I need to change my tv from cable to dtv!!! But i dont have the manuel but i do have my remote!!please help........32"westinghouse lcd hdtv
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
You may be able to Google the model number with manual to locate one. You should have the model number when you do that.
Posted on Nov 01, 2012
SOURCE: can't progam my direct tv remote to operate my westinghouse 32''tv
I don't have DTV anymore, so I don't remember the exact code I used for my SK-32H240S, However, I do remember that I found one that worked at this site. Scroll down to locate your remote series # - it most likely will be printed on the upper left corner of the front of the remote - as an example, mine says RC64. Click on the corresponding listing, then follow the directions on the site. I tried only a few codes before finding one that worked correctly. Good luck.
Posted on May 08, 2009
SOURCE: Westinghouse SK32H240S 32'' LCDHDTV Picture appears and Disappears
This problem is caused from a problem with the main board. The main board will need to be replaced. It runs from $100.00 to $150.00.
Posted on Jun 10, 2009
SOURCE: Mintek LCD TV DTV-320-D buttons does not work
Be advised that Mintek Digital Inc., the company that has sold portable DVD players, DVD Flat Screen TVs has filed bankruptcy in Federal Court. What this means to consumers is that your product(s) warranties that are within your purchase date are no longer valid. Anyone purchasing any Mintek products with claims of warranties are being mislead. For further information, contact the California Attorney General's Office, the Better Business Bureau or telephone 301-986-666 or email at mott@mpegla.com to seek compensation. Remember, if you buy any Mintek product, you are buying a product that cannot be supported or warranted. You are on your own since September 9, 2007.
Posted on Jul 23, 2009
SOURCE: westinghouse 32" lcd tv model # sk-19h210s won't turn on
Try unplugging it . Wait a few seconds and plug it in again.
Posted on Mar 23, 2010
budmrtn
  • 11361 Answers
SOURCE: Westinghouse LTV-32w1 32 in. HDTV-Ready LCD
You need to remove the stand to get to get the back cover off, this is what it looks like inside, the power supply module is at the bottom of the chassis.
http://s807.photobucket.com/albums/yy352/budm/LTV-32W3HD/
http://s807.photobucket.com/albums/yy352/budm/Westinghouse%20LTV-32W1/
ALL the screws must be removed, they are around the edge and around the middle of the back also.
http://www.shopjimmy.com/catalogsearch/result/?q=westinghouse+LTV-32W1
Posted on May 19, 2010
Testimonial: "Thank you for the info."
How do i get cable tv on my westinghouse tv
Go to the menu look for the input settings make sure it is set for cable not air. There might be a input button on the side of tv or on remote that will let you select which input to use. It will have to be set on cable thin scan for channels.
Aug 08, 2017 | Westinghouse 32-inch Led-lcd Tv - 720p...
I have to press my remote control " ON " button several times before my 32" VIZIO TV finally turns on ? Help.
Sounds like simply interference, It could be a glare from a glass door for example. also it depends on how far you are from the TV, I would reposition your self a little closer to test the theory, If the distance is the issue you can either move closer or stop by a local radio shack and grab a remote extender that can extent your signal significantly they are normally between 10 and 20 bucks. also if the remote is not the factory remote that came with the TV and belongs to the cable company then that could also be the issue, Vizio is still not 100 percent support by cable company universal remotes. I do tech support for Charter Communications and VIZO is one of the biggest issues I see when it comes to remote compatibility with cable remotes.
Hope this helps and as always please feel free to reply with any further questions. take care :)
Please dont forget to rate me :)
Jun 07, 2011 | Vizio L32 32 in. LCD HDTV
Lost remote want to use a univerisal remote but tv say front panel lock How do I unlock it? 32 in westinghouse
On the TV itself, MENU, SET-UP, INPUT, VIDEO then go to Channel lock and de-select it.
Hope this helps. If you post a model number, I can probably get you a manual.
Good luck, R.J.
May 13, 2011 | Westinghouse 32" Flat Panel LCD HDTV
I am tire of cable and want to use an antenna, I have hooked an antenna to the tv checked the hook up and it is secure, but am getting no signal...I have been trying to find a place to change from cable to...
After u hook up the antenna source like a digital or a roof antena to the tv.Used ur remote go into the tv menu.Goto SETUP,go down to CH.Pick AIR enter and scan for free air DTV channels.
Feb 25, 2011 | LG 32LG30 32 in. LCD HDTV
My 32 inch westinghouse lcd tv's screen turned pink when on
your T-con board is failing you need a tech to replace it about a 150 dollar job
Nov 18, 2009 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Need to switch to dtv from reg tv but dont have fac. remote
most universal remotes will only do basic functions on your tv like changing volume or channels only some will do menu functions or change input source. if you have a universal remote with a input or source button you can try it some cable and satelite remotes have this function and are discribed in the user manoal. If all else fails you can order a original remote from the manufacture or your local tv repair shop
Apr 27, 2009 | iLO 3200 32 in. LCD Television
Dtv universal remote
I'm using a universal remote with code for an LG 0178 (or 101780 AND IT WORKS
Dec 29, 2008 | Vizio L32 32 in. LCD HDTV
Can't progam my direct tv remote to operate my westinghouse 32''tv
Dec 27, 2008 | Westinghouse SK-32H240S Television
Screen is cut off top/bottom
I had the same problem on my 47 inch Westinghoust HDTV. It turned out to be a problem related to my satellite tv (Direct TV) remote controller. Someone inadvertently hit the "format" key and jacked it up. I set back to it's original position and get the full screen. Don't know if you have cable or satellite, but this may help someone having this problem,
Nov 16, 2008 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Direct TV remote, need code for Westinghouse Flat Screen 32" itsdon458@yahoo.com
Try these codes listed for Sony.  10080 11100 10111
 One of these should work.
Jan 06, 2008 | Westinghouse 16093 Remote Control
Televison & Video Logo
19 people viewed this question
Top Televison & Video Experts
Electro Med Services...
