Operating systems not found. I accidentally hit the computer then it starting beeping. Turned it off. Then turned it back on and the video tells the rest.
More then likely you just knocked the cable loose to the harddrive. Open the case, unplug the cable and re-push it in on both ends, the drive and motherboard. See if that helps. I would say look into MBR but the fact the screen says it right there.
"Media Test Failed, Check cable."
This is VERY easy to do, dont be afraid to open that bad boy up!
Posted on Oct 31, 2012
I can't fully understand what you mean, you can speak more clearly?
askanything
  • 151 Answers
SOURCE: operating system not found
this is the problem that is arised when u try to install  2 OS at one time. for example if u install XP and winn2000 together this problem is arised.
The thing is that u have install new operating system with the help of cd/
Posted on Oct 14, 2007
  • 2427 Answers
Yep, your operating system has crashed, not your hard drive, but the windows on the hard drive..
simply boot from your windows cd / dvd and choose upgrade as the instillation type or leave current file systems intact so as you install windows over again, you dont loose your previous data..
Posted on Jan 08, 2008
  • 55 Answers
the laptop is unable to read operating sistem from disk - you have to try to insert recovery disk after changing in the bios (you can read on laptop manual how come in bios for changing to first boot is hard disk to first boot is cdrom or dvd or cd ) after that you can try to       recovery the operating sistem - it may be not so easy delfo
Posted on Mar 16, 2008
  • 25 Answers
SOURCE: Computer wont start up...
Insert your Windows, or Linux disc and attempt to boot/repair install windows. Your POST/BIOS is not detecting your Operating System (windows more than likely). That being the case you may need to reinstall or repair install the OS. Did you or a member of your family format the hard drive? What were the circumstances under which this occurred? Either way using your Windows disc should allow you to move forward. If you didn't get a windows disc with your PC you should have gotten a "restore" disc this will (when run properly by follwing prompts) reset the computer back to factory settings. If you suspect that you have valuable data on your PC you will want to take measures to recover that data first before "restoring".
Posted on Oct 26, 2009
  • 1015 Answers
SOURCE: sony vaio operating system not found when computer
You can try running the installation/recovery disc that came with the computer or the built-in recovery system (if it has one) to try and repair the windows installation. The problem is if the computer is saying that the operating system is not found then critical files got deleted from something like a virus or the hard disc drive has stopped working. You may have to do a format and re-install of the windows OS.
Posted on Nov 14, 2009
Operating system not found
hi goodner,
getting the error "operating system not found" means that the hard drive where the Operating System is installed (i.e. Windows XP, Windows Vista, Windows 7), Cannot be found by you BIOS upon the boot sequence.
When you turn the PC/Laptop, you normal see a screen that flashes flashes with screen that displays the ff:
Primary Master:
Primary Slave:
Secondary Master:
Secondary Slave:
The Primary master should have a value right next to it. If not, either the hard drive is faulty and needs replacement, cable is loose,
If you have a value to it and stil gets the same error the operating is corrupted and needs to be re-installed.
Jan 29, 2013 | Computers & Internet
Laptop is beeping when turned on and will not load windows
Remove the hard drive and power up the computer, does it still beep, if yes sub out the ram memory one at a time and test. If no reseat the hardware back in position to see if you can start it, no change have the hard drive tested.
Jun 17, 2012 | Dell Computers & Internet
I am at work in a hospital. Our IT people are not here at night. I can not get my Dell keyboard to respond. When I touch any key, it makes a soft beeping nose, but nothing happens. I think I accidentally...
First of all make sure that the Number lock or fuction lock are not on. Press one of these keys and see what happens.
Secondly if the keyboard is part of a desktop unit, disconnect the keyboard. Restart your computer and reconnect the keyboard after the system boots. Allow your operating system to recognize and reinstall the keyboard.
Good luck and please post back if you need anymore assistance.
Regards.
Feb 19, 2010 | Dell Spacesaver USB Keyboard J4624 SK-8115...
Computer not turning on
probably it is your operating system. try to recover your windows by using the recovery disc that came out with your e machine or find another widows to install but do not format the hard disk rather replace the existing one.
if you can't make it, please send me an email at 208501414@ukzn.ac.za then i will help you step by step.
thanks
wonder
Sep 17, 2009 | E-Machines (308714) Motherboard
My E-Machines desktop just stopped working. A few weeks ago, my user was corrupted so I had to do a system restore to get to my data on hard drive. Did that and backed up to external drive and it worked...
that beep means POST.. your computer hardware is fine .. please just re install the operating systemm... before that you might want to back up the hard drive data using bartpe or some tools similar to that.. if you dont have that expertise. just re install the operating system .. you should get back to work...
remember beep meaning POST meaning your hardware is fine.. the operating system is just corrupted / broekn
May 13, 2009 | E-Machines eMachines Desktop PC
Computer turns on and beeps
Have you recently changed any hardware or BIOS settings? Is it one beep for 8 seconds or 8 beeps? If it's 8 beeps then that indicates a bad video card. If you are not using the on board video then try re-seating the video board or try a different video board.
Mar 13, 2009 | Microsoft Windows XP Professional
I accidentally hit "standby" key and can't get out.
go into safe mode and restore your computer via a restore point that occured before the accidental hitting of the key.
hope this helps
kev
Nov 30, 2008 | Logitech 967461-0403-PK Keyboard/Mouse
Causes :
  • Hard drive is not detected on the system
  • Hard Drive starting to fail / Damaged
  • Incorrect Master Boot Record (MBR)
There are a number of solutions that you can try on. Here is a link from Microsoft that will give you all the steps to verify the root of the problem. Click on the link :
http://support.microsoft.com/kb/321626
--------or---------
Operating system not found causes / Solutions
Nov 03, 2008 | HP Compaq Presario SR1420nx...
Display output turned off
you are going to have to take it to a computer tech. that is the only thing i can tell you unless you are useing a pci video card if that is the case put it in a new slot and reboot.
Dec 20, 2007 | Compaq Presario 5000 PC Desktop
Black screen
The beeps are probably BIOS beep error codes. Through a series of long and short beeps the computer communicates computer problems that occur early in the startup processes. It's likely the problem isn't your monitor but something in your computer box itself. If you can tell us what the pattern is we can start diagnosing your problem. We'll also need to know the manufacturers name, the specific model computer you have and what operating system you are running.
Feb 04, 2007 | Microsoft Realsync DS771 17 Black LCD 8ms...
Computers & Internet Logo
80 people viewed this question
David Payne
David Payne
