Question about Nintendo Wii Console
I cannor get my profile onto the Wii fit starting page.
We have added more than 8 Wiis and have reduced down to below 8, but still cannot get the newer ones to show up on the profile start page to atart exsercises.
How can we get, for example guest K to go away?
  • 31 Answers
U xpaned the mii
Posted on Jan 09, 2010
Can't add wiimote when playing Cabelas Big Game Hunter 2010
If it is a one player game the wii disconnects other controllers to save battery. Some games say 2 player but in the fine print you learn that it is only online (with other wiis)
Jan 05, 2014 | Activision Cabela's Big Game Hunter for...
How do i fit reducing ring 16mm bore onto a30mm bore table saw blade, to use on a draper table saw
the reducer should fit right onto the shaft, if its the right size. Mic it to ensure. Then the blade should fit on no prob. I use a 30mm to 5/8" adapter on my own General 50-185 saw. Quality(sizing) of adapter is an issue.
Aug 02, 2012 | Saws
I have just got a new HP 1050 Deskjet J410 Series printer. I am not able to increase or reduce a document when copying. What do i need to do?
Press Copy until Reduce/Enlarge appears in the top line of the dis
The following options are available in the Reduce/Enlarge menu.
you will have three choices.
Reduce/Enlarge
Actual Size
Custom 100%
Full Page 91%
Legal > Ltr 72%
Also:
Use Photo Fit to Page when you want to automatically enlarge your original
photo to fill the printable area of the paper size loaded in the paper tray.
Photo Fit to Page only enlarges original photos that are standard photo sizes. The
standard photo sizes are as follows:
• 3.5 by 5 inches (9 by 13 cm)
• 4 by 6 inches (10 by 15 cm)
• 5 by 7 inches (13 by 18 cm)
• 6 by 8 inches (15 by 20 cm)
• 8 by 10 inches (25 by 25 cm)
For originals containing text or photos that are not a standard size, use Reduce/
Enlarge.
Manual is HERE Copy functions start on page 27.
Mar 27, 2011 | Office Equipment & Supplies
Can I use a Wii console bought in the USA, in Indonesia?
Seems that Wiis are "region-locked". This is all a bit vague but in general they don't work outside their original region-----so I gathered from the Forum section of the Nintendo Wii website. Difficult to get information on this and how to unlock them.
Feb 03, 2010 | Nintendo Wii Fit for Wii
Wii fit profile calendar shows 2007 instead of 2009. Can only advance forward to 2008.
This cannot be fixed from the wii fit menu. Instead, go to the main wii console menu. In the lower left corner, there is an icon for "settings". The date & time can be changed from there.
When you go back to the wii fit it may tell you it's been 700 or so days when you last worked out. But the date will be fixed.
If you have been using the wii fit for any length of time, DO NOT delete your wii fit profile as this will cancel out any new excercises or balance games you have opened up with your profile.
Jul 31, 2009 | Nintendo Wii Fit for Wii
Playing WIIs Sonic Zero Gravity we are not able to setup multi players, any suggestions?
The trick is, you have to sync up the 2nd controller to the Wii before starting the game.
Turn on the Wii, there's a small cover below the DVD drive that you flip down, (This is also the spot where your SD Memory card can go) There's the red button.
Open the battery area of the 2nd Wii remote. You'll see a small red button.
Press both the red button the Wii Console & the Wii remote. Then it should turn on & Sync.
Once that's done, start the game. It will then recognize the 2 controllers.
-T
Jan 11, 2009 | Sega Sonic Riders: Zero Gravity for...
Wii remote wont work after installing wii fit
From Nintendo:
  1. Turn the Wii console power OFF by pressing the POWER Button on the front of the console. Unplug the power cord from the wall outlet for a few seconds. After a few seconds have elapsed, plug the cord back into the wall outlet.
  2. Turnthe power of the Wii console ON. When you see the Health and Safetyscreen, open the small flap on the front of the Wii console to find ared button labeled "SYNC." Press and hold the SYNC Button down for 15seconds. This will clear all the syncs on the Wii, allowing you to geta clean start to begin the process described below.
  3. After holding the SYNC Button on the Wii console down for at least 15 seconds, you can now "re-sync" your Wii Remotes:
    1. Withthe first Wii Remote you wish to sync, remove the battery cover on theback of the Wii Remote to find a small red button just below thebatteries.
    2. Press and release the small red button just below the batteries on the Wii Remote; the blue lights on the front of the Wii Remote will blink.
    3. Quickly press and release the red SYNC button on the inside of the white flap on the front of the Wii console (picture).
    4. When the Player LED blinking stops and stays lit, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
    5. This sync procedure (steps "a" through "d" above) must be followed for each additional Wii Remote added to the system.
Jan 02, 2009 | Nintendo Wii Console
Console itself....
You should try to reset the game data by hitting home and rest while playing your game, if that doesnt work go to Wii main menu, THEN hit reset button on the Wii system. And that should do mthe trick it worked for my family!
Feb 27, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
44 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
