Question about Valentine One Vehicle Parts & Accessories
How to wire a cigarette plug - Valentine One Vehicle Parts & Accessories
  • Matt Parr Oct 31, 2012
    I have the cord because it was recently hardwired but i want it put back into a cigarette plug. There are four wires, black, red, green and yellow. and the plug i bought has two mounting options. Where does each go? Any help would be much apreciated.
    Problem Solver:
  • 13 Answers
2006 dts cigarette fuses not working
cigarette fuses not working ? fuse keeps blowing ? Could you elaborate a little ?
Nov 13, 2016 | 2006 Cadillac DTS
What are the precautions to take when removing the battery that will not disturb the car radio when you have no resetting disk for a car radio
get a 9 volt battery and cigarette lighter plug and connect the 9 volts battery positive to the center wire in the cigarette plug and negative to the second wire, then plug it into your cigarette lighter socket, then you can remove the car battery and install the new car battery. good luck :)
Oct 14, 2014 | 2005 Ford Fiesta 1.3
2005 Sebring cigarette lighter's not working
This could be several issues:
1) bad fuse.
2) something (rodent) damaged a wire. I had this happen to me with spark plug wire.
3) lighter itself has fail. Sometimes the spring that holds the cigarette light down fails to do so.
Aug 12, 2014 | Cars & Trucks
I just got my first cb and am trying to install it. I have connected the red wire in the fuse box( to the radio) and grounded the black wire. turned the car on and I cannot get any power to the CB, but the...
Take a deep breath and start over! The best way to power this little radio is probably through the cigarette lighter or 12vdc accessory jack. It is simple and straight forward and no fuse box or negative ground wires to worry about. Go the Radio Shack, purchase an adaptor (cig lighter type) and hook it up to your radio wiring being careful to watch polarity. You may have to have your ignition on to run the radio, but that is much safer that maybe blowing up the unit.
Unless you are running a larger more powerful unit or an amp, there is no added benefit to hooking the radio into the fuse box.
Dec 16, 2010 | Cobra 19 DX IV CB Radio
Does the CP-17L Icom adaptor have a voltage regulator or is simply a wire with 2 plugs and a fuse? In other words, can it be replaced by any wire with a cigarette lighter plug in one end?
Hi, the best way to determine if this plug simply just a plug, is to take it apart. By then, you can replace the fuse and not have to buy another adapter. Hope this helps.
Nov 18, 2010 | Icom CP17L CIGARETTE LIGHTER FITS...
Cigarette lighter came undone. how do I reattach?
I had this problem as well. Start by removing the small plastic plate by the emergency brake (Pull the brake up). It just pops off, Then remove the left side of the middle console that includes the cup holders and ash tray. It will loosen and you will have to manuever it to take it completely out - turn it sidways to get it out from the shifter, You will need to do this to get to the two screws holding in the front panel where the cigarette lighter is at. Using a phillips screw driver, unscrew the two screws at the very botton of the panel near where it would meet the center console. These screws are hard to get to but can be done. Once you have removed the screws, starting at the bottom, begin to remove the panel slowly as the wiring will still be attached. Unclip the emergency blinked power clip. The cigarette will have two plus that will clip off. The wiring will still be harnessed to the panel, By using a flat screw driver, you can push in the plug clips from the opposite side and the wiring plug will come out. Now you have the panel completely out. Position the cigarette holder in, the metal clip with the little handle goes to the rioght hand side in between the two plastic plugs.holding this all together, there should be a metal ring that will screw back in to hold the cigarette holder in place. once this is secure, plug in the three wiring clips and then plug in the wiring harness once you have the panel positioned to put this back in. once your wiring is back in re-mount the panel and put the two screws back in. Put in the center console molding and then put in the small molding by the parking brake.
I am a woman with no mechanical experience , so goes to show you that this is possible. Time it took me to repair - 30 mins including figuring out the panel screws etc.
Dec 18, 2009 | 2005 Mitsubishi Outlander
Cigarette lighter does not work
first check the fuse, next, get a light tester and see if you getting power to the lighter unit. two wires to your cigarette lighter one black for - and red for +, if you getting power, your line is good that mean your cigarette lighter unit does does not have a good contact to what ever is plugging in. replace the unit; if no power to the unit, test the cigarette fuse and see if the wire is hot. if not you have a short to the fuse. hope that help some..good luck
Jul 07, 2009 | 2000 Ford Taurus
Aux Pwr Outlets not powered
there is a plug on the back of cigarette lighter. it has two wires. it could possibly be unplugged. test it there. it should have the positive wire in the center and ground on the outside. the cigarette lighter receptacles go out sometimes and can be replaced if you have voltage in wires but plug in doesn't work.
Jan 01, 2009 | 1988 Chevrolet S-10
Zumo 450 Power Through Cigarette Lighter
You should be, Check to make sure the fuse isnt blown on either the cigarette lighter plug or in the plug that has the wires coming out of it.
Nov 24, 2008 | Garmin zumo 550 GPS Receiver
Vehicle Parts & Accessories Logo
51 people viewed this question
Top Valentine One Vehicle Parts & Accessories Experts
John Nolan
Christian Krentz
Christian Krentz
Are you a Valentine One Vehicle Part and Accessory Expert? Answer questions, earn points and help others
