Question about Sewing Machines
Hi Debbie I have borrowed an Elna 2002 (N 13847) sewing macine and can't open the left hand top section to allow me to thread it. I don't want to force it so can you let me know how it opens
The mahine is a simple model and has not been used for years.
SOURCE: Sewing Machine Elna 6000 model
Cannot get top thread to catch and uplift bobbin thread, have changed bottom bobbin; think this may be shuttle problem. Need to get machine in to Polokwane in Limpopo Province to a repair center, cannot find a contact number of Elna there. Can you assist?
Posted on May 27, 2008
SOURCE: Need help threading machine
I have the same problem
Posted on Sep 21, 2008
  • 240 Answers
SOURCE: how to thread bobbin on Elna SU
Please describe the type of bobbin you have. Is it held inside of a removable metal casing? Or is it a dropin type? Is the sewing machine what is known as a "freearm" which you can put a sleeve or trouserleg over or is it a flatbed type? When I know this I can help you further.(I used to sell sewing machines).
Posted on Jun 11, 2009
SOURCE: I have a Janome MB4 and have had so many problems
Hi!
I was having the same problem(s) and I loosened the tension on the bobbin case and switched to prewound paper bobbins and everything sews beautifully.
Hope that helps!
-Donna Jo
Posted on Sep 08, 2010
Tally Girl
  • 1129 Answers
SOURCE: My elna sewing machine bobbin
If the fly wheel is going around then the clutch isn't disengaged to wind the bobbin, you need to pull out the flywheel on your model to disengage the clutch for bobbin winding.
Take thread from thread spool across to bobbin winder thread guide, then back to bobbin and thread the tail through the hole on top of the bobbin. Place bobbin onto spindle on top of machine and then push it against the stop to engage the bobbin winding motor. HOld the thread tail up and start winding slowly until the bobbin core has been covered including the starting point. Stop and trim off the thread tail with scissors. COntinue winding bobbin and give the thread a nudge if needed to wind evening top middle and bottom of the bobbin. A good smooth wind is important. Also don't wind at full speed and keep an eye on the thread reel that the thread is coming off, you don't want it bouncing around as this will **** the thread and stretch then relax it affecting your bobbin wind.
Obviously if you know this and the bobbin winding mechanisim is just not working, then it will need a service/replacement by an Elna repair person.
Posted on Aug 02, 2011
How do you adjust the tension control on an Elna lotus SP
The tension dial is on the front of the machine right above the needle. The higher the number, the tighter the tension is applied to the top thread. HINT: When threading the top thread, ALWAYS RAISE the presser foot throughout the entire threading process. This allows the thread to seat completely in the tension disk. Tension is correct when the top and bobbin threads meet in the middle of the fabric.
Elna Lotus Instruction Booklet
Elna Lotus SP bobbin case repair Removing cotton jam from Elna Sewing...
Elna SP ST SU sewing machine repair tips (I use liquid Tri-Flow Synthetic Lube or silicone spray to loosen parts seized from old oil. Do NOT use WD-40, cooking oil, motor oil...)
Apr 29, 2017 | Elna Sewing Machines
I inherited my mother's Elna Lotus SP sewing machine. She had the sewing guide inside the machine, but not the instruction manual. I need to know how about the bobbin and how to thread?
Hi Jeanne, you might want to check out my tip on early Swiss Elnas,
http://www.fixya.com/support/r10602655-acquired_early_swiss_elna_sewing
it should help you get the Lotus going. Lovely machine. If you are in the USA you may also want to contact White Sewing Center as he may have this manual available for sale or a copy of it. www.whitesewingcenter.com.
Remember to use the Elna 7 hole dished metal bobbins, there are 7 holes on the top, and looks like this11_7_2011_6_23_57_am.jpg
Always wind it and insert it into the machine this way. Don't use any other bobbin. Standard needles 130/705H, flat shank to the back.
Check out my other tip on bobbin winding too, it is important to keep tension onto the thread spool that you are winding thread off as the machine doesn't tension the thread for you. So you need to apply pressure to the top of the thread spool as you wind off, use the curved handle of your scissors on the top of the spool.
Feel free to connect to me and ask if you have any other questions, I have a Lotus TSP at home and its almost identical to the SP. Happy stitching.
Oct 30, 2011 | Elna 2007 Mechanical Sewing Machine
Bunching bobbin thread elna 1010
Firstly remove the bobbin and case and give the whole area around the bobbin a good brush out, removing all lint and fibres from the area completely, don't blow it inside the machine deeper. Then if it has marked oiling points, give them a drop of clear quality sewing machine oil.
Now, check that the bobbin thread is fully into tension spring and that the bobbin is in and rotating the right way in the case. Also check the way the thread is wound onto the bobbin, many users have never been shown the right way to wind and just go flat out. You need the bobbin to be wound smoothly and evenly right across the middle top and bottom and you don't want the thread to be wound on with varying tensions on it or it relaxes unevenly in the seam causing puckers.
See my tip on bobbin winding here: http://www.fixya.com/support/r10598580-winding_bobbin_correctly
Then check top tension is set at the mid range number, usually 4 or 5 and that it is also fully seated into the tension discs. Always thread with the pressure foot raised so the discs are open for the thread to seat in.
Change the needle, and check stitch length is appropriate for the weight of fabric being sewn, usually 2.5 length is fine.
Now test sew again and hopefully the stitching is now more even.
Oct 21, 2011 | Elna 1010
Can someone help me with threading my Elna Serger?
A model number would be helpful
Follow the Colour Threading guide on the machine....
Basically......Start with the Loopers (from Right side) finish with needles (Left side)
So....4,3,2,1 in sequence .....1 is first then work to the left
Oct 19, 2011 | Sewing Machines
How do you put a bobbin in a elna so i can use it to sew
Drop in a full bobbin with the holes side upwards (I'm assuming this is a Swiss Elna sewing Machine horizontal bobbin design as you haven't given the model number).
Now, hold the thread tail with your right hand and pulll the thread clockwise towards you while holding the bobbin still with a finger from your left hand. Bring the thread tail around towards you until it goes into the little slot, then press downwards onto the thread tail close to the bobbin until you hear it click into the tension spring. Test by lifting the thread tail upwards, it should stay in tension and not come back out of the groove.
Now close the back slide cover over the bobbin leaving the bobbin thread tail visible out to the right.
Now manually turn the flywheel towards you while holding the top thread tail and take the needle down into the bobbin holder area and back to the top, pull the thread tail to bring the bobbin thread up to the top.
There is a threading up diagrams at www.sewusa.com http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Elna_Sewing_machine_threading/Elna_Supermatic_threading_diagram.htm
for the old Supermatic but the bobbin holder design is almost identical for all the subsequent models such as the SU, TSP, Supermatic or Air Electronics like the Stella, Carina or Jubilee, the above is the same for all.
Sep 19, 2011 | Elna Sewing Machines
My elna sewing machine bobbin won't spin on top to wind thread around. The fly wheel spins though...I've been putting thread on the bobbins by hand.
Aug 01, 2011 | Elna 2007 Mechanical Sewing Machine
I've got an Elna 634 overlocker, and want to turn
Just trim the fabric to the desired hem length plus one inch, then overlock around this raw edge with thread close colour match to the fabric.
You then have the choice of either stitching around with a stretch stitch on your sewing machine, or hand sewing.
Being lycra shouldn't change how you hem them unless the trouser leg is extremely close fitting and the hem seam is going to be under tension.
My first choice would be using a twin needle in straight stitch from top side but this finish can pop/break if the hem is under tension. But perfect for most knit hems.
If you hand sew then you can turn up hem allowance and put a length of fusible hemming web inside the hem allowance and press it to hold. Then do a back stitch hand sew around to hold hem in place.
If you sew with the regular sewing machine, then use either the stretch stitch or a very small zig zag, and a ball point or stretch needle.
On ready to wear you would see a coverstitch hem but your overlocker doens't have this stitch.
Jun 12, 2011 | Elna Sewing Machines
I have an elna lotus sewing machine and have refilled the bobbin but cant remember how the bobbin goes back into its place. the machine will sew for awhile and then the cotton gets tangled .can you help...
Is this a Swiss made Elna Lotus with top loading bobbin (check machine plate on right beside power inlet for manufacture details) ? (the original Lotus was released back in 60's but that name has been reused on a number of different models since, some made under licence elsewhere) If yes, then the following applies:
Bobbin should have holes on one side only, always wind it with the holes on top and load it into the bobbin holder the same way so it is rotating anti clockwise when you pull the thread.
Drop wound bobbin into bobbin holder and, while holding the bobbin still with one finger, pull the thread tail towards you into the tension spring, then press down on the thread until you hear it "Click" into the tension spring.
Then hand wind the fly wheel towards you while holding the top thread tail to catch the bottom thread and bring it up to the top needle plate, close the back sliding plate over the bobbin.
Other thing with these machines is ALWAYS hold the two thread tails firmly when you start a new seam so the threads don't get pulled down into the bobbin holder area. Really important.
You can dowload a manual from www.arizonaexpressionz.com for most of the Swiss machines.
If it is not Swiss made one, then your bobbin may be vertical front loading (like the Brothers).
There are threading diagrams for lots of machines at www.sewusa.com, there might be one there that covers your machine.
May 22, 2011 | Elna Sewing Machines
What bobbins will work with a vintage Elna Lotus SP sewing machine?
I did a search and found this post for you. I hope it will help.
The best-known Elna guru is Ray White, aka "Elnaman". He teaches classes on sewing machine repair but his speciality is Elnas. You can order parts or contact him at his website:
http://www.whitesewingcenter.com/index.p…
or you can contact him directly at:
Ray White
White Sewing Machine Center
PO Box 73
Bellview, MO 63623
Phone: 573-697-5841
elnaman@whitesewingcenter.com
You can also join the yahoo group "elnaheirloomsewingmachines" where very knowledgeable Elna owners/collectors share information and answer questions. Enjoy your Lotus!
Sep 02, 2009 | Elna Sewing Machines
Old Elna SU (blue on top with black 'Elna' logo)
You take the thread down the left side of the silver wheel and then gently tug it upwards so that it clicks into the wheel. Then pass the thread through the rear of the thread take up lever(this should be raised), from left to right. Then take the thread down and slip it into the thread guide, down slip into the needle clamp and then thread through the needle from front to back.
Mar 17, 2009 | Elna 2007 Mechanical Sewing Machine
Sewing Machines Logo
29 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
