Goodman U60 HVAC Evap coil piston size - Heating & Cooling
22yooper
  • 828 Answers
SOURCE: coil piston
If you purchased it as a package the right piston may already be installed in the indoor Evaporator coil. When shipped the extra piston if needed is packaged with the outdoor section condensing unit.
Posted on May 17, 2008
bobotfel
  • 236 Answers
SOURCE: Evaporator Coil
Yes, just count how many pins per inch and replace with the same number of pins per inch.
Posted on Sep 11, 2008
manhandy
  • 146 Answers
SOURCE: where to install packaged piston on 4 ton 13 ser
it goes high pressure line evaporator coil if it call for it see instruction it will say.
Posted on Jul 07, 2009
  • 92 Answers
SOURCE: Goodman Model # cpke241AB not cooling always running
First locate the air handler.Open the access panel and you will see the evap coil.You will clean the coil in the unit,I use a wire brush and coil/evap cleaner.I dont typically clean the blower but if you must there will be 2 or 3 screws and some electrical that you will need to disconnect.then the blower assembly will slide out and you can clean it outside,Note where you disconnect the electrical connections --good luck!
Posted on Sep 09, 2009
Testimonial: "Thank you !! It worked! The A/C is running and the cost of the cleaner $11.00 (home dep) ~vs~ $325.00 that AIR ZONE A/C in Oldsmar, Fl wanted to charg"
  • 1033 Answers
SOURCE: I replaced a comfort air hander with a Goodman air handler with a 4-ton coil.
Hello, here is a link to a chart with piston sizes http://www.acwholesalers.com/v/vspfiles/assets/images/gsc1314_piston.pdf
Posted on Dec 02, 2011
How does ac evaporative coil with piston work?
the evaporater coil's piston acts as a orfice. the size of the piston hole allows a certain amount of refrigerant through at design pressure. it produces a designed temperture drop at designed cfm of air across it.
Jun 19, 2014 | Goodman Heating & Cooling
Piston size for 3ton indoor coil
if you have a 3 ton condensor it is .074. the piston is sized according to mfg. instructions for condensor
Jun 04, 2014 | Goodman Heating & Cooling
What is the correct size for evaporator coils piston ?
.078 is Shipped with Coil
Note: For a properly matched system and piston sizing information, refer to Goodman piston kit chart of the corresponding Goodman
outdoor
unit.
Oct 26, 2012 | Goodman Manufacturing Goodman CAPF3642C6...
I have a SSX140241A - 2 Ton 14 SEER R410A Goodman Air Conditioner Unit with a CAPF1824A6 - Goodman 1.5 to 2 Ton Cased Evaporator Coil. The coil came with a size 59 piston and the outside unit had a size 55...
No, it simply has to do with the fact that the conditions are exceeding the innate capabilities of the unit. Need more refrigerant and larger condenser and evaporator. Basically, a bigger, more powerful unit for the conditions encountered.
Sep 22, 2017 | Heating & Cooling
EVAP COIL REPLAESMENT PART # MODEL # CK36-1B
You will want to pick up a 3 ton coil. The 36 stands for 3 ton, 42-3.5 ton, 48-4 ton and so on. When replacing coils, the biggest thing to worry about is size and diminsions
Jun 22, 2011 | Goodman Heating & Cooling
Sep 08, 2009 | Goodman CLQ36AR49 Air Conditioner
Goodman a/c not cooling
It looks like you did make some improvements when you replaced the coil and metering devise. The fact that this system never ran right "out of the box" is suspicious. My first instinct is that the system is either unmatched in size or the whole system is sized incorrectly. Do your Heat gain/Loss calcs and see if it matches close to what is in there, both for the coil and condenser. Secondly double check that the evap you installed is matched the same as the condenser. In some situations the ID coil can be over sized by a 1/2 ton. But that is the only exception and it does not apply to all cases.
If the system is sized and matched correctly, then I would consider the compressor to be the problem.
Jun 28, 2008 | Weather King 10AJA2501AH Air Conditioner
Coil piston
May 17, 2008 | Goodman Heating & Cooling
Heating & Cooling Logo
105 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
