Question about GE Refrigerators
My Refrigerator makes ice but doesn't dispense water
I have ge refrigerator model#gsh25jsxnss Refrigerator makes ice but doesn't dispense water History One day this happened to me out of no where. i've chicked the filter but get the same result. . Any ideas?
    Top Expert:
  • GE Master
  • 9,472 Answers
The water reservoir is probably frozen. Remove the drawer second from the bottom and place a hair dryer on the shelf blowing on the coil of water line referred to as the water tank/reservoir. Let it blow hot air on it for 10 to 15 minutes. Try the water dispense. If the water flow is restored, set the fresh food section one setting COLDER to increase air circulation. Set the freezer to one setting to one setting warmer to circulate air that is a bit warmer. This corrects 90% of the issues related to water dispense.
The other 10% is normally the fault of the water valve.
Here is the water valve to order in case it is faulty.
Regards,
Richard Roth
http://appliancecafe.com
Posted on Oct 31, 2012
  • 409 Answers
SOURCE: Kitchenaid side/by/side refrigerator Model KSCS25INSS01-Auto defrost happening often and ice machine not producing ice
hi there,
the icemaker is not making ice due to the fact that the valve solenoid may need replacing.
check the water line into the icemaker, to make sure that you don't have a water leak.
the reason the fridge is running is due to the fact that it's trying to remove as much warm air out as possible.
i would have a technician look at it.
Posted on Sep 17, 2008
SolutionGuy
  • 331 Answers
SOURCE: GE Profile Refrigerator Ice/Water dispenser not working
Hi Urban Woman,
Unfortunately, your dispenser interface board has gone to appliance parts heaven and needs to be replaced. Fortunately it's relatively cheap. If I recall correctly, all you have to do to access the dispenser board is use a small flat screwdriver. There are 2 locking "tabs"/slots on either side and underneath the board (you will barely be able to see it, they're just that small). 6fb5654.jpg
Of course you already know that you need to unplug the fridge before doing any repairs so I can skip that part.
Insert your screwdriver into those slots and pry the bottom of the board out. Then grasp it with your hands and remove it completely. There are three wire bundles on it, remove them and re-install them on the new board. Then simply snap the new board into place.
This should take maybe 15 minutes to do... super easy job.
SG
p.s. Here's a link to the service manual, but the removal of the dispenser board is not in it (everything else is, though, so it may come in handy later)
p.s.s. Since you're going to be unplugging the fridge for the repair, you ought to go to Home Depot and pick up one of these to plug it back into. Transient voltage spikes are most likely the cause of all your woes... including the main board that was replaced.
Posted on Apr 01, 2009
SOURCE: My Jenn Air refrigerator ice maker quit working
My Jenn-Air refrigerator (JRSD2790) quit making ice, dispensor works, water dispensor works. Do I need to replace the entire
ice maker?
bjones03@comcast.net
Posted on Feb 13, 2010
  • 13 Answers
SOURCE: LG refrigerator won't dispense water any more
The water line is freezing in the door due to deteriorated insulation. The only fix I have found to work on my fridge was to defrost the inside door with a blow dryer. Then place a weedeater replacement line (the orange 10" or so size you find at Lowes' or Home Depot) up through the dispenser nozzle, If the line only travels about 3-4 inches up the nozzle, then ice is still in the tube. Blow dry it until you are able to get water to dispense. After the tube is ice-free, place the weedeater line up throuth the dispenser nozzle leaving about 1/8" sticking out. The dispenser will still work with the line stuck in it. The dispenser will probably freeze again in about 8 hours, But all you need to do each time this happens is to pull the weedeater line out, dispense the water to unclog the ice, and place the weedeater line back in the nozzle. I have been using this method for about a week now and it works great. My GE Side-by-side is also 4 years old and this seems to be a problem with all of them. There is a part you can order to fix the problem, but I have heard it may not work.
Posted on Mar 21, 2010
  • 19 Answers
SOURCE: Ice maker in our GE profile refrigerator is not working
Ice maker Diagnostic Test:
- Remove the ice bucket
-Turn the ice maker off, wait 15 seconds than turn it back on
-Press the ice paddle three times, this will begin diagnostic test.
-PLEASE DO NOT TOUCH ICE MAKER DURING DIAGNOSTICS
-In 3 minutes you should see the rack inside turn 360 degrees
-AND the ice maker bowl should fill with water
-IF either DID NOT work, call 1-800-GE-CARES for ice maker replacement. A service call is approx $80. The $80 will be deducted from the part/labor if you choose to purchase/install parts from the service technician. If not, you will pay for the service call. Good luck.
Posted on Apr 05, 2010
I have an Amanda double Door refrigerator with an ice & water dispenser. The ice machine unit's dose not dispense ice cubes,
If the unit is making ice and the water will work from the door but the does not dispense, you will need to replace the "auger motor". Here is the part to order.
Nov 28, 2012 | Amana 22 cu.ft. Side-By-Side Cabinet Depth...
Need to replace Ice & Water Dispenser for msd2354 side by side refriderator, how to get the unit?
use your model number to order it from marcone.com, they will give you a parts breakdown and you can get any part you want
Oct 12, 2012 | GE GSS22JF Side by Side Refrigerator
GE GSH25JFRF BB ice maker doesn't dispense. Water dispenses and ice maker makes ice but won't come out.
There should be a plastice hinge cover on the left top hinge on freezer door. Take it off and press the plug together firmly. Try that and let me know, Sea Breeze
Aug 19, 2012 | GE Refrigerators
GE Refrigerator Model GSH22SGRBSS NO WATER TO THE FRONT DOOR DISPENSER. ICE OK
Generally, the path to the water dispenser is as follows: water comes in from the wall, goes through a solenoid (valve), and through some tubing to a reservoir behind the fruit and vegetable compartments. From that reservoir, more tubing goes down under the refrigerator, then up near the bottom of the door hinge of the door that has the water dispenser.
First, listen for if there is a water running sound when you try to use the water dispenser. If there is not, then most likely there is no water coming from the supply at the wall, or the main solenoid where the water comes in is not working. If ice is being dispensed, you know that the switch that you press with your cup is good, but that doesn't mean that water is coming in to make new ice. It could be just existing ice being dispensed.
If you DO hear a water running sound, then something is leaking, possibly onto your floor. Follow the path of the water in the first paragraph to locate the leak. Could be that some tubing came off, or burst.
Nov 08, 2011 | GE Monogram Side by Side Refrigerator
GE Side By Side Ice Machine & Water dispenser not getting water
you may have a pin hole in your water line to your dispenser or you could be leaking at the water valve itself on the water dispenser side. you'll have to pull the refrigerator out from the wall and look where the main water line goes into the back of the refrigerator. you will probably have to take the back off to see. be sure you put the back of the refrigerator back when you are through.
Jun 05, 2010 | GE Profile PSW26P Stainless Steel Side by...
Ge refrigerator makes ice but does not dispense ice
FROZE UP RESEVOIR BEHIND REFRIGERATOR DRAWERS. PULL OUT FRUIT AND SNACK DRAWERS AND DEFROST WITH BOILING WATER OR A HAIR DRYER.
Nov 08, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Arctica (PSS26NGSB) ice and water dispenser
need to call ge at 1800-386-1215 some of these sxs have a door insulation issue that they will either send replacement doors to an authorized service company to exchange at no cost to you or offer a rebate for a newer model. yours might be in this group
have your model and serial number out of the ref located in the refrigerator section, about 4-5 inches from the celing down the right side and call and see
Apr 12, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
105 people viewed this question
Top Refrigerators Experts
KJ4QOB
Jim Akins
rodney bartholomew
Level 1 Expert
