Question about LG Washing Machines
I have an LG washing machine. The model number is WM2077CW. It stopped all of a sudden. There is no lights. When I press start, it is not working. What is the problem?
The model number is WM2077CW. It is a front load washing machine. The machine is dead. No lights and it doesn't work. Is it the control board?
    Top Expert:
  • LG Master
  • 9,472 Answers
Check the breaker to make sure it is not thrown. If the breaker is OK, then you will need to replace the "main control board". Here is a link to the part you need.
Posted on Oct 31, 2012
4 Suggested Answers
stradeteox
  • 88 Answers
SOURCE: LG washing machine Model # wm2077cw
LE is a locked motor error. If this happens often then 95% of the time this is just a bad hall sensor (motor position sensor). A technician should be able to ohm out the hall sensor to make sure. The part is relatively inexpensive and easy to replace.
This can also happen if the motor is overheating slightly from being overfilled (too many clothes) or if you do one load after the other and do not allow at least 10-15 minutes between loads for the motor to cool down. In this case the LE error will only happen occasionally.
Hope this helps, please rate my solution.
Posted on Jan 11, 2009
Daniel S
  • 4323 Answers
SOURCE: The washing machine works fine
Hi
The issue is with the door lock assembly that is bad and should be replaced. If the door lock assembly is bad the control will sense that the door is open and so will not start a spin cycle. If you want you can test the door lock assembly with a voltmeter before replacing it. Hope this helps...please post back for further assistance.
Daniel
Posted on May 09, 2011
  • 6277 Answers
SOURCE: when we press start button,the
(no promises but it's worth carrying this out anyway!)
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Aug 18, 2011
LG Tromm wm2077cw front load washer would not drain Looked at drain pipe and drain pump filter, both was good no clogs
Does the pump work? if so common problem is something stuck blocking the sump pipe between drum & pipe 2 the pump
Dec 23, 2015 | LG Washing Machines
My LG washing machine, Model# WM2077CW squeals a bit as the spinning comes to a stop. All other operations are fine. Is this model belt driven or am I looking at some other issue? Thanks.
direct drive. two other issues come to mind. one, your front door seal is malformed and touch drum someplace. two, your bearings and bearing seals are making the noise and starting to wear.
Oct 11, 2015 | LG Washing Machines
LG WM2077CW Front Load Washer Problem My LG Tromm model # WM2077CW is leaking at the bottom of the machine but not from the door. If you run your hand along the bottom front of the machine there is a seam...
MOST OF THE TIME IT IS A HOSE THAT HAS RUBBED A HOLE IN IT OR THE DOOR BOOT DRAIN HOLE. THE HOSE IS ATTACHED TO THE BOOT BOTTOM CENTER OF THE BOOT AND HAS A SHORT HOSE THAT RUNS BACK TO THE TUB..
Apr 25, 2017 | LG WM2077CW XL Front Load Stackable Washer...
Washer won't fill. code LE
Try unplugging and replugging. Apparently it does a reset of something. It worked for me. I would make sure you don't have to much laundry in the machine too.
Dec 10, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Lg wahing machine WM2077CW a little bit of water enters cycle slowly, and i don't see soap nor water
Hi, Turn the faucets off at the wall and remove the inlet hoses. Look inside the inlet valve and see if the screens inside the valve are plugged.
I hope this helps
Vic
May 30, 2009 | Washing Machines
Washing Machines Logo
173 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
