Recover administrator password for 3com 3c17302 switch using console
Bought used switch can't login using console because didn't get administrator pw for switch admin admin doesn't work
SOURCE: Lost login Username and Password
How do I use the reset the password on my DES-3226?
Posted on Mar 02, 2008
SOURCE: inherited 2 switches 3com 4228g (3c17403) password problem
I haven't worked with these switches but generally settings such as ip address and factory defaults can be set through the Console Interface (CLI). You will need a null-modem cable to access this and a terminal client (Windows Hyperterminal works).
Hope that helps
Posted on Jan 01, 2009
sandeep239
  • 59 Answers
SOURCE: Wants to reset 3824 3com switch via console
You forget the password for the "admin" user account and can no longer perform important management operations. solution.gif Use the password recovery method outlined below to define a new password for the "admin" user account:
  1. Access the Command Line Interface from the console port and enter the user name "recover" and password "recover" to place the Switch in password recovery mode. The Switch remains in password recovery mode for a maximum of 30 seconds, before it returns to the CLI login prompt.
    note.gif You must use the console port to recover the passsword. If you attempt the recovery method using the network, the password will be rejected.
  2. Perform a hard reset on the Switch whilst it is in password recovery mode by switching it off, waiting a few seconds, and switching it on again.
    note.gif You cannot use a soft reset operation to reset the password of the "admin" user account. This will end the password recovery procedure and return you to the CLI login prompt.
  3. When the Switch has rebooted following the hard reset enter a new password for the "admin" user account.
Posted on Mar 05, 2009
SOURCE: Default password is incorrect or reset doesn't work
The default ip is 192.168.1.1
default user-name and password for the 5 models of 3com are as follows.:
1.
3com default ip: 192.168.1.1
username: n/a
password: admin
or
2.
user-name: adminttd
password: adminttd
or
3com default ip 192.168.1.1
user-name: admin
password: n/a
or
user-name: n/a
password: PASSWORD
OR
5
user-name: root
password: !root
ok try
this
Note that at time you will need to set your local ip of your pc from which you are acess the device to the same range...
That is for example 192.168.1.10
Good luck
uttam
Posted on Feb 26, 2010
  • 121 Answers
SOURCE: i forgot my admin password
If it's the Power Plus (3C16475BS) model, there should be a reset button inside a small hole on the back. "10 - Recovery Button" Inserting a paperclip or similar to reset. If it's not the Power Plus model and is in fact (3C16475A), this is an unmanaged switch, with no administrative capabilities. You don't need a password.
http://www.3com.com/products/en_US/detail.jsp?tab=features&pathtype=purchase&sku=3C16475BS
Posted on Feb 25, 2011
Remove password password
Reset Administrator Password ' Free and Fast Methods to Reset Administrator Password
Are you looking for ways to reset administrator password? Do you believe there are several free and also fast methods to administrator password reset? Windows Password Recovery Tool can release all your doubts!
Feb 17, 2011 | Sylvania G-Netbook
I forgot my pssword and I can´t LogIn
I believe probably the easiest and safest way for you is remove your Windows OS Passwords with Windows Password Recovery tools. I found a good one at http://www.reset-windows-password.com last week, and then I downloaded it and used it to remove the lost password within only few minutes. Furthermore, the powerful tool didn't cause a little data lose. It's worth an attempt.
Nov 13, 2010 | Biostar MCP6P-M2 Motherboard - v6.0,...
Hoe do you reset a 3Com Superstack3 3870 to factory defaults?
Username: recover
Password: recover
*** Password Recovery Mode ***
The administrative password will be cleared if a hard reset operation is
carried out on the device within 30 seconds.
If a hard reset operation is not carried out during this period, the device
will return to the CLI login prompt.
Nov 09, 2010 | 3Com (3c17462)
I got a acer aspire 5334 laptop with windows 7 home premium, & I am the only user on the laptop. I am stuck at the login page because I forgot my password . I typed in millions of different passwords....
You don't have to reinstall Windows 7, here are some method I know:
1. Log on your computer by using built-in Administrator account in safe mode, its password is default blank if you never change it. So that you can use it to change all other user password.
2.Use a password reset disk if you have already created.
3.If the methods above are unavailable,you have to reinstall your system,or else you must use a password tool to crack it.
Recomend you to use "Windows password rescuer professional",it is simple and safe,and can recover windows password in several minutes.You can free download here:http://www.daossoft.com/download.html,and try it free if you need. Follow the steps you can easily recover the password,It is only four steps:
11_24_2011_2_36_03_pm.jpg Step 1: Download Windows Password Rescuer
Step 2: Burn bootable CD/DVD or USB flash drive
Step 3: BIOS setting,setup your computer boot from CD/DVD or USB
Step 4: Reset Windows password by a few clicks.
GO to Windows Password Rescuer official site: ' http://www.daossoft.com/ 'for more info.
Aug 21, 2010 | Computers & Internet
It requires me a password before the windows can be open
If you have forgotten to password then you need to reinstall Windows.
If you have not set an administrator password then you can login as administrator and the reset your login password.
Sep 14, 2009 | Toshiba Computers & Internet
Mar 05, 2009 | 3Com SuperStack 3 3824 (3cr17402-91-uk)...
Computers & Internet Logo
296 people viewed this question
David Payne
David Payne
