Just installed a ct-3271 prostart starter in my 1996 ranger everything seems to be working except I can't get it through ready mode, I go through ready mode and at the end when you take the key out it says it should stay running and it does then it sais hold the I or II botton for a second and the lights should blink twice to confirm ready mode has been activated but the lights only blink once and it still won't start just blinks once when pressing the remote which means ready mode hasn't been activated! Help please!! Lol
SOURCE: I can't find a code.
need the code for a philips
Posted on Jan 17, 2008
SOURCE: led light will not light
When I push the TV button or the set button or anything, It will not blink but comes on steadily for about 30 seconds. All the instructions say press the set button and wait for the red light to blink. It will not blink, it just comes on steady. I am at a loss for what to do!! i also need to know how to program the remote to a sanyo?
Posted on Feb 05, 2008
PaulTulsa
  • 14 Answers
SOURCE: same problem
Press 1 after 9-9-1. The "1" code is the TV code.
Posted on Feb 23, 2008
  • 217 Answers
SOURCE: almost home...
http://www.remotecodelist.com/remotes/jensen/JR300C.pdf
Posted on Mar 20, 2008
SOURCE: viper remote starter-
Have this problem also. Took new vehicle (5009.2 miles) to dealer. They suggest that something in the control module tends to stick causing the battery to drain and that it is not an uncommon problem that they see. We had single digit temperatures here when the problem occured. It got up to 20 yesterday and everything works well again.
Posted on Jan 04, 2010
I have to install a remote starter ProStart 3271 ct J need to chima Electric to complete installation I need to connect the wire starter kill output
talk to prostart on custom car hacks.
only th
ey can help., after all its THEIR design.
when stuck far from home , dont expect some pro to figure out your custom wiring , for cheap, for fast or even possible.
dont hack cars! and save tons of grief and cash,,,,
unless its a toy. then hack away.
looks like you are already in trouble. sure.
(done many)
Sep 13, 2014 | 2001 Toyota Corolla Sedan
Need help with the 3 pin harness from a prostart car remeote starter ct-3460tw how to wire to my 2000 jeep tj sport with manuel trans
It looks like those are the Lock/Unlock wires with a ground for power locks that rest at ground. Your ok without them just finish your install. Good luck Sir.
Nov 03, 2013 | Vehicle Parts & Accessories
You may have this posted in the wrong product category. Please select another category appropriate to the problem and re-post the problem so the correct expert will see and respond to the question..
This is for car and truck problems related to Factory Installed Systems not add on aftermarket systems.
This post can't be removed or moved, please re-post the question in the correct product category. Thanks
Oct 31, 2012 | Cars & Trucks
Hey MECP guy, what a job you're doing; THANKS. I want to buy the Prostart CT-5472W for a 2004 Lincoln Navigator. I also want to get addt'l modules like DEI 504D shock sensor 506T audio sensor
Yes, I frequently use DEI modules with Audiovox( Prestige and Code) alarms and remote starters. I just have to hardwire them to work with the systems.
Oct 26, 2012 | Vehicle Parts & Accessories
I installed prostart remote starter in 2002 Sonoma,used xpresskit bypass module to bypass passlock 2, truck started with remote ,now won;t start with remote,have to reset and start with truck key
If you are sure that everything is connected properly, then the only explanation could the ground when running from the remote starter to the bypass. If you are using data to data(D2D), switch over to wire to wire. Test the ground when running connection from the remote starter (white) to the ground when running connection of the Xpresskit (blue). You could even go so far as to connect the ground when running of the bypass to constant ground for the test. You CANNOT leave this wire connected to chassis ground.
Also, that vehicle has a second ignition wire(white) that MUST BE power up for remote start. If not, it will trigger the check engine light.
Oct 01, 2012 | Vehicle Parts & Accessories
I need a instalation manual for instaling a prostart ct3271 in to a 99 olsmobile intrigue
this address will take you to the pdf manual for this product...http://www.engines911.com/asdocs/CT_3271_ig_en_h46s40_081031.pdfhope this helps. if not google prostart ct 3271 and it will take you to their site, im sure you can find more options
Dec 31, 2011 | Cars & Trucks
I have manual transmission car and I installed the
this is working proper, you have to set the system to ready mode everytime you want to be able to remote start it, this is a safety feature
Dec 27, 2009 | 1996 Honda Accord
Looking for installation manual for a prostart ct-3100.I would like to install it in a 2000 gmc jimmy
http://www.engines911.com/asdocs/CT-3100_ig_en_h100s100v100_010810.pdf
here is the information you requested, good luck on the jimmy, you will also need a passlock 2 bypass modual and a door lock polarity inverter, let me know if you need them as I stock these items
Dec 10, 2009 | 2000 GMC Jimmy
Need install manual
http://www.engines911.com/asdocs/CT-3200_ig_en_h370s380v150_040902.pdf
copy and paste into your browser... should be able to download and print...
Jan 06, 2009 | Vehicle Parts & Accessories
Televison & Video Logo
57 people viewed this question
Top Televison & Video Experts
