Question about Hitachi 53UWX10B 53" Rear Projection Television
Convergence problem Hi all. I've had this 53" for 5 years and have loved it every day I've watched it. A week ago I turned it on and the magenta color didn't line up with the rest. I used the Magic Focus and it stopped part way thru and then a #4 shows up in the lower right corner. The extended warrentee just ran out and I just had it serviced (cleaned)in February. I would appreciate any help someone can give on what chip set I would need to fix this. Also, do I need to purchase the service manual set this back up? Thanks!
I had the same problem sounds identical. My warranty was up in a couple weeks when this happened so they came out and fixed it. They replaced the red converter IC. However just recently the blue and green is acting up??? My warranty is up now so thats a bummer.
Posted on Jun 08, 2007
Have a Panasonic PT-47WX53 47. It's probably as old as when it came out. I've messed around with the convergence before but it was never un-fixable. Then a couple a days ago I came into the ro
yes and also possibly the low ohm resistors. You can get the PT53WX53 convergence kit which fits your model from www.tvrepairworld.com which has the 2 ICs and associated resistors plus the CD with repair instructions.
Jun 09, 2012 | Panasonic PT-47WX53 47" Rear Projection...
Tv restarts while we're watching it
It sounds lamp is weak in tv and need to be replaced.
If lamp has not been replaced in last 2-3 years then replace it to get tv problem fixed.
Thanks.
Jun 07, 2010 | Sony KDS-R60XBR1 60" Projection HDTV
Color shadowing on screen
I had similar symptoms about a year ago. Also came on sudden. The red convergence chip had burned out (poor heat sinking on this model Hitachi). Replacing the color convergence chips fixed it. ($50 for parts.) First, however, have you tried the "magic focus" function? That's explained in the manual, which is available online IIRC, but I'd have to look for the link if you need it.
Mar 02, 2010 | Hitachi 53UDX10B 53" Rear Projection...
LG plasma tv screen is washed in magenta
This is normally only caused by two things, 1st- if your using the RGB inputs make sure the green is securely connected or possibly a bad set of cables. 2nd- If your not using that set up then I would say you have a defective main board. Have it looked at by a servicer if you cant find anything wrong with RGB Comp input cables.
Feb 20, 2009 | LG 42PX4DR 42 in. Plasma TV
TV wont turn on, makes buzzing noise and shuts off
I have two RCA HD52W59 TV's. I have had one for 3 years and one 4 years. The one I have had for 4 years is giving me the problem. Last week the tv turned off while watching it. It wouldnt come right back on. 10 minutes later we tried and it worked fine. the other night the kids were watching and it turned off and smelled like something burning. I tried turning it right back on and got no power at all. I tried to turn it on two days later and it made a buzzing noise and the green light went out. Never did get a picture, no powering up on the screen. Any ideas? Don't want to spend alot of money. Really loved the TV hope it isnt junk now. Better yet I hope the same thing doesnt happen to the other one I have.
Jan 22, 2009 | RCA HD52W59 HDTV Projection Television
3D Looking Colors
yes its most likely the STK392-110 ICs change both at the same time. You can get replacements at the following link with free instalation instructions.
http://servicemanuals.vstore.ca/
Jul 31, 2008 | Panasonic PT-53WX54 53" Rear Projection...
NO PICTURE
The leading cause of this type of failure is convergence.. Replace both convergence Ic's Stk392-110 and check all 2.2 ohm resistors in that circuit... This repair on this particular unit is fairly easy because the convergence amps are mounted in such a way to easily remove the left board for field servicing...
Have a great day!
Bill
Nov 03, 2007 | Panasonic PT-53WX42 53" Rear Projection...
HITACHI 53UWX10BA
Hi there, Check IC601, C603 for leakage, I601 and vertical pulse detector QN05 for poor convergence check RK42 for open circuit. Best regards, Arpi
Jun 16, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi 53swx10b
The convergence Ics need replaced. In Hitachi, resistors and sometimes a coil needs replaced as well. The convergence/deflection PCB is available, but, the cost of that board is higher than having a servicer come to your home and repair the unit to component level. If you are not familar with this circuit, then call a servicer. Have them replace both ICs not just one. Make sure they are repairing to component level and not replacing the board. Hope this helps.
Mar 30, 2007 | Hitachi 53SWX10B 53" Rear Projection...
Open Questions:
See all Hitachi 53UWX10B 53" Rear Projection Television Questions
Hitachi 53UWX10B 53" Rear Projection Television Logo
75 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
