Question about Dryers
Maytag Gas Dryer SDG515DAWW - heating stopped
This Legacy Series dryer has worked fine for about 4 years, but today it stopped providing hot air. All electrical works fine, and drum turns. I checked the igniter and it does not glow hot.
Is there a good way to check and see if the problem is with the igniter versus the thermostat versus something else? I would like to try and order the correct part the first time.
Thanks
Bruce Same symptom: No ignition, but apparently no power fed to the ignitor. Checked ignitor-coil by powering from outside ->OK! Motor runs fine, but no heat. What could it be preventing power getting to the ignitor?
Bernd
  • bvonsosen Jan 04, 2009
    Thanks so much 'TheMobilian'. I think I'm on the right track: found and checked thermal fuse-> no connection between the poles (I guess = melted) and will replace it first. If needed, next I'll have an eye on thermostat (the fuse-melting could be a consequence of a bad thermostat) and the 2 coils. Have to wait for parts; let you know.
    Bernd
  • bvonsosen Jan 08, 2009
    Well, after double-checking continuity of thermostat and thermal fuse under better conditions out of the dryer, before ordering any parts, these parts were good and I ended up replacing just the ignitor (bought it at 'Appliance Parts Specialist' on the web and received it next day, 17.06 + 4.95 S+H).
    The alignment lip on the ceramic-body of the replacement-ignitor was longer than on the original part and I carefully removed some material making it fit into the slot in the mounting bracket. The dryer runs perfectly again.
    Thanks for all the educational help!
    Bernd
  • Dryers Master
  • 8,205 Answers
The heat is regulated with a Klixon mounted next to the blower housing near the vent pipe so it can judge the temperature of the air coming out of the drum.Right next to it is a melting type fuse. If the dryer runs and gets too hot the fuse will melt.But the dryer will still run. So if the fuse is good(continuity) and the dryer control(cycle) thermostat is also good then you should have power going to the gas valve assembly when the machine is running unless the timer is in the no heat or wrinkle free/cool down mode. When the gas valve assembly is energized the flame sensor Maytag Gas Dryer SDG515DAWW - heating stopped - a%20flame%20sensor%202.bmp flame sensor mounted outside the burner chamber detects the heat from the ignitor. When the heat is very intense then the sensor shuts down the igniter
a%20igniter.jpg Igniter and that frees up the power so that the coils can be fully energised and open the gas gates. The gas comes out and hits the red hot igniter and you have ignition. It stays on for maybe 2 or 3 minutes or until the control thermostat is satisfied and shuts down power to the gas valve assembly.
Posted on Jan 04, 2009
Sdg515daww maytag legacy series gas dryer will not put out any heat until the dryer has been on for about an hour or an hour and a half...have cleaned external vent tubing and vacuumed (as far as vacuum...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 28, 2011 | Dryers
Model sdg515daww dryer working but gives no heat.
heatman101
Jun 18, 2011 | Maytag Dryers
MAYTAG LEGACY DRYER IS 3 YRS OLD TODAY AND HAS STOPPED HEATING. BREAKERS ARE NOT TRIPPED AND PROPER VOLTAGE AND VENTING IS WORKING PROPERLY. HOW HARD IS IT TO CHANGE THE HEATING ELEMENT? THANKS FOR THE...
heatman101
Apr 23, 2011 | Dryers
Dryer stopped heating
watch the video
Jul 11, 2009 | Dryers
2 year old maytag gas dryer blowing warm air
Hi, Is there ant heat at all? Is it possible the dryer heats at first and stops later in the cycle? The first thing to check is the 4" vent going to the outside. Make sure it is cleared of lint and that it is not pinched off at all.
If the vent is ok, you might need to replace the coils on top the gas valve.
I can help you with this. I just want to narrow it down.
Vic
Jul 05, 2009 | Maytag MGD9700S Gas Dryer
Gas Dryer
HI thanks for your question. the problem is with the coils on the gas valve. one has failed. they come in a pack of 2 replace the coils. thanks the appliance doc. please rate my answer. thanks.
Oct 14, 2008 | Maytag Dryers
Smell Gas.
you need to clean out you venting ...it is most likely clogged or filling up
Jan 02, 2008 | Maytag MDG2706A Gas Dryer
if it dont come on in 30 secs replace it
Dec 30, 2007 | Maytag MDG2706A Gas Dryer
Dryers Logo
629 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
