Question about Samsung SC-D353 Mini DV Digital Camcorder
Pink strips through screen and tv when playing back tapes
All of a sudden when i was going through my old tapes i went to hit play after inserting a new tape into the camcorder and now everytime i attempt to the play the videos back, like 5 pink lines appear on the screen throughout the whole video. it has happened to every tape i put in and it happened out of nowhere! i even tried to record new videos and the pink lines still show up when i try to play it back...and even when i connect it to the t.v to watch it..i have no idea what happened! can someone help me out?!
    Champion:
  • 221 Answers
Clean the heads - the '5 stripes' are the symptom of dirty heads.
Posted on Jul 10, 2007
SOURCE:
TV screen went black, sound is intact, can I fix it?
This sounds like you accidentally hit the input button on your remote. It will either be INPUT or SOURCE on you remote. Turn on your TV and source(cable box) and hit one of those buttons until your picture comes back
Mar 02, 2015 | Televison & Video
Have sharp quos 52" screen went pink. Can still
Hi, My guess is your daughter messed it up. Go to menu and color and reset to default should fix it.
You may have to adjust color for your best viewing. Good luck.
Sep 27, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
I was trying to view so vcr tapes I had video some years ago and I loaded a tape and started watching it and all of a sudden the picture went out but I could still hear. I used a head cleaner and the tape...
yes, this is what happens to analog tape...it gets corroded because it was not stored in a cool spot...your vcr heads are cleaned that is why u still hear the audio...(video will go first all the time)...but if you play it all the way through once a twice (see if you can save it ...dvd)
Jun 27, 2010 | Televison & Video
Pink lines when i play back my tapes on my canon zr500
Hopefull your not going through the tv and then to your dvd recorder
transfer should go straight from your camera to the dvd recorder.
you may also want to but a head cleaner for a mini dv camcorder,run it twice and try recoding again.If that doesnt work,you may have a problem with the heads inside of the camera.If thats the case,it would need to go to canon or an authorized service center.
Feb 01, 2010 | Canon ZR500 Mini DV Digital Camcorder
Tape won't play, FF, or eject.
sorry to say that none.no trip button for that.i assumed that the magnetic strip of the tape is already wind up inside.you'll need to open the unit up and gently rotate the flywheel of the tape player until you can open the door of the tape compartment.no need to force or it will just break.
Jun 22, 2009 | Sony EVC100 Hi8 VCR
Won't record or play back tapes
It is old equipment, and a replacement is only £9.99 on Ebay
Mar 12, 2017 | Samsung SC-D353 Mini DV Digital Camcorder
Gr-fxm40 wont play back
Have you tried playing the tape in a regular vcr with the VHS-C adaptor?
Jun 12, 2008 | JVC GR-FXM40EK Camcorder
Tape stuck in VCR, won't eject.
you posted 2 different problems here...
to answer this one ". The tape is stuck, won't eject and I'd like to get it out without damaging the VCR unit."...open unit, find motor that moves tape ejector and spin that motor by hand (power off)
the other problem, "the VCR will not insert a tape. It keeps rejecting it."...open unit and fully turn ejection motor until home position is reached...this is a home sensor switch not being activated.
Feb 04, 2008 | Televison & Video
How do I remove lines
I had the problem of the horizontal grey lines with some pixels of pink. I ran the dry head cleaner a few times and the lines became solid grey with the sound now skipping worse than before. I cried, cleaned again, then played the tape. I did this about 4 times and still had no luck.
I then decided to try to record with a new tape around the room to see what would happen. After recording I played the tape back and it worked perfectly. I then went back the old tape that would not play properly and it worked fine! Seems like when I used the record button after cleaning it a few times everything worked fine, wierd.
Hope this might help someone.
Oct 22, 2007 | Canon ZR80 Mini DV Digital Camcorder
Will not playback or record
I have a Sony handy cam ccd-trv108 Hi-8 and I can not get it to play or record, everytime I insert the tape and hit play the display screen flashes c:31.22 Please help me?
Aug 10, 2006 | Sony Handycam CCD-TRV108 Camcorder
Samsung SC-D353 Mini DV Digital Camcorder Logo
281 people viewed this question
Top Samsung Video Cameras Experts
Marvin
Marvin
302lab
Level 1 Expert
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
