Question about Magic Chef Washing Machines
Water is leaking between the shaft and drum - Magic Chef Washing Machines
    Top Expert:
  • Magic Chef Master
  • 9,472 Answers
What is the model number of your unit?
Posted on Nov 01, 2012
I mhave a whirlpool cabrio 6600 and makes a terrable sound when spinning
By experience it's the bearings on the shaft. The old seal leaks allowing water from the drum onto the bearings which eventually drys them out. The new replacement seal works better. It's do able but time consuming. approx. 5 hrs. Instead of posting the entire process, go on "Youtube" and search for your model. Cost of parts and bearing tool, $150. To remove the drum, I use a 21"- 2"X 4" on the inside of the top of the drum and a scissor jack to lift it off of the shaft. It's all on 'Youtube". Just to let you know, Maytag wants to sell you the whole drum and shaft together, $500. I would advise you to purchase the bearing tool with the kit. It makes life a lot easier. Purchase both from your local parts supplier.
Dec 26, 2016 | Whirlpool Washing Machines
Why is water leaking from the bottom of the the washing machine?could the drum be to full?
It could be a bad tub seal, hole in a hose, or even the drain pump.
I would need your model number to be able to tell you how to check these parts.
Sep 27, 2011 | Frigidaire Washing Machines
I had a clog in the pump filter, pump assembly fine cleared it all, now the drum is knocking in the spin mode and there is water leaking, not from pump. I read about the counter weights, the shocks seem...
This can be related to a tightness in the spindle shaft that makes the motor spin the whole drum together. so this also seems to be the leak in the system. So check the shaft, the bearing assembly the water seal in the drum shaft.
You might have to reset and overhaul this section for the fault to clear off.
If the shocks are good the counter weights should work fine unless there is a mechanical damage on the chassis.
Jan 10, 2011 | Whirlpool Duet GHW9150P Front Load Washer
WATER LEAKING FROM DWNSIDE WHILE RUNNING
Possible leak from the spindle shaft of the agitator. It will good to have a close look while the drum works so as to locate the point of leak.
If this is from any hose or joints , it can be taken out and reset. If not the water seal can be loose and must be taken out and changed. ---- the bearing assembly unit .
Jan 03, 2011 | Washing Machines
Hotpoint WMA30 is leaking a small amount of oily water from the back of the drum when in use. There is a small hole in the back of the drum, should there be a screw in this hole that has fallen out?
Thwater is leaking because the shaft seal has worn, and the hole is supposed to be there as it is a drainage hole.
The outcome will be that the main drum bearings will eventually fail as the water will get into the drum bearings.
To replace the seal involves a complete strip down of washer. not a job to be undertaken by yourself, unless you know what you are doing.
Nov 14, 2010 | Hotpoint WMA30 Front Load Washer
I have a GE washer WJRE5500GWW. It makes a loud grinding sound during agitation and spin cycle.the spin seem a bit slow but it pumps out the water just fine.
its your drum bearings going there just about worn out,,not a cheep job to fix sorry,,,soon it will start leaking water from the drum drive shaft!!!
Jul 15, 2010 | Washing Machines
Water leaking under washer but no appearance of leaking from hoses
water seal inside washer drum may be damaged, causing water to come out along drum shaft.
Oct 24, 2009 | Frigidaire Washing Machines
WATER LEAK ON REAR OF DRUM AND EXCESS MOVEMENT hOOVER1400 HPB145
If there is water leaking then you need to repalce both bearings and the seal that sits around the drum shaft and protects the bearing. Check the brass collar on the drum support thats sits in the bearing is not worn or grooved.If it is the shaft and/or the drum need replacing too
Sep 22, 2009 | Washing Machines
Leaking at drum where drive shaft enters
hi thanks for the question .your problem is major save yourself a lot of aggravations purchase new a nice washer is called roper built by whirlpool but cheaper same quality thanks the appliance doc
Sep 28, 2008 | Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub...
Washing Machines Logo
56 people viewed this question
Top Magic Chef Washing Machines Experts
Ian Jones
Dan Webster
Dan Webster
Are you a Magic Chef Washing Machine Expert? Answer questions, earn points and help others
