Screen Display I have attached a 2216Vw computer monitor to my 4 year old Windows XP computer.I cannot get the screen display to look normal - round things are still elongated sideways football shaped.I have done multiple things trying to resolve it with the driver and with the screen menu options to no avail.The text is also blurry from line to line - shadowing.
  • 2 more comments
  • xanethar Jan 03, 2009
    Hi
    Adaptor Description - SiS 661FX
    Adaptor Type - SiS 661 Rev00 SiS Compatible
    Fiona
    I have a P4S800-MX Motherboard (whatever that is).
    If I run that will I be able to connect on-line with an update source ?
    I have attempted to load the 2216Vw driver direct from the AOC website as well as the disc that came with the monitor. I can get so far with the installation then get a message saying no update is needed to use the device.
    If there was a simple solution to alter the way things are stretched on the control panel thing that changes height, width etc it would be a piece of cake - but nothing there makes any difference.
    Regards, Fiona.
  • xanethar Jan 04, 2009
    Thank you. I have now downloaded VGA Driver V 3.59 and half way through the installation process I get "update for plug in error". I can't get any further.
    Should I try reloading the software I initially loaded with the new monitor from their disc ? Or is this just going around in cicles ?
    Fiona.
  • Dick
    Dick May 11, 2010
    To find out what video card you have if you are running Windows XP press Start, All Programs, Accessories, System Tools, System Information. When that comes up expand the Components section by clicking the + sign next to the word components, then click Display. Your video card is shown on the line Adapter Description.
    Please provide video card information.
    President:
  • 948 Answers
The SiS 661FX is a chipset that has onboard video. Your motherboard manufacturer (or computer manufacturer if you have a name brand unit) should have the latest video drivers for your motherboard. Installing those drivers should fix the problem.
If you have already installed updated video drivers, post what you installed and where you got them from and we can go from there.
Posted on Jan 03, 2009
  • Dick
    Dick Jan 04, 2009
    Go here and download and install the VGA drivers -http://support.asus.com/download/downloa...
    Version 3.59
    is the most recent one. Install that if you have an older version. If you already have that version all I can suggest is buy a video card and put in there instead of using the onboard card.
Rotate screen back to normal
Computer users occasionally have a need to rotate, or "flip," a monitor display to be better able to read long documents or to view pictures. Because rotating a computer screen is such a basic function, modern operating systems (Windows XP and up) include hot keys and display options that enable the user to rotate the computer screen by 90, 180 and 270 degrees. Rotating the computer screen allows for more display options. For instance, when rotated 90 degrees, a 1680x1050 monitor becomes a 1050x1680 monitor, which provides more vertical pixels than a standard display.
Windows XP/Vista Monitor Orientation
Minimize any windows or programs to the taskbar. Click the desktop. Press "CTRL" + "ALT" at the same time. Press one of the arrow keys to flip the monitor orientation by 90, 180 or 270 degrees. The left arrow rotates the computer screen 90 degrees; the down arrow rotates the computer screen 180 degrees; the right arrow rotates the computer screen 270 degrees; the up arrow resets the monitor orientation. Rotate the computer screen in Windows Vista by opening the Control Panel, searching for "Tablet PC" and changing the "Orientation" drop box to the desired rotation. b> Windows 7 Monitor Orientation b> Click the Start menu at the lower-left hand part of the screen, and open the Control Panel. Select "Display," then click "Change display settings" from the left column. When using multiple monitors, select the monitor that you would like to rotate. Click the drop box next to the "Orientation:" option. Select the desired rotation and click "Apply." Click "Keep Changes" or "Revert," depending on preference. Click "Apply" in the Display Settings window. Click "OK" to finish.
Feb 23, 2013 | Gateway Computers & Internet
My Samsung n120 screen is displaying only vertically - how do I go back to horiz display?
Feb 15, 2013 | Samsung N120-12GW Netbook
The screen has shifted to the right so that i cant see the [X]on any windows. Ive already maxed out the left shift but its still stuck to the right.
does the screen appear distorted;does it move as you shift left/right/up/down? IF THIS IS TRUE, YOU PROBABLYHAVE THE RESOLUTION SET WRONG....RIGHT CLICK ANYWHERE ON THE SCREEN;PROPERTIES;SETTINGS; ADJUST SLIDEBAR TO PROPER RESOLUTION FOR YOUR MONITOR
Mar 07, 2010 | AOC 2216Vw 21 inch LCD Monitor
Lcd screen stuck in external screen mode
How to use the function (Fn) keys on the keyboard - ThinkPad T40, T40p, T41, T41p, T42, T42p, T43, T43p
Switching the display output location.
Switch between the computer display and an external monitor. If an external monitor is attached, the computer output is displayed in the following three patterns by turns:
  • External monitor (CRT display)
  • Computer display and external monitor (LCD + CRT display)
  • Computer display (LCD)
Notes:
  • For any operating system other than Windows 2000 or Windows XP, no additional procedure is needed. Just press Fn+F7.
  • This function is not supported if different desktop images are displayed on the computer display and the external monitor (the Extend desktop function).
  • This function does not work while a DVD movie or a video clip is playing.
To enable this function in Windows 2000 and Windows XP, the following procedure is needed:
  1. When you log on to Windows 2000 and Windows XP for the first time, press Fn + F7 and select a display-switching function in the Initial setup window. Since in Windows 2000 and Windows XP multiple users can log on to a single operating system by using different user IDs, each user needs to select the function in the initial setup window when logging on for the first time.
  2. If the Fn + F7 key combination have been assigned to a presentation scheme function, start Presentation Director, and change the settings.
Feb 28, 2010 | IBM ThinkPad T41 Notebook
Plugged in a new 23 inch LG LCD Monitor and cannot get picture
In additio to the fine help given by Mister.
If you have a DVI output on your computer get the cable for that and this will greatly increase the quality of your display.
Your graphics card should be able to autodetect a DVI monitor and suggest the best display type.
Sep 16, 2009 | Computers & Internet
I had to reinstall my Viewsonic monitor after getting a new hard drive. Now the screen shows everything is a horizontal stretched mode. How do I get it to normal aspect ratio?
It seems like the display resolution was not set to the optimal resolution for your monitor.
To correct this, follow this guide. I am assuming you have Windows XP.
1) Navigate to the Control Panel in Microsoft Windows by left-clicking on Start, followed by Settings and then choosing Control Panel.
2) In the Control Panel window, open Display.
Note:
In Microsoft Windows XP, depending on how your operating system is setup, you may not see the Display icon. To correct this, click on the link on the left-hand side of the Control Panel window that says Switch to Classic View.
3) In the Display Properties window, click on the Settings tab.
4) Slide the Screen resolution slider all the way to the right for your optimal resolution.
5) Click the OK or Apply button to confirm the changes. If prompted, follow any additional on screen directions.
NOTE: If the text appears too small, go back to step 4 and try a different position on the slider until you get it how you like it.
Good luck on solving your computer problem.
Aug 27, 2009 | ViewSonic VA2226w 22" Widescreen LCD...
My AL1916W monitor will accept the Windows XP Pro output for a while but then presents a message which travels round the screen "Input not supported" and I can do nothing. It works OK with another CPU -...
It is display screen resolution issue.
When you power up the computer press F8 key then enter in enable vga mode then go to control panel ->display->settings
then change screen resolution to 1024*768 then restart then check.
Jul 30, 2009 | Acer AL1916W 19" LCD Monitor
Green display on boot up Please help
Check to see that there are no machine BIOS settings that could affect the monitor. Normally, the bios controls display until the OS takes over. If your XP screen after bootup looks fine, I don't see how you have a problem with your monitor setup under Windows.
Jul 03, 2009 | Computers & Internet
ViewSonic 19" flat screen monitor goes black - intermittently
There could be a problem with your display card settings or the display card itself. If you are using Windows operating system, make sure that you have the monitor driver installed for that specific monitor. This is to ensure that Windows only allows settings for which your particular monitor was designed.
Let me know if I can assist you any further regarding this.
Best wishes,
Graemevm
Jun 12, 2009 | ViewSonic Optiquest Q9b 19" Flat Panel LCD...
Computers & Internet Logo
129 people viewed this question
David Payne
David Payne
