SOURCE: I have a 1993 honda
not true. the car needs to run at a certain temperature for it to run properly, not too cold, or not too hot. what the thermostat does, is it closes off the water circulation to your engine when it is cold. once your car reaches its normal operating temperature, which is a little less then halfway between the two lines in your temperature gage, it opens up allowing coolant to flow from your radiator to engine and back, and let the coolant cool the engine. if the thermostat is not there, during the winter time, especially in very cold climate, your car takes much longer to get to normal operating temperature, and causing it not to run as efficiently as it should for much longer, leading to more problems in the long run. i hope this helps, and dont remover your thermostat. if you are concerned about it, they only cost 15 dollars at autozone. goodluck.
