Question about Hoover U8171-900 / U8172-900 / U8173-900 / U8174-900 Savvy Bagless Upright Vacuum
Hoover Savvy has limited suction when cleaning the floor and carpet
I seem to have full suction thru the hose but limited to none when cleaning the floors. The brushes seem to be spining on carpet mode but has a high pitch sound and doesn't pick up. The canister, filters and brushes are clean. When I turn on the carpet mode, it almost seems that the suction is in reverse. Dirst comes out of the bottom. Please help me.
  • 3 Answers
With the unit standing upright, double check the clear plastic air passages on the sides of the vacumn to see if they are clogged.
Posted on Jan 07, 2009
  • Help me Fix Stuff Apr 21, 2012
    If those passages, bag, hoses, everything else is clear as well, what else could be making the suction go almost in reverse when on carpet?
Doesn't seem to have much suction when I put my hand under the head. Have cleaned both the filter and the mesh screen
Check the suction from the hose for rge tools see if there is suction
also check to see if there is a obstruction on the short hose to the nozzle
May 16, 2016 | Hoover U5140-900 Widepath Bagged Upright...
My hoover spin scrub has no suction wont pick up water why?
No suction means somewhere in the intake side of the system you have either a blockage or an air leak.
Jan 21, 2015 | Hoover Brand New SteamVac Spin Scrub...
Miele Vacuum Cat and Dog Upright S7260 Loss of Suction
could be a couple things first make sure the hose is clear check real good the other is make sure your bag is good and tight and clean and make sure you have no holes or tears in the hose
Mar 07, 2014 | Miele Vacuums
1) check the hose for blockage.
2) see the belt is slipin to due worn and replace .
3) check the bag/tank for full and need empty, and replace.
However go to the
and use the troubleshooting with common senses.
God bless you
Sep 06, 2012 | Hoover U8171-900 / U8172-900 / U8173-900 /...
I cleaned out the hose and removed brush to clean and checked belt. Everything seems to work but will not pick up or suction on carpet. The hose is totally clear from clogs. I can see the floor from one...
Hi troupdavid,
I see that your Vacuum is having issues with it suction, you mentioned that you took it a part to clean it, see steps below.
  • Check if everything is inserted properly and is in place.
  • make sure the the Vacuum airflow does not have anywhere else to come out from, cause if there is, the vacuum suction will really not be really getting enough suction to be able to get dirt Off the floor.
  • Make sure the bag is correctly placed in the Vacuum and is tucked in properly for proper suction.
  • The hose should be twisted to be locked into Place, either clock wise or counter clockwise which ever makes it lock to the hose socket.
  • Also check the agitator shield beneath making sure that the Belt is not pinched in or squished by the Agitator and the Agitator shield, this can also cause lack of suction for the Vacuum.
I hope that this will be of help regarding your query.
Have a nice day,
May 01, 2011 | Hoover Tempo Widepath Upright Vacuum -...
Is there a switch to turn-off the tools so that
On the Hoover U6311-900 there is no switch that turns off the suction to the tool hose. That hose is attached to the head of the vacuum on the side via a spring loaded "door". Just twist the hose to remove it, the door will close and you will have full suction again.
Apr 06, 2010 | Hoover U6311-930 Power Drive Bagged...
No suction from upholstery attachment
Problem: Low suction
Problem: Clean solution won’t
Problem: Brushes/brush indicator
won’t rotate during floor cleaning
Possible cause
Possible solution
• Not firmly plugged in
• Plug unit in firmly
• No voltage In wall plug
• Check fuse or breaker
• Blown fuse/tripped breaker
• Replace fuse/reset breaker
Possible cause
Possible solution
• Recovery tank full/automatic
shut off engaged
• Remove and empty recovery tank
• Blockage In tool on end of hose
• Remove tool and clear blockage
• Recovery tank lid not on
• Make sure lid is on securely
• Recovery tank front panel not
replaced after stair or upholstery
• Replace recovery tank front panel
(page 14)
Before using tool
It may be necessary to remove air from
the system (“prime the pump”) so the
clean solution will flow to the tool. Follow
these steps:
1. Attach tool to hose and turn the carpet
cleaner ON.
2. Put the tool on a hard surface or
against your hand to block off the suction.
3. Wait a few seconds (can take up to
15 seconds). Then squeeze the trigger
and begin cleaning.
Jun 17, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Brushes won't spin on carpet
belt is stretched replace the belt and all will be well
Jul 22, 2008 | Hoover U5753-900 WindTunnel Bagless...
Hoover savvy no suction on carpet setting
Check to make sure you hear the vac. motor is running when in that position. The switch in the handle could be bad if it is not.
Apr 29, 2008 | Hoover U8145-900 Savvy Bagless Upright...
as the hose fits into the base (if i am correct) the power at the base should be fine, make sure the base is clean and free from blockage, you say the brush doesn't spin, has the belt broken, if so replace it, (very cheap) and only a couple of screws to undo, the roller not rotating will effect the power of suction dramatically, start from there and see how you go if i have helped please rate me
Sep 15, 2007 | Hoover U8171-900 / U8172-900 / U8173-900 /...
Hoover U8171-900 / U8172-900 / U8173-900 / U8174-900 Savvy Bagless Upright Vacuum Logo
227 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
