Question about Williams (5009622) Ceramic Gas Wall Mounted Panel Heater
Wiallwialliams wall heater wont stay on installed new thermo coup aready
Piolot lites burner goes on but after a short while it all goes off
  • 499 Answers
Get a AA battery and tape a wire on each end, then attach the wires where the pilot generator wires to, mv/pv and pv usually,if it runs this way the valves good, the pilot generator makes 750mv or 3/4 of 1 volt, by the dissimilar metals in the pilot generators numerous thermocouples, they make 30mv each and are used on water heaters only now.
Dont run it with the battery if you sleep! test only.
Posted on Oct 31, 2012
5 Suggested Answers
SOURCE: williams wall heater
i'm having the same problems.......................
Posted on Oct 29, 2008
SOURCE: Wall heater pilot light
As it turns out there is an emergency shut-off valve connected to the vent that was triggered by high winds. The reset button is hidden on the upper left hand corner of the unit (as you are facing it) behind a small grill on the side of the outer casing. Logic tells me that it's there so in the event of a clogged vent you don't fill your house up with carbon monoxide. One push on the reset button allowed the pilot to stay on and therefore the heater to fire up.
Posted on Dec 28, 2008
  • 3 Answers
SOURCE: heater lites then goes to low flame will not stay on high flame
Pilot sensor or thermocoupler
Posted on Feb 04, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: model SRPH02 BURNER WILL NOT FIRE
Bad flame sensor. Try to clean it with some steel wool
Posted on Apr 24, 2009
Basemnt flooded water heater wont stay lit ever since, taken out burner assembly severl times now stays on long enough to heat water then shuts down soon after.replaced thermocoupler and have to lite...
Sounds like the air intake is clogged, and pilot and burner tubes are dirty.
All manufacturers say that flooded water heater should be replaced and not repaired.
You can clean air intake and burner assembly, and then next step would be to replace burner assembly and replace gas valve thermostat to see if functionality returns.
Expense of replacing parts is about half the cost of new gas water heater from box store, and still no guarantee that old heater will work.
http://waterheatertimer.org/How-to-install-gas-water-heater.html#clean
Jun 22, 2011 | Water Heaters
Cant figure out how to relite my furnace
on the bottom of the unit there is an access door remove it and behind it you will find a gas valve and a pilot find the piolot......turn off the gas valve and move the selector to piolot depress the switch and at the same time place the flame from a log lighter onto the pilot light after this lights turn the gas valve to run and the burner should light.
Mar 03, 2011 | Empire Direct Vent Wall Furnace;...
Pilot light on water heater wont stay lit
The thermocouple has failed. It is the temp probe that goes from the pilot lite burner area to the control valve. Go to your local plumbng repair shop and buy one. Most appliance parts stores have them also. Take the old one with you and they will hook you up with an exact replacement. They are not that hard to change. Usually a nut or 2 screws in the temp bulb area at the burner end and a nut that threads into the control valve.
Make sure before you install the new one that the area where it mates to the gas valve is clean. Should be about a 20 min job including clean up with replacement parts in hand.
Jan 23, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
Model SRPH02 BURNER WILL NOT FIRE
Apr 24, 2009 | Williams 2509612 Ceramic Mid-Size Heater
The heater won't stay lit
CHECK YOUR EXHAUST VENT MAKE SURE THAT IT IS NOT PLUGGED OVER HEATING THE UNIT.ALSO IF IT HAS A FLAME SENSE BAR CLEAN IT AND CLEAN ALL SENSOR OFF.AND MAKE SURE ALL WIRE CONNECTIONS ARE PLUGGED IN TIGHT.
Jan 16, 2009 | Desa International CBN20T Heater
Burners wont ignite
does unit have thermo-cupling
Nov 23, 2008 | Carrier 52PQ307 Wall/Window Air...
Nexgrill patio heater won't stay lit
I called Nexgrill technical support at 1-800-913-8999. They are sending me a new thermo couple to keep the valve open when ignited - so the patio heater will stay on. I needed to give them the serial number (inside the propane tank door) and fax them a copy of the receipt.
Hope this helps.
Jun 01, 2008 | Williams 2509612 Ceramic Mid-Size Heater
Williams (5009622) Ceramic Gas Wall Mounted Panel Heater Logo
156 people viewed this question
Top Williams Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Mack Baxter
Are you a Williams Heating and Cooling Expert? Answer questions, earn points and help others
