Question about Maxell Computers & Internet
My 32 gb flashdrive says that it needs to be formated but will not let me because it is write protected, so can someone tell me how i can format it so i can use it again
  • Maxell Master
  • 27,725 Answers
Click start click to open on my computer you should see your Usb drive E: or something
right click select properties there will be an array of options select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box then click permissions
make sure all 3 boxes are ticked full control change and read in windows 7
click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
click start right click on my computer select open
Right click the icon of your Usb Drive (It should be E:/ or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
click start click on my computer to open you should see your drive
right click then select format
another way
click start control panel administration tools computer management disk management right
right click on your usb drive select format
if you need more help with this post a reply
hope this helps
Posted on Oct 31, 2012
justsayes
  • 4 Answers
SOURCE: Unable to Format WesternDigital USB Hard Disk
Are you formatting a new disk or an existing one? Keep in mind that the rest of us do not know all the details that you know unless you tell us & thus it will take much longer to resolve your issue.
You said "after you tried it with XP CD". Dont know what you mean. What program did you use the first time & what steps did you do?
Posted on Nov 24, 2008
laikexpert
  • 281 Answers
SOURCE: How do I turn off the write protect on the verbatim 4gb flash drive?
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Posted on Jan 31, 2010
laikexpert
  • 281 Answers
SOURCE: my kingston 32 GB pen drive shows write protection
http://dl.dropbox.com/u/4040651/HPUSBFW_2.2.3_MASTER.exe
2. Format
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
Posted on Feb 02, 2010
laikexpert
  • 281 Answers
SOURCE: KINGSTON USB 2.0 4 GB IS WRITE PROTECT. I want to
2. Format
SOURCE: MY 4 GB KINSTON USB CULD NOT FORMAT IT IS BEING
You need to slide the unlock on the side of it to remove the write protection from it
Posted on Mar 20, 2010
What does card protected mean?
Wheb you have a SD, SDHC or SDXC memory card and you put the switch to the lock position, the card is protected, That means nothing can change the files that are stored on the card. Not by wiring, not by deleting and not by formatting. Keep the lock with up, towards the golden connection points.
On the picture the 64 GB card is unlocked. `the 32 GB card is locked 8ab871eb-243a-48dd-a8d8-58e5df95d568.jpg
Dec 29, 2013 | Vivitar ViviCam 8025 Digital Camera
I had a pendrive of 8 GB my friend tried to make a bootable pendrive so he changed some settings by command prompt. My pendrive storage capacity dropped from 8 GB to 3.44 GB I need a good solution please...
It seems that after your friend made it a bootable pendrive, he/she did not format it.The space has been used up by the installation files in the flashdrive,and these files may be hidden.This is likely to be the case with some command-line utilities for making bootable flashdrives.
To recover your space, simply format your USB pendrive.To do so on Windows XP,insert the flashdrive into your PC, go to My Computer, right-click the USB pendrive,and in the window that appears, click the tools tab and select the Format option.
That should solve your problem.
Jan 25, 2011 | Computers & Internet
I have a Usb flash drive but it has a capacity of 0 bytes. lastly i buy this with a 2 GB. i don't know if what can i do in this matter i hope you can help me. i don't how to format this cause when i try to...
some cheap flashdrive has no option of format..only delete option..but if you do is format may flashdrive firmware was lost ..thats why read zero value...
but trying it to insert to the other conputer if same problem occuring..
if so...your USB is have lost firmware..
May 25, 2010 | Computers & Internet
CAN NOT BE FORMATED
Hi
try to format your kingston with
Following tool.
from the site
http://www.softpedia.com/progDownload/HP-USB-Disk-Storage-Format-Tool-Download-123786.html
This tool allows you to format your pendrive either
in fat32 or NTFS
IN which NTFS is better
and also IT· Allows creation of a FAT32 volume larger than 32 GB.
An alternative is to format it in any linux
Feb 26, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
I can not copy enything onto the 8gb flashdrive and if copied it cant be deleted again
Do you have a write protect switch on the pen? If so switch it to the open position.
Sep 10, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
4 GB Flashdrive says I only have 635.9 MB on my MAC
Formating the flashdrive may restore the drive to its full capacity. This will delete the existing files on the flashdrive.
Sep 03, 2009 | Dane-Elec DaneElec 4GB USB Drive Copper...
32 gb expresscard can not be formated or read
remove the card from your computer, look for a tiny switch on the card, and move this switch to the other side.
Jul 21, 2009 | Transcend 32GB ExpressCard SSD, MLC 32 GB...
Cannot use the San Disk 4 GB flashdrive
up to 2gb sd cards are sd format 4gb are sdhc format . you camera will not write to sdhc and it is not a good idea to put in your camera .
Jun 03, 2009 | Nikon Coolpix 2200 Digital Camera
Write protected and locked files on PNY Optima 2 GB flashdrive
is there a little switch on the side of the usb, if so move it. test with "H2testW"
Jan 25, 2009 | PNY Optima 2GB USB 2.0 Flash Drive - Dark...
I got a transcend 4gd flashdrive and its write protected i have tried accer software still doesnt work need a better solution
LLFTOOL is a utility for low-level disk drive formatting,
also supports formatting of FLASH cards using a card-reader.
2. Format flashdrive
Dec 29, 2008 | iLO (2 GB) MP3 Player
Computers & Internet Logo
141 people viewed this question
Top Maxell Computers & Internet Experts
yobo007
yobo007
Eric
Are you a Maxell Computer and Internet Expert? Answer questions, earn points and help others
