Question about FrancisFrancis! X1 Espresso Machine
Francis francis x1 wiring diagram - FrancisFrancis! X1 Espresso Machine
  • 6 Answers
SOURCE: I am looking for user guide / user manual of the Francis Francis
Go to this site www.redmonkeycoffee.co.uk select expresso machines then FF X1 you will see a link to download manual
Posted on Jan 01, 2009
ThaMp3Doctor
  • 8596 Answers
SOURCE: francis francis X1 the water supply seems to be lacking pressure
I would go ahead and run a solution of 50% distilled white vinegar and 50% water through the machine. If the machine still runs slow after that, pour another 50/50 vinegar/water solution into there - let it run just enough so that the vinegar water starts to drip out, then cut the machine off. Let the vinegar/water sit in the machine for about 20 minutes. Then cut the machine on and let the rest of the solution run through. Then run plain water through the machine to clear out the vinegar. Try brewing a batch and see if the machine behaves normally.
If the above fails to resolve the issue, the FrancisFrancis machines are now owned by illy, so would need to contact them for further TS.
-Tha Mp3 Doctor
Posted on Mar 09, 2009
jmgldsmth
  • 1906 Answers
SOURCE: Francis Francis X1 - Cleaning lime from tank
CLR rinse followed by a vinegar brew then a clear water brew cycle
Posted on May 21, 2009
SOURCE: I recentlty bought a Francis X1 (2000 model). I
There are two different handles made for this unit (I own an X1 and have both). Both of these handles have baskets.
First - The pod handle has a basket area that is very shallow, about 1/3 of an inch deep and the basket has very small holes.
Second - The handle for loose grounds came with two baskets, one for a single dose, and one for a double dose. Both removable baskets have the very small holes for the espresso to drip through.
You must have a basket in the handle in order to use the machine. If you try to make espresso without a basket, you'll just make a mess. Besides, the machine will never be able build enough pressure to extract espresso from the grounds.
Search the net (ebay?) for francis francis x1 handle.
Good luck
  • 3 Answers
SOURCE: Francis Francis X1 Gasket broken
Hello Salmonp,
You can contact Empire Fulfillment at 877-855-4540 for all of your Francis Francis machine needs. The are the authorized service center for Illy cafe and the FF machines.
Posted on Aug 05, 2009
Need repair parts and repair diagram for Francis Francis X!. Water tank tube broken
Call Empire Fullfillment, they have parts lists and manuals they can email to you. You can also order parts.
http://www.empirefulfillment.com/
Feb 11, 2011 | FrancisFrancis! X1 - Stainless Steel...
Francis francis X1---the steam nozzles won't work,
HI Unscrew the chrome tip from the wand. Then check the wand tube for a plug. Insert a paper clip into the wand tip to see if there is a restriction.
Feb 07, 2010 | FrancisFrancis! Coffee Makers & Espresso...
I have a francis x1 coffee machine need a seal
Call 877-854-4141, which is Empire Fulfillment. If you are not sure if the part is exactly right, ask them to email you a diagram of the part.
Oct 12, 2009 | FrancisFrancis! X1 - Stainless Steel...
Hello Salmonp,
Aug 05, 2009 | FrancisFrancis! X1 Espresso Machine
Francis Francis X1 blowing thru ESE pod
Check the group head shower, make sure it does not have any defects(cracks, scratches or unusually large holes).
May 30, 2009 | FrancisFrancis! X1 - Stainless Steel...
May 21, 2009 | FrancisFrancis! X1 - Stainless Steel...
Low temperature
I had the francis francis examined.  It is indeed the boiler, a $200 fix if you could get the part.  Francis Francis X1 is now a brick!
Dec 19, 2007 | FrancisFrancis! X1 - Stainless Steel...
Francis Francis! x1 leaking
Well, to state the obvious, you should call Francis! Francis! at 1-877-854-4141 and ship it to them for repair. It's unlikely you can perform a fix yourself. Have you tried opening the machine up? I got PDFs of diagrams and part lists, which I obtained by calling them at the number quoted above. Good luck! Stephen
Dec 13, 2007 | FrancisFrancis! X1 - Stainless Steel...
FrancisFrancis! X1 Espresso Machine Logo
148 people viewed this question
Top FrancisFrancis! Coffee Makers & Espresso Machines Experts
dharmanos
Level 1 Expert
Joe Lalumia aka...
Joe Lalumia aka...
Jim Goldsmith
Jim Goldsmith
Are you a FrancisFrancis! Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
