How to use the dvd player how to play a dvd how to get a picture
I have a toshiba flat screen tv and a toshiba bluray dvd player . The tv and the dvd player are hooked up correctly. the dvd player is ON the disc is in and I do not get a picture on the tv screen. If I turn on the tv I get a tv show and I want to play the dvd. How to I switch the tv to a mode that will play a disc??
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
Should be with the remote---whatever input on the rear the unit is connected to you have to switch the set to THAT input to see the DVD
Posted on Nov 01, 2012
SOURCE: Black & White picture
This worked for me push your n/p botten to NTSC then go into setup and put your generl SPDIF output to SPDIF/RAW and then go over to video and make sure your compontent is off hope this helps
Posted on Sep 22, 2007
Benimur
  • 6966 Answers
SOURCE: How to play a DVD on my Toshiba DVD Player
Using the Toshiba's remote, select either Video (1...X, if several) or S-Video depending to what Video INput the DVD was connected to the Toshiba.
Good luck and kind regards.
Posted on Nov 25, 2007
SOURCE: DVD player - ERR
error in any disk i put in!!!!!!!!!
Posted on Nov 23, 2008
fieldy14
  • 456 Answers
SOURCE: my Toshiba portable dvd player says no Valid Disc
If the units under warranty you may want to contact Toshiba as it sounds your unit is in need of a replacement laser assembly.
If the unit isnt under warranty, Toshiba should be able to supply the parts you need and as long as you mark every thing that you remove, as to know where it goes when re-assembling the unit. The lasers arent difficult to replace. Good luck.
Posted on Jun 07, 2010
SOURCE: The Kick-*** Bluray won't play on my Toshiba
Finally found the BDX2000 firmware.
Here ya go:
http://support.toshiba.ca/support/ceg/downloads/all/view.asp?docid=D000026
Posted on Sep 08, 2010
Why won't my westinghouse tv model tx 47f430s play bluray, but it will play regular DVD's just fine though?
This fault is not a user repairable one, especially to blu-ray players. Contact the authorized service center for Westinghouse.
Gopakumar Gopalan Google
May 16, 2014 | Westinghouse Televison & Video
Thompson DVD DTH271E refuses to play HD DVDs but fine normal DVDS, cant seem to get any help via Thompson, & think may need "firmfare" update? New machine but in Spain & language...
Hello there.
Push "Play/Pause" and "DVD Rec" on the dvd recorder a few seconds to see the service menu. There you can find your firmware version.
Post back the version for us.
Hope this helps.
May 06, 2008 | Televison & Video
What are the best settings for the DMP-BDT330 Panasonic Bluray Player
Hello Myles, we recommend you connect the player with a HDMI cable and then set the player's output to 1080p.
Apr 27, 2014 | Panasonic Televison & Video
5 yr old Westinghouse TV w built in DVD player. DVD player won't play. Tried several different movies, none will play.
First thing I would check is that you are playing regular DVDS and not BluRay. Your TV may be old enough not to accept BluRay. If it doesn't work with a regular DVD then you most likely have a bad reader which can be replaced but you will have to take the tv apart to get to it.
Dec 12, 2013 | Westinghouse Electric SK-32H570D 32 in....
Toshiba 26 inch lcd tv/dvd combo lost picture
I have same problem with a 7 month old Toshiba 26LV610U LCD TV/DVD combo.
Feb 10, 2010 | Toshiba 26HLV66 26 in. LCD TV/DVD Combo
I need a firmware or software update to play a hddvd in my flatscreen/dvd combo. its an emerson 19inch flat screen model ld195em8
Sorry to say, but a firmware update will not reformat your DVD player into BluRay or HDDVD capabilities.
There is only one way to get your TV to display BluRay DVDs, that is to purchase a BluRay player and connect it to your TV with a HDMI cable, now this will also require your TV to have a HDMI port to connect to, and your TV must be able to display full
1080p resolution,with that said I don't know of a 19" TV that is full 1080p capable,especially not a combo unit.
Good luck !
Jan 11, 2010 | Televison & Video
Attempting to play a DVD on a Toshiba player but not able to get full screen picture on TV. Can you help with the problem?
A DVD plays in "Letterbox" format. To have full screen, the TV settings need to be changed to full screen, or zoom. Found in the TV menu of most TV's.
Read ya
Z
Dec 31, 2009 | Toshiba SD-K760 DVD Player
Sony Bluray player Picture blinking on and off
Hi Lauren,
We had this very same problem and all we did was upgrade our standard, generic HDMI cable to a Monster brand "higher def" cable, and all was right with the world. Hope this helps!
Nov 15, 2009 | Sony Televison & Video
DVD picture is in Black & White only.
Are you trying to play an NTSC disc in a PAL player, If so,your player has a switch or
on-screen setting to select the output format for NTSC discs,
Or maybe you have connected one of the component outputs (Y, R-Y, or B-Y) of
your DVD player to the composite input of your TV.
Please rate this solution
Jan 20, 2009 | Toshiba 26AV500U 26 in. LCD HDTV
Televison & Video Logo
364 people viewed this question
Top Televison & Video Experts
