Question about Jensen VM9510 Car DVD Player
No Audio on Jensen UV8
Installing new Jensen UV8 in a 2004 Suburban, using GM 2000 wiring harness.
No audio!!! Nothing, no noise, no static, nothing. Checked the wiring, looks good.
Not using the Blue or Blue/White as I don't have a motorized antenna or external amplifier. Not using brown or orange either.
Ideas???
I just bought the uv8. Ist I must say i hate it, it was the worst purchase made. Amoungst others problems, your answer to solve no audio is this.
<<push mute button>> then volume up. you'll have sound. good luck
Posted on Apr 30, 2009
Speakers stopped workin in a 2000 Suburban
If you have a non-original stereo, there may be inline fuses in the wire harness leading to the stereo. Look under the dash with a flashlight and see if you can find the harness. Alternatively, you can pull the stereo from the dash and look at the wires that way.
The speakers can be checked by using a 1.5 volt battery. Unhook the speaker wires from the back of the stereo. Then, using jumper wires, MOMENTARILY connect the battery to each pair of speaker wires. If the speaker is good, you will hear the speaker cone move (it will make kind of a scratching noise) as the battery is connected.
If the speakers check out, and you are SURE that the stereo is receiving power and ground at all the correct points, then I'm afraid that your stereo is likely damaged.
Jan 05, 2014 | Chevrolet suburban player. stereo...
Phase linear uv8
Hola Hope this might help a little. You may have to read. Sorry, I can\'t post too many pics or video, but this link should help I hope. The link provides details and goes over the wiring. If not, google it or check on YouTube.
Instruction Manual - Page 1
http://www.helpowl.com/q/Jensen/UV8/Technical-Support/phase-linear-uv8-schematic/9778
May 10, 2013 | Audio Players & Recorders
I have a 2004 Hyundai Elantra and am trying to install a stereo but dont know what the wiring diagram is..any help?
Personally owning this car and installing several Hyundai stereo's, I would purchase a wiring harness kit from car audio shop or electronics retailer. The wire harness has a plug that connects to the cars wiring harness. This wiring harness kit will also list the wires to connect your new aftermarket radio to the harness. I would also recommend using crimped **** connectors to attach the two harnesses together.
Feb 24, 2010 | 2004 Hyundai Elantra
Radio wiring harness jensen to jeep
Hello rickscarpell,
As far as I know there are no head unit specific to vehicle specific wiring harnesses at all. The aftermarket receiver will have it's own manufacturer supplied plug which most installers pair up with a vehicle specific wiring harness. There are some dealers that will mate the 2 for you providing a plug in solution. One in particular, www.installer.com, in Houston, TX, would solder and heat shrink any 2 harnesses together for about $25. But for the last few days, their website seems to be down. I'm not sure if they have closed up shop or what.
Hope this helps.
Oct 20, 2009 | Jensen Car Audio & Video
Rear Speakers and audio controls no longer work.
Remove your "new" heated gear harness, test functionality of audio. When installing the heated gear run new power and ground wires. Unless installing HD items and directed to use existing circuit. Good troubleshooting practice, if it nolonger works undo what you did then move forward after it works again. Hope this helps.
JP
Sep 16, 2009 | 2004 Harley Davidson FLHTCUI Electra Glide...
Clarion's VRX765VD player - Radio works but Audio in cd/dvd ?
Yes I do. I have a similar problem with my 2000 Chevy Suburban. I need a fix!
Jun 17, 2009 | Clarion (VRX765VD) Car DVD Player
My uv8 wont eject my disk
I suggest you disassemble the radio and take it out that way. While your in you can check on the blockage. Shouldn' t be hard. Good luck.
Jun 07, 2009 | Jensen Car Audio & Video
The UV8 needs to use The Pink wiere to play an CD audio?
I got through to tech support. For problem of no audio from DVD or CD (can only hear radio), reverse the Blue wire (power antenna) and the Blue/White wire (external power amplifier). This should solve the problem.
Nov 26, 2008 | Jensen VM9510 Car DVD Player
Jensen VM9510 Car DVD Player Logo
287 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
