Question about Vizio VBR120 Player
Reset parental controls password for Vizio VBR120 DVR player
I forgot the four-digit password to my kid's DVR. Is there any way to reset the password?
    Top Expert:
  • Vizio Master
  • 14,553 Answers
Many have a default code like all 9's but you may have to call the maker if not in the owner manual.
Posted on Nov 01, 2012
SOURCE: my vbr120 blu ray player
I have the same problem. While I don't have the permanent solution, I can tell you a few things. 1) You don't need to unplug, simply hold the power button down on the unit until it does a full reset (it normally just goes into standby mode when you tap the power off button). 2) I've noticed the locking only happens if I try to watch a netflix after I've used an optical disc between resets. IMO, I believe it's a problem with the system memory not updating and won't be solved unless they put out a specific firmware upgrade for it (unlikely on such a cheap player).
Posted on Feb 16, 2011
  • 16 Answers
SOURCE: need unlock code for vizio
There is no unlock code supported by this firmware.
Posted on Feb 22, 2011
  • 16 Answers
SOURCE: I need the dvd region code for the Vizio VBR120
Hugo, there is no region code change available for this units version of firmware.
muntejaya
  • 10421 Answers
SOURCE: region code for vizio vbr120
Please get the code here :
www.regionfreedvd.net/ www.dvdripper.org/dvd-region-codes-vs-ntscpal/ www.regionfreedvd.net/players.html
www.dvdreviewer.co.uk/Forums/...region_code/page1
Best Regards, Jay__45r
Posted on Feb 27, 2011
dss902
  • 16 Answers
SOURCE: I have a Vizio VBR120
The default IP mode is set to Dynamic, which means your player will automatically detect and use
your network settings after you connect your Ethernet cable, but you can manually change these
settings if you are an advanced user and are comfortable with networks.
1. Turn on your player and your TV. If a DVD is not in the disc tray, the Home menu will be
displayed. If a DVD is in the disc tray, press SETUP to display the Home menu.
2. Connect one end of an Ethernet cable (not included) to the Ethernet port on your player
3. Connect the other end of the Ethernet cable to your home network (usually your router
home network must have broadband Internet access such as cable or DSL.
4. Press to select Settings, and then press SELECT.
5. Press to select Network, and then press SELECT.
6. Press ^ or down to select Wired and then press SELECT.
7. Press to change IP Mode to Manual and then press SELECT.
8. Manually change your network settings such as IP Address, Subnet Mask, Default
Gateway, the Primary DNS, and Secondary DNS.
9. Press ^ or down to select Apply and then press SELECT.
Note: If you need additional help setting up your network, please refer to the user manual for your
router or contact the manufacturer of either your router or your Internet service provider if they
provided the router for you.
Your ip settings will look something like this 192.168.2.1
You might be able to find you setting by going to Network Connections -> 2x click on Local Area Connection -> then click on the support tab.
Posted on Mar 05, 2011
Resetting parental controls
there seems that only 4 digits are the max but I could be mistaken, as far as reseting the password there is nothing listed on the Vizio website in the manuals ect for reseting the parental controls, probably due to security for the owner.
But there is a solution
if you call 877 MY V I Z I O
with you model number of your unit and make them aware of the parental lock issue there might be a way for them to explain the resting everything back to factory settings.
Aug 11, 2008 | Televison & Video
Forgot parente control password
It seams parents like to set a password the and finally forget it ,don't worry the password unlocker will help. Top 4 Free Methods to Reset Windows Password
Feb 27, 2014 | Techno Source Kurio Kids Tablet With...
How do i reset my kurio 7 tablet my daughter forgot the password
factory reset true Recovery mode
vol+/- homebutton last power key
realease home key and - vol when boot
in recovery mode select "FACTORY RESET" enter
"ERASE CACHE" enter
REBOOT DEVICE-
Done
Jan 08, 2013 | Techno Source Kurio Kids Tablet With...
Hisense H32V77C password reset
I couldn't find it anywhere in the service manual but you can try calling there support line. default is 0000 if that helps anyPhone: 1-678-318-9074
Fax: 1-678-318-9079
Jul 05, 2012 | Televison & Video
553SV Vizio TVand forgot the passcode. Anyway to retrieve it ? Or reset to factory settings
System Info
Display the technical information including model name, version and
revision of firmware, source type, and resolution.
Reset TV Settings
Return all Picture and Audio settings to factory default. A screen will come
up to confirm your selection or to cancel it. Press Left or Right Navigation
buttons to make the selection, and then press OK to accept it.
Note: This does NOT reset the Parental Control Password.
Clear Memory (Factory Default)
Use this function to reset the TV to the default factory settings. The screen
will display a message to confirm that you want to reset the values to
factory settings. Press ? or ? to make the selection, and then press OK to
accept it.
Guided Setup
Use this function to return to the Initial Setup menu. Use this function if you
want to have a guided setup when you move your TV. Refer to Chapter 3 for more information.
Note: Previously scanned channels will be removed.
Aug 16, 2011 | Vizio P2 42 in. HD-Ready Plasma Television
My son forgot his dsi password. What do we do next?
Hi.
Go into system settings and navigate to parental controls, tap on yes to change parental controls. Where the DSI asks for the password tap on "I forgot", it should then take you to the secret question page. Enter the secret question and you should be able to reset the password. If your son has forgotten his secret question again tap on "i forgot". It will then give you an 8 digit code. Leave it on that screen for the time being. Don't tap OK.
Post that code here and I should be able to provide you with a 5 digit code so you can reset the password and clear the parental settings.
Regards.
Jun 28, 2011 | Nintendo Video Game Consoles & Games
My son blocked everyone out of the tv with parental control. He can't remember the password he used and I can't get the reset to do anything. How can I fix this?
If you have reset the TV back to factory settings, you can use the factory unlock code, which is 0000.
To Reset the TV:
  1. Press the MENU button on the remote control to display the Main menu, and select SETUP.
  2. Highlight Reset Default, and press the OK button.
To Remove the Parental Control Block:
  2. Highlight Parental, and press the OK button.
  3. To use the Parental function, must enter a four-digit password. The factory password is 0000.
  4. Select Program Block, and press OK to display the Program Block menu.
  5. You can remove the parental control in this section.
May 25, 2011 | Polaroid TLA-01911C TV
MAnual/Reset Parental Control Code
According to the manual, "If you forget the password, you can erase your current password by pressing the number 8 button on the remote four times, thn press the enter button to confirm the setting. PASSWORD: 8888"
A picture of an unlocked lock indicates that Parent Lock is NOT active.
Parent Lock Levels:
1: Kid Safe 5 : PG_R
2: G 6 : R
3: PG 7 : NC _17
4: PG_13 8: Adult
It also says that it takes 3-5 seconds to reset the unit to the factory default. I hope this helps! Karen
Feb 17, 2008 | Durabrand Portable DVD
Parental control
Here is the procedure to reset the parental lock code:
  1. From the XBOX dashboard screen, go to settings and then parental control.
  2. When prompted for the password, perform the following sequence using the XBOX controller: X, Y, Left Trigger, X.
  3. Enter in a new password, or disable parental control entirely.
fixya!
Feb 07, 2008 | Microsoft Xbox Console
Vizio VBR120 Player Logo
405 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
