Question about Pioneer VSX-454 Receiver
Pioneer vsx-454 not working propley.radio not even hissing,managed to get whisper sound via pc aux,i have cleaned inids?
As stated above,powers on correct,displaysss sweet just on full volume only a slight whispering sound of the music shows up on full volume,radio doesnt even work?
    Novelist:
    Champion:
  • 225 Answers
It sounds like you're not in the right input source (mode) or you have a external source selected. I show your unit as a 1995 model and so check your Tape 1, Tape 2 selection buttons. These "Tape" selection button get dirty contacts that will kill the audio. To clean, with the volume low, press them on and off around 20 times each. This works the contacts back-n-forth and will help clean them.
Posted on Nov 02, 2012
Gurudristi
  • 98 Answers
SOURCE: Pioneer VSX-D209 receiver shuts off when too loud
Dear Tabasco,
Your receiver is basically going into protect mode.
Just check your speaker cabling again. Make sure that all of them are seated properly, none is touching each other or the body of receiver. Take out all the wire and put them back again if necessary..
Some times even a little tiny frayed wire touching the receiver could trigger the protect mode. Be careful, since protect mode is sometimes not fast enough and it could blown a few trasistors in the power circuit.
Just check your speaker as well....whether they play all right thru another receiver or amplifier. its posiible they might be shorting inside. A little frayed wire could also trigger the protect circuit in your receiver.
I hope this should solve your problem.
If everything else seems all right and still your receiver shut down when you raise the volume then it possible that there are bad connections on the main board that are set in.
This would generally happen if the system is slighly old or have dry solder and when you raise up the volume. This should be a simple repair that will not require parts. If you can solder, you will be able to repair this yourself. If not, then a local service center will change the local labor rate.
Hope you can sort out your problem with the above trouble shooting. Let me know if I can guide you further.
Best of luck! Thanks for using FixYa!
Posted on Apr 21, 2009
  • 3 Answers
SOURCE: Pioneer VSX-454 Receiver
ANY NEW universal REMOTE MADE 1984-2001
Posted on Jun 14, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: diagram of pioneer receiver vsx-454 to show wire hookups
This site has the manual for downloading. You need to register but it's free.
Posted on Mar 02, 2010
  • 35 Answers
SOURCE: Pioneer Amp VSX-D409 Volume
I have a VSX D508 Looks just like the VSX D409. Had the same prob with the volume control when I bought it. I first tried the cleaner. Better than what it was but didn't compleatly solve the problem and before long it was getting worse again.
It does have a rotary encoder instead of the traditional varible restance volume control. I finally broke down and removed it from the board and lightly sanded the contacts with fine sandpaper.
This involves removing the whole face from the main board and chassis. Not that bad, a couple screws and some ribbon jumpers and latches and it's off.
Next carefully pull the volume control straight off the shaft, remove the nut under it and lay it face down on a soft surface. Remove the screws that hold the circuit board to the face and slowley seperate the too, you'll have to release some latches also to sepperate them.
If you replace the volume control with a new one or clean the old one you have to go this far because it's soldered to the front side of the board. Yes, it has to be de-soldered from the board.
This control was not designed to be dissassembled but I was able to carefully open it and remove the shaft to totaly expose the contacts for a complete even couple of passes with the sandpaper.
I did have to use some 5-minute opoxy when I put it back together because I couldnt get the metal tabs to close as tightly as they were before it was opened.
I soldered in the volume control, put it back together and it's worked perfectly ever since. I don't know how much pioneer wants for a new one but I can tell you they wanted $69 plus shipping for a new remote for my receiver. And with this style of volume control you might be at their mercy as far as finding one from another source that fits.
Posted on Apr 03, 2010
  • 88 Answers
SOURCE: my pioneer vsx-519V-k amp keeps turning off
check audio ic & component like resistors & capacitors. good luck!
Posted on Apr 26, 2010
Power sub woofer is not working on my pioneer vsx-81txv everything is working all the speakers except the power sub connection at the back all i can hear is the hissing sound when i try to connect the sub...
Hissing? How loud? A sub isn't even capable of making high frequency sounds at normal volumes.
The Pioneer manual would tell you how to enable and test the subwoofer output.
Page 17 and the MACCV procedures on Page 33 (auto) or 43 (manual)
Jun 13, 2011 | Pioneer VSX-81TXV Receiver
Diagram of pioneer receiver vsx-454 to show wire hookups
Feb 28, 2010 | Pioneer VSX-454 Receiver
Hi there. Need some help. I love my pioneer
Get an RCA-to-whatever-size-the-headphone-output-on-the-IPOD-is adapter and jack it into any available aux or line level input.
Feb 02, 2010 | Pioneer VSX-454 Receiver
I have a Pioneer VSX-454 reciever, both 1.25 Amp fuses blown
blue two legged varacter on power supply board needs to be replaced
Jul 12, 2009 | Pioneer VSX-454 Receiver
Sep 20, 2008 | Pioneer VSX-454 Receiver
Pioneer VSX-D608 Optical connection
The manual states that the default association of each digital input in as follows:
  • Optical 1: CD
  • Optical 2: MD
  • Optical 3: TV
  • Coax: DVD
Use the "Signal select" button to set the receiver to use a digital input, and the Dolby/DTS button (above "Signal select") to enable decoding.
As samz11 stated above, a remote is required to alter the digital input mapping.
Sep 19, 2008 | Pioneer VSX-D608 Receiver
Connecting 2 stereo amplifiers using one as a preamp and the other as a booster
I would take from the tape out of the pioneer and feed into the aux input of the marantz you will then have to adjust the volume levels on each amp as required
Oct 28, 2007 | Audio Players & Recorders
Pioneer vsx d512
All you have to do is connect the coaxial out from pc to any audio i/p at the back of vsx d512.but ensure you select the right channel to play the audio ( eg. tape i/p select tape at front control, aux i/p select the aux at front control )
Aug 03, 2007 | Pioneer VSX-D511 Receiver
Poor sound
You need to connect most turntables to a PHONO input or buy a PHONO preamp. Many newer receivers do not have a PHONO input. The AUX port you are using would work fine for a device like a CD player, but turntables need to be amplified. You can buy an external Phono pre-amp from Radio Shack. I don't know anything about this site, but something like this device should work for you. http://www.phonopreamps.com/tc400pp.html
Jun 19, 2007 | Pioneer VSX-D711 Receiver
338 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
