Question about Compaq (142307-001) Internal 24x CD-ROM Drive
142307-001 cd rom drive need to buy - Compaq (142307-001) Internal 24x CD-ROM Drive
    Genius:
  • 1,552 Answers
Take the existing CD-ROM to any computer-store, and, for $30, you can buy a compatible CD/DVD reader/writer.
Posted on Dec 28, 2014
2 Suggested Answers
bharat_s
  • 178 Answers
SOURCE: CD ROM DRIVE/DVD ROM DRIVE PROBLEM!
it is infecetd by viruses.. scan for viruses..
please vote for me...im sure this will solve your problem...
Posted on Sep 29, 2009
CD ROM DOESN'T READ DISCS. I NEED TO RE-INSTALL SOME DRIVERS ON MY OTHER COMPUTER, BUT I CAN'T. I WENT TO DEVICE MANAGER-CD-ROM DRIVE PROPERTIES. UNDER OPTIONS DISCONNECT WAS CHECKED. COULD YOU...
Either spend $40 to buy a new CD/DVD reader/writer,
or take the CD-ROM with the files to another computer.
Spend $10 to buy a 4Gbyte USB memory-stick.
On the other computer, copy all the files from the CD-ROM disk to the memory-stick.
Move the memory-stick to your computer, and install from the files now on the memory-stick.
Jul 28, 2011 | LG Computers & Internet
Hello i want buy solution cd-rom driver..... my
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd-rom then plug them back in this should activate the found new hardware wizard or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you will see options to update driver,roll back driver,or
select properties you will have options under general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
Jan 16, 2011 | Dell (074JH) Internal 48x CD-ROM Drive
Cd rom drive problem
Hi, you can purchase cleaning CDs for your CDrom, if this does not work it probably meens your laser has gone and you will need to buy another one
Jul 04, 2010 | HP (176135-630) (176135630) Internal 48x...
Drive can't load many cd's. Cleaned the head with alcohol. Still erratic loading problem.
It might need to be replaced. Check the CD type. There are also CDs that certain drives does not accept. Check if it has a + or - sign beside it. Also check if your CD-ROM can read a + or - CD type. But usually, if this is the problem, I usually recommend replacing the CD-Rom drive. If you really want to repair it then try the motors inside, it could be malfunctioning. If you'd rather replace it, try buying the one that can read +/- CD. I also recommend buying a "DVD-RW +/-" instead of an ordinary CD-ROM. It can function and read all CD or DVD with a "+" or a "-" type. You can also burn CD or DVDs using this.
Nov 08, 2009 | Lite On LTN - 529S Internal 52x CD-ROM...
Emac = cd rom?
Yes, you will be having the CD rom drive, It will be available for every Emachine computer
Aug 29, 2009 | E-Machines emachines (emachinees) CD-ROM...
The CD ROM Drive is not ejecting properly
hi,
Locking device / software installed
First, verify no locking software is being loaded, which would allow the CD-ROM tray not to open. If you are unable to determine this, reboot the computer and as it is booting up, attempt to eject the tray. No power to computer or CD-ROM drive
If you have recently installed a new CD-ROM drive or you have moved the computer, it is possible that the power to the CD-ROM may have become loose or disconnected. Check the cable connections. Bad eject button
If you are running Microsoft Windows 95, Windows 98, Windows NT 4.0, Windows 2000, Windows ME, or Windows XP, open My computer, right-click on the CD-ROM drive and choose the option to eject. If this ejects your CD-ROM drive tray, it is likely that the button on the CD-ROM drive has become defective and it is recommended that the drive be replaced. CD stuck within drive
It is possible that a CD may have become stuck within the CD-ROM drive. If the CD-ROM drive has a small hole (that is not the head phone jack), using a paper clip, place the paper clip within the hole and attempt to manually eject the CD-ROM tray. If the CD-ROM drive is only partially able to be opened, attempt to pull the tray gently to see if it can be manually ejected. If it cannot be opened any further, it is likely that the gears within the CD-ROM drive have become bad, dislodged, or that a CD is positioned in the drive, which does not allow it to open. Incompatibility with IDE / ATAPI interface
If you have an IBM compatible computer and recently installed the CD-ROM drive and are unable to open the drive, attempt to temporarily disconnect the IDE cable to verify that you not experiencing an issue with an incompatibility between the CD-ROM and motherboard. Once the IDE cable has been disconnected, power on the computer and see if the CD-ROM drive tray is now able to be opened. If the drive is able to be opened with the IDE / ATAPI cable disconnected, it is recommended you use the interface card supplied with the CD-ROM drive or the ATAPI interface on the sound card / motherboard. Bad drive
Unfortunately, if after following the above recommendations you are still unable to properly open the CD-ROM drive using the button on the front of the CD-ROM drive, it is likely defective and should be replaced. Caution: If you are able to open the CD-ROM drive using a paper clip. We do not recommend that you continue using the CD-ROM drive by manually ejecting the CD-ROM using a paper clip. The drive should be replaced and this is not meant to be used as a temporary solution. Additional information and tips for buying a new CD-ROM drive can be found on our CD-ROM buying tips section.
Jul 02, 2009 | Computers & Internet
Cd-rom drive broke , need to replace but dont know what will work
YOU CAN GET A ROM OFF OF EBAY, NEWEGG.COM OR WHAT I ACTUALLY SUGGEST IS BUYING AN EXTERNAL USB CD/DVD DRIVE. THEY ARE STILL AVAILABLE DON'T BELIEVE ALL THAT NONSENSE.
yep i just looked on newegg.com you can buy them brand new for $18.00 with cd and dvd or just cd
Mar 31, 2009 | Sampo DVE-620 DVD Player
Where can i buy a dvd rom and how to install it
You can buy a DVD rom from any regular electronics and computer store. just go there and ask for a DVD rom
Sep 24, 2008 | Dell Compact Disc Reader CDR-1900 CD-ROM...
Computer
Hi Diviola, you have no choice but to buy a CD-ROM drive. They are not as expensive as you might think. You're windows CD can format the hard drive in you're computer before installing windows. Some people can use a USB memory stick but in order to copy the windows CD software to the memory stick you'll still need a CD-ROM drive. A 2GB or 1GB memory stick will cost as much or more than a CD-ROM drive. Please click on the link to see some prices for a standard CD-ROM drive.
http://www.zipzoomfly.com/jsp/ProductList3.jsp
& here.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3287198&CatId=87
The link above is a CD-ROM drive & can also make CD-RW's (RW stands for re-write).
You can replace you're CD-ROM drive you're self. Just do not disconnect the cables from you're old CD-ROM drive untill you have the new drive. Connect the cables to the new drive (one at a time) as you disconnect them from the old CD-ROM drive.
Double check that the cables are tightly connected before you power up the PC. Load you're windows CD into the new CD-ROM drive & when you start you're PC up windows will start to load.
When you receive the new CD-ROM drive & if you need help connecting & running anything. You can come back here & ask questions. I'll help you through this.
Luck!
Mike
May 10, 2008 | Creative Labs Sound Blaster Live! 5.1...
Compaq (142307-001) Internal 24x CD-ROM Drive Logo
178 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
