Hometics SS5000 power supply voltage?
What is voltage, amperage, and polarity of input jack?
  • 127 Answers
READ MANUAL
Posted on Nov 01, 2012
IS SONY SPEAKER VGP SP1 INPUT CONNECTION DIFFERENT FROM VGP SP2 SPEAKER CONNECTION
There may be many different power supplies that will work for your speaker system, but they must comply with the following:
1. The output voltage of the power supply should be correct as what the speaker system requires. (seems like 12 V in your case)
2. The specified maximum current output of the power supply should always be a higher value than the Amperage spec of the speaker system.
3. The output wires or pins of the plug on the power supply should correspond to the (+) and (-) on the power input of the speaker system.
A multimeter will come in handy to determine a power supply's output voltage and polarity.
Jan 25, 2016 | Sony Computers & Internet
Need to know input, polarity and voltage to ensure I have the right adapter.
Complete Guide to Using the Correct Charger or Power ...
www.groovypost.com/.../choose-right-power-adapter-charger-phone-lap...
Jun 24, 2013 - If the device has a DC input of +12V / 5.4A, get an adapter that has a DC output of +12V / 5.4A. If you have a universal adapter, make sure it has the proper current rating ... Ideally, you'll have the same voltage, current and polarity on your ......or hdmi on my laptop .can you say what's the reason for the same.
How to select an AC to DC power adapter - ApogeeKits
www.apogeekits.com/power_adapter_selection.htm
An explanation of regulated versus un-regulated AC to DC voltage power adapters. ...voltage output power adapters and how to use this information to select the right one... Some (more expensive) DC voltage output power adapters have voltage ... Care should be take to ensure that the maximum input voltage of the load ...
AC/DC Power adapter ' Laptop Parts 101
www.laptopparts101.com > Laptop parts
Dec 26, 2008 - It's very important to use the right adapter for your laptop. ... Polarityon the new adapter's plug must be the same as on the original ... AC/DC power adapter voltage and amperage ..... I have purchased an non-hp dc-dc convertor (150W), 12Vinput, 19V output. .... So the cable component has to be replace.
Determining Proper A/C Polarity - Galen Carol Audio
www.gcaudio.com > Resources > How-To's
Jan 10, 2016 | Computers & Internet
What is the power output of ac dc adapter in jensen jta 460? Can this adaptor be changed with 220volt ac dc adapter with required dc output?
For Any Adapter:
As long as the Voltage and Power output of the power supply (wall outlet or other) matches the input requirements for the adapter whether 110V or 220V.at enough amp output; and
IFF the dc output of the adapter is exactly the same voltage and has for amps at a minimum matches the maximum amperage requirement for the input of the device, any of them will work, as long as it has the right connector with the correct polarity needed for the device!
Or, in other words...
Supply Output V = Adapter Input V
and
Adapter Output V = Device V
Adapter Output A(min) >= Device A(max)
Aug 27, 2015 | Computers & Internet
What is the power voltage for the x235 got display model dosent have a power lead
There should be information about that cast into the outside of the display housing, Charlie, or it may be printed in insanely small print on the serial number label. Most likely, though, it'll be cast into the housing near the power jack. It'll also indicate polarity, but it won't tell you which size the power plug needs to be.
If you can't find the voltage & current requirements anywhere but you CAN find the little polarity indicator, you could buy a "universal" power supply with switchable voltage and polarity. Start with the power supply set to the correct polarity and the LOWEST voltage. If it doesn't work, step up one notch and try again. Increase voltage ONLY until the unit functions, and NO higher. Tape over the voltage selector switch when you have it right.
Aug 04, 2014 | Exercise & Fitness
Misplaced my power supply for my 1950x pencil sharpener and can`t find the output or polarity labeled on the thing?
I have the same sharpener. Input is 120v AC 60Hz 16W which is what comes out of the wall in USA.
Output is 12V 800mA and the polarity is positive in the inside of the plug. I'll try to attach a photo to this post.
misplaced-power-supply-1950x-pencil#solution-section-kjptrdwcwv032w1lziamb525-3-0.jpg
Mar 02, 2014 | Boston Acoustics Mighty Mite Electric...
Wht kind of current comes out?
The computer's switch mode power supply produces DC (direct current) electricity.
Nov 05, 2012 | Computers & Internet
HOW DO I RECHARGE SPECIFICE CHARGER OR BY COMPUTER
By computer so that you will obtain the specific charger that you need.
plankw,
What laptop is it? Manufacturer name, and Model Number.
(Bottom of laptop)
Also,.....on the Bottom of the laptop is stated the Input, and Output voltage.
Your concern is the input Voltage, not so much about the Amperage.
(V = Voltage, A = Amperage)
Example;
Input: 12V2A (Sometimes printed as 12V~2A)
12 Volts at 2 Amperes.
The AC adapter (Charger) must also have the correct plug to fit the laptop's DC Power Jack.
(DC IN)
Regards,
joecoolvette
Apr 21, 2011 | Computers & Internet
I need a replacement AC power adapter for FPE1080 TV
Hi, i have personally substituted laptop power supplies for those kind of televisions-make sure the power supply you get is of similar power rating, it should tell you the needed D.C. voltage and M.A. requirements maybe near the power jack-or somewhere on the label. Used power supplies are common at televised thrift stores. Just make sure polarity matches on power supply and tv-careful not to try and force jack into tv-it should slide right in. the voltage is usually 18 to 24 volts with an amperage of 2.5 to 4 amps, or 4000ma or something to that effect, hope this was helpful, Prodzilla
Mar 31, 2011 | Audiovox Televison & Video
Can i buy a new transformer for my digital photoframe
If you can determine the voltage and polarity of the input (often embossed next to the socket) then you will be able to find a generic replacement. Most of these use a standard concentric plug that is a different size for different voltages.
There are power supplies that have adjustable voltages and an array of different connectors, although the single voltage ones are neater. You will also need to make sure that the power supply you get can provide enough amperage or wattage for your frame. If you still have the old power supply you can get the information off of it.
My first stop for buying this sort of thing is Amazon. You can also find many such items on eBay.
Nov 06, 2010 | PANDIGITAL 8.0" Digital Photo Frame...
2Wire 1000HG power supply went bad. Need to replace but having trouble finding one. Would like to purchase in a store
Ok there is generally nothing "Special" about mains, wall power supplies, they simply provide DC volts, via a step down transformer, or switchmode technology, now there are ONLY three important things to know and they are, the Voltages, and Amperage, and Power Plug Polarity. You can often find this A: In the manual under Power Supply Specification, B:Or on the Actual power Supply itself, If one looks carefully, there is always on a UL listed power supply, the Output Voltage & Amperage, often Polarity is indicated too. If not, that can be gleaned usually, by looking besides the power input socket, on the actual unit, and, it usually, has a little drawing, with a dot and a 3/4 circle around it, with a + & - showing what goes where. In almost all occasions, though, it is Positive to the CENTER, & Negative to OUTER, (or earth). All you have to do, is get any other power supply that has the SAME Voltage and Current rating, IE: 12 Volts @ 2.5 Amps. Now any 12 Volt supply that gives, the same or MORE than 2.5 Amps will do. You just need to ensure that the Plug is right, often the plugs are different, that too, can be overcome, simply, by cutting off the OLD, plug, and cutting off the NEW plug, and joining, Old, to New end on PSU. Again, usually, Positive is the Center, and the Negative is the Outer. Right go get that supply. eBay or Radio Shack, are good places to start. Also any other "Laptop" power Supply that has same specs as described, will also work. As a matter of point, switchmode is generally "Cleaner" power than a transformer one.. but it is NOT critical.
Mar 02, 2010 | 2wire HomePortal 1000HW DSL Modem and...
Televison & Video Logo
14 people viewed this question
Top Televison & Video Experts
Electro Med Services...
