Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Stuck bulb in fridge
Can i leave the fridge plugged in when i do the epoxy trick? i really don't want everything to defrost or get warm. But i also don't want to fry the socket or start a fire. Earlier when I used the potato, we could smell it cooking when it was on the filament. Crazy!! Thnx so much
  • 700 Answers
I would definately shut the unit off to do the repair. Electricity is not something that you want to play with exspecially 115 volt because when it grabs ahold of a persoin your muscles freeve instead of release and you can fry yourself real easily. Good Luck and have a Happy New Year.
Posted on Jan 05, 2009
Freezer is warming- up to 24 degrees now. something is running- should i unplug the freezer to keep the defrost fan from coming on until repairs can be made?
the fan is not a defrost fan? it helps to circulate the cold air into fridge and freezer. so when the fridge goes into defrost mode the fan and compressor stop running. if ur getting constant warm or heat? I suspect ur defrost timer is not coming out of defrost cycle? the heat is only suppose to last up to 20-30 minutes then back into cold mode? hers a trick u can use that may get u back into cold mode, locate the defrost timer in ur fridge usually at top center. then under the timer u will see a tiny slot or hole. if u stick a small screw driver into that hole and turn slowly clockwise till u hear it click? if its stuck in defrost , it will now come out of defrost and u should hear the fan and the compressor come on, hope this helps let me knoiw if u have any more questions
Mar 16, 2015 | Refrigerators
Refrigerator is warm, ice on back of the freezer. What is the problem?
First check to see if the fan is spinning, it could be stuck in the ice. A full manual defrost is required for starters. Move all the food to another cooler. If the covers will come off the freezer easily, check the fan and the defrost coil.
After the defrost, plug it back in and check the fan, and the defrost timer. It should hum. Rotate it to a click, which will be defrost. Check if the defrost coil works. Leave the timer running, it should restart the fridge after a short time. If it doesn't, get a new timer. Keep checking components until you have your fridge fixed. Have fun, fridges are not too difficult to sort out.
Feb 03, 2012 | Maytag Refrigerators
Frost build up behind/inside back freezer panel
I have same problem, it usually happens after someone leaves door open too long or after 4-6 months. I usually place two frozen milk jugs full of water in the upper fridge and tape the upper fridge door closed at night before bed so the kids don't open and let the upper food get warm., Unplug the fridge and open the freezer and remove all drawers (place excess frozen food in freezer in garage) , leaving the freezer open with a towel in the bottom to catch the melting water from the back panels inside and the next morning wipe the fridge bottom clean and plug it back up and replace everything. I hate that I paid so much for this fridge and have to defrost a couple times a year. However found out too late to return back to the store. It seams like it should have a cycle that heats the back plate every so often to warm and evaporate the ice that collects, but I haven't heard or can't find anything on that.
Jun 16, 2009 | Samsung RB215LASH
Freezer very cold fridge warm.
does the fan come on if not then the fan delay is bad
May 25, 2009 | Refrigerators
Samsung refrigerator freezer not freezing
-2 although below freezing temperature, is not really enough to keep food really frozen. I am presuming we are talking in Celcuis. You need to set the freezer to a lower setpoint.
Mar 09, 2009 | Samsung RB215LASH
Everything in My Freezer is Melting and Fridge is getting warm!
find another place for all of your food because you may need to call a service company.
possible causes: stuck in defrost (if nothing is running) bad compressor (if fans are still running) freon problem if everything is still running
Jun 28, 2008 | Jenn-Air JCD2389G Side by Side...
Warm Fridge
the defrost timer/ board is getting stuck in defrost and when you unplug it and plug it back in it resets the defrost timer/control board. you may need to replace the defrost timer/control board.
Jun 19, 2008 | Frigidaire PLHS237ZD Stainless Steel Side...
Have a 2 year old SAMSUNG RS2545SH Side by Side
Control board has gone bad....
What happens is the defrost is controlled electronically from a circuit board, when this goes bad, the freezer quits defrosting, and freezes the fans that circulate air through the fridge side of things.
To check this, unplug the entire fridge, leave the freezer open, wait for it to defrost a bit, if this causes the fridge to start cooling again when you plug it back in, then its the defrost. You should also see ice crystals on the back of the freezer just under the icemaker.
Mar 05, 2008 | Samsung RS2630SH Side by Side Refrigerator
Bottom mount freezer not getting cold enough
You have a failed component or components in your automatic defrost system. This is why you have excessive frost inside the freezer along the back wall. The timer could be stuck in run mode. The defrost thermostat (bi-metal) could be defective or the defrost heater could be open or shorted.
Sep 18, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
My freezer is working but my Fridge is warm?
Sounds like a typical air flow (circulation) problem. This can be due to an evaporator fan not working, a frozen up coil not allowing air flow over it (due to failed defrost system, etc.) or even the damper for the fridge section stuck closed not allowing cold air from the freezer in. The first thing is to check the evap. fan to make sure it's running. It's easy to take the rear interior of the freezer section off and check for fan operation, solid ice on the coils, etc. If the coils have a nice white frost pattern all over then that's ok, but if they are frozen solid block where the air can't flow over them it's a defrost timer, defrost t-stat or defrost heat element (not likely) issue. Usually it's the t-stat or timer that goes out. The t-stat is easy to visually check to see if it's epoxy is "popped" out and of course a continuity check to be sure. The defrost timer is just a swap out sort of thing, not much to test there.
Jan 10, 2007 | GE Profile PSW26P Stainless Steel Side by...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
47 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
