Question about Jandy Aqualink - Rs24 One Touch Pool / Spa Combination Control System
No heat for the spa.
While the spa is activated once pressing the spa button on the indoor control panel, with water circulating to the spa, there is no heat. Can you advise on reasons and what we can do to correct. Thanks!
  • shayt3330 May 11, 2010
    Your answer sucks ***
  • Anonymous Mar 17, 2014
    spa is coming up with error 8 control panel wich our manuel says may be water in the control panel but is dry and clean ?
    Problem Solver:
  • 7 Answers
Go to the heate and see if it tries to start and report back on any noises you hear or click or fans or is you smell gas
Posted on Jan 06, 2009
I have an EC display on my panel
That means your "Heating" mode is in Economy! Without knowing what make our model spa you have, or the manufacturer of spa controls, difficult to assist in telling you how to switch to other modes. Maybe try this:
Pressing the "Temperature" button and then immediately the "Light/Jets" button may change the system back to Standard? Once you press those buttons, the "Ec" code comes on and stays on (flashing), and then you can press the "Light/Jets" button to toggle between Standard and Economy and maybe SL - which is Sleep modes.
Good luck
Feb 22, 2015 | Pool & Spa
How to use Sino Spa spa controller pad
controls operate the pump to circulate the water..there are controls for bubbles and an air pump to increase the volume of the bubbles..and a setting to run the tub slower to allow heating of the water..
Dec 18, 2013 | Pool & Spa
Balboa hot tub.. how to turn up the HEAT / TEMP , no owners manual, and does anyone know where I can get one?
You do not have a Balboa Hot Tub. That is the company that made the control panel for it. Id venture to guess it's either a Hawkeye, Barefoot or Master spa if it came with no owners manual. To turn up the heat simply press the Red "up" arrow on the digital control pad. Check out the link below. It's a quick reference guide to what I'm guessing is your top side control.
http://www.hawkeyespas.com/pdf/balboa-504-topside.pdf
Apr 22, 2013 | Garden
Hi have problem with canadian spa (balboa mrspa1) control panel digital reading when turned on goes to OH,circulation pump will not run
OHS, OH, or SPA TEMP LMT Message There is an "Over Heated Spa" (OHS or OH) Water Condition.
One of the Water Temp Sensors has detected 110°F (43.3°C) Incoming Water Temp and Spa Functions are Disabled. System will Auto Reset when Water Temp is below 108°F (42.2°C). Check for Extended Pump Operation or High Ambient Temp, or contact your Dealer or Service Organization.
Spa Water Cool Down
• In order for the Spa Water Overheat Error Message to Automatically Reset and Clear, the Spa Water Must Cool to below 108°F (42.2°C).
• Check the Topside Panel Display to see if the "OHS", "OH", or "SPA TEMP LMT" Spa Water Overheat Error Message has Cleared. If the Error Message has Not Cleared, the Spa Water is still too Hot to Continue Testing.
• Either Wait for the Spa Water to Cool Below 108°F (42.2°C), or Exit Now and Retest at a Later time.
You can find answers to COMMON SPA MESSAGES at the following website:
COMMON SPA PANEL MESSAGES
Hope this helps.
Mar 30, 2011 | Balboa Instruments Duplex Digital Panel 2...
My heater is heating to 100 degrees as indicated on the heater, but the actual temp in the spa is much less, usually 10- 15 degrees less
Press menu, scroll to settings. There should be a choice labeled "calibrate". You can change the temp reading here.
Mar 27, 2011 | Pentair Easy Touch Indoor Control Panel...
Hot tub heating is working but pump has stopped
you may have a system that uses a small circulating pump that circulates the water thru the heater to keep water temp at proper level (this is usually the case with hot springs spas and is because it is the most cost effective way to maintain constant water heat without using a full size pump or two speed pump just to push water past the heater core. therefore the issue is you have a problem with your jet pump and it has nothing to do with the circulating and heating portion of the spa. you can check to see if there are any reset buttons in or near the equipment as well as open enclosures to make sure everything is clean and dry also make use any contacts on spa skirting are secured propertly
Apr 24, 2010 | Pool & Spa
Water temperature thermostat misread
You most likely have a bad water temperature sensor. Replace the water temperature sensor that is probably near the discharge side of the filter pump. That should take care of the problem.
Oct 17, 2009 | Pentair Easy Touch Indoor Control Panel...
When I change the temp. setting it keeps heating at original temp
The keypad appears to working correctly.
When you alter the set temperature via the keypad the display will flash the temperature thats to be acheived, once it stops flashing the keypad will revert back to the current temperature of the water.
Hope that helps,
Ian.
http://hottub.synthasite.com
May 24, 2009 | Balboa Instruments Duplex Digital Panel 2...
Jandy Aqualink - Rs24 One Touch Pool / Spa Combination Control System Logo
255 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Bill Jordan
Ian Kime
Ian Kime
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
