connection at the controller. Slow speed problems may be motor or motor brush problems you can diagnose by visual inspection or a voltmeter. Load test the new batteries and the charger output. Block it up and run it checking and knocking all the components until it quits. I have seen a dragging brake caused by a melted controller harness at the controller connector cause a similar problem. Hope this helps.
Posted on Aug 18, 2012
I have a Pride 4 wheel Go Go Elite Traveller Scooter. It generally works fine, but I will frequently get an 8 beep error code and it won't go after a stop. I merely turn the key off and then
BEEP CODE CONDITION SOLUTION
2 Battery voltage is too low to operate Charge the batteries fully until charger and
the scooter. any meters indicate completion.
3 Battery voltage is too high to operate Contact your authorized Pride Provider for
the scooter. assistance.
5 Solenoid brake trip. The manual freewheel Remove the key, then push the manual
lever may be in the freewheel position. freewheel lever to the drive position and
restart the scooter.
6 Throttle trip. The throttle control lever Release the throttle control lever completely,
may have been depressed while inserting then reinsert the key.
the key.
7 Throttle trip. Throttle potentiometer Contact your authorized Pride Provider for
fault or speed potentiometer fault. assistance.
8 The motor is disconnected. Contact your authorized Pride Provider for
assistance.
9 Possible controller trip. You may be Shut down your scooter for a minimum of
attempting to install the battery pack while several minutes to allow the controller to
the key is inserted or the motor controller cool. Or, try reinserting the key into the key
may be in overheat protective mode. switch.
What you may be doing is mis-counting the beeps and it may be 9 beeps or its 8 and you have a bad connection between the motor and the switch? Good luck!
Jan 19, 2015 | Pride Health & Beauty
My Go Go Elite Traveller mobilty soccer beeps when I try to go Forward
hi, that can mean the throttle pot not giving the right resistance to the controller, contact me for more help if required...
Regards
Rob.
www.facebook.com/gewizrepairs
Mar 27, 2014 | Drive Medical Health & Beauty
I have a Go Go Elite Traveller 4 wheel. I just spent $175 on 2 new batteries for it. I charge it every time I use it. It will not go more than 20 minutes before it stops. Then I get 6 beeps. ...
hi, sorry to hear you having issues with the go go
Here's the manual
http://www.pride-mobility.co.uk/docs/Elite%20Traveller_owners%20manual.pdf
The fault description is :
Throttle control lever not at centre position
at start up.
Return the throttle control lever to centre
position, turn Travel Scooter off then back on
so what happened is that the throttle is no longer centre , look at the base of the throttle stem, a cross head , now that should look straight at the the seat stem, be in aligh with it, if's it off slight you will get that fault so you need to adjust the lever so the pot is dead centre again..
Still having a problem then goto my site and contact me so we can solve this for you free of charge..
Regards
Rob
www.gewizrepairs.co.uk
Dec 30, 2013 | Pride Mobility Products Go-Go Elite...
Has 6 beep
6 Bleeps on a Go-Go indicates you have a speed or throttle pot error.
Sep 23, 2013 | Pride Go-go Elite Traveller 3 Wheel...
Aug 18, 2012 | Pride Go Go Elite Traveller Plus HD 4...
My son has a pride mobility 3 wheel go go scooter, purchased less then a year ago. He has MS and depends on the scooter to get around college. It stops intermittently, he hears 7 beeps, and then 2 more...
The throttle potentiometer, which the throttle lever is attached to, is a component that is very prone to wear. Often there is a bad or uneven surface on the sliding contacts that can give poor performance or surging throughout the throttle range. I have had to replace several during the warranty period. According to your beep code description there could be a bad or intermittant component or a loose wiring connection of the speed pot, throttle pot or front to rear harness. I usually replace the speed potentiometer and the throttle potentiometer at the same time because these two components are interconnected. There could be a loose connection in the front console or loose connector. It is also a good idea to check the front to rear wiring harness connectors and harness for cuts or shorts. This also gives a 7 beep code. Check for binding of the throttle lever on the console case and a bent throttle shaft and mounting bracket. If the scooter is less than a year old it should be covered under warranty. Keep in mind that replacing these components under warranty requires a factory certified tech at a dealer. I hope this helps.
Oct 26, 2010 | Pride Go Go Elite Traveller Plus HD 4...
I have a gogo scooter it bleeps once than cuts out I have to turn it off and back on for it to move
probably a dead battery or a bad battery will move you till the controller gets to a threshold voltage then it beeps and stops , testing this is easy turn on the scooter adjust the speed control to the lowest setting then start riding the scooter at full throttle then start turning up the speed controller if that produces the problem then the batteries need charged or replaced
Jul 01, 2010 | Pride Mobility Products Go-Go Elite...
7 bleeps on my GO GO ELITE TRAVELLER SCOOTER
Hi. 7 beeps is fault code for a faulty speed potentiometer. Might also be a broken wire on the pot or a faulty connector. Most times, a new pot will fix the problem.
Good luck. Neil.
Jul 08, 2010 | Pride Go Go Elite Traveller Plus HD 4...
Health & Beauty Logo
183 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
