Question about Frigidaire Washing Machines
Washer will not turn on,power works to the electric outlet.
Getting no power within appliance,but the outlet works.
    Top Expert:
  • Frigidaire Master
  • 9,472 Answers
What is the model number of your unit?
Posted on Oct 31, 2012
5 Suggested Answers
sdmc73
  • 121 Answers
SOURCE: No power to Whirlpool duet front loading washer
sorry no reset on that model but check the outlet
Posted on Nov 29, 2008
  • 1028 Answers
SOURCE: KENMORE Elite HE 3T
no but there is a control bd it is probably gone
Posted on Jul 31, 2008
  • 1294 Answers
SOURCE: Washer wont turn on
Check the plug of your washer, the fuse in your washer's plug also. You start from there......
Posted on Jun 06, 2007
Daniel S
  • 4323 Answers
SOURCE: Maytag Neptune Washer Front loader
Hi
First open the bottom front panel of the washer and clean the drain pump assembly completely....if the washer won't start after you have cleaned it then it can be due to a bad control board or the door latch assembly. Hope this helps...please post back for further assistance.
Daniel
Posted on Feb 17, 2011
Tip
How to Verify Power from a 110V Outlet
Video about How to Verify Power from a 110V Outlet
  • The first step of troubleshooting a power issue with a machine equipped with a power cord is to verify that the outlet being used is working
    • This video demonstrates a simple method of testing the outlet
  • Make sure that the outlet and appliance have matching plug and receptacle before plugging in
    • Failure to do so could result in injury and/or damage to electrical circuit and/or appliance
  • This procedure is a quick and easy way to test the functionality of a 110 volt outlet
  • Plug in a small appliance such as the fan used in the video and make sure the appliance works
    • If so, you know that the outlet is not your problem
  • You could also use a light, small lamp, or radio for this test
    • Any small appliance that you can plug in and turn on and know the appliance is working
  • This completes our demonstration of testing a 110V outlet for power
on Feb 11, 2015 | Proform Exercise & Fitness
If you have no display and you have power to the machine, then you will need to replace the "control board". Here is the part you need.
Oct 31, 2012 | Frigidaire Affinity ATF8000FE
I HAVE POWER BUT THE CONTROL PANEL HAS NO POWER
see this causes and fix it. God bless you
Check Power
Check the outlet by plugging an appliance into the same outlet the washer was plugged into an running the appliance a hair dryer works good for this it will draw some amperage. If it works fine move on.
Control
To check the control remove the top panel and then remove the console to access the wiring to the control. Find the wire feeding the control from the main power cord. If you cannot visually see this refer to the tech sheet or service manual. Connect voltmeter to the 2 wires feeding the control if it is recieving power and it does not respond replace the control.
Oct 02, 2012 | Maytag Neptune MAH6500A Front Load Washer
My pressure washers motor wont even turn on when plugged into the mains ive tried changing the socket fuze to see if thats the fault but still the same.. any help much appreciated
If an appliance seems to be completely dead, you need to trace the power all the way from the socket outlet to the inside of the appliance.
Check the obvious first and ensure the outlet is working by plugging another appliance into it.
Open the plug and check the wires are screwed securely into the pin terminals.
Often the cores in a cable will break due to metal fatigue at the point where they exit the plug or enter the appliance.
Remove the plug and pull firmly on each cores of the cable. Often they will break and pull out of the cable if the copper is broken.
After that it is a matter of opening the casing of the washer (turn off the power) and doing a continuity test for each core to ensure the wires aren't broken. Do a continuity test on the power switch also to ensure it is working.
Nov 24, 2011 | Karcher Garden
Water starts to spray from the bottom of my Bosch Aquatak 120i when i turn the water on. Is it still safe to use when this is happening
Electricity and water can be a hazard which could be life threatening, but you can operate electrical equipment in a wet environment if you are careful and follow safety precautions. Most import, make sure the electrical outlet you are using for the pressure washer has a working ground plug. Just because an outlet has three prongs does not mean the ground is working. You need to use an outlet tester which is inexpensive from a hardware store or use a multi meter to test the ground for conductivity to earth ground. Your power washer should have a working GFI (Ground fault interrupter), and you need to press the test button to make sure it is working. If your power washer does not have a GFI purchase one from a hardware store. I would also plug the power washer directly into the electrical outlet since an extension cord could have a bad ground connection and will cause the power washer to pull more current from the outlet. Make sure the power washer is raised of the ground so it will not sit in a pool of water. If you follow the safety precautions you should be safe but keep in mind water does not carry the electrical current, it is the impurities in the water which carry the current. Therefore, water could be more conductive depending on the impurity of water. However, it sounds like a loose connection in the power washer which could also be an o-ring or a washer is broken and it would b a good idea to have it fixed.
Apr 29, 2011 | Garden
WON'T TURN ON. PLUGGED IN AND BREAKER IS ON.
Unplug the washer and get a short HD extension cord and plug in to another KNOWN good (has power) outlet. Or plug in a small appliance where the washer was plugged in and see if it works. Designated outlet for washer could be defective. Never work on electrical devices until you have the correct breaker switched OFF. Good luck, best regards.
Feb 01, 2011 | Miele 24 in. G892SCU Plus Built-in...
New GE electric kettle causes wall outlet to stop working.
Your electric kettle in drawing more current than your wall outlet's are made for. Not being able to read your current draw on your GE kettle I would guess you have a bad GE kettle and it needs to be returned to where you bought it.
Oct 09, 2017 | General (102105011) Electric Kettle
Moved Washer and Now no Electrical
Suggestion: You dont need any special outlet. With a tester (you can get this in any electric shop) see if there is power in the outlet. You said it was hot?? It is not supposed to be hot. Try another outlet; & you could unscrew your machine plug to see if all the three wires are okay, ie. well connected, screwed in.
Sep 21, 2007 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
21 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
